d3c0y
Everything posted by d3c0y
  1. Honestly it's not just a 280ZX badge, JDM cars have that as the bonnet badge in the place of the Datsun one...
  2. I think if you look closely, the metal is folded up at the front of the vent to promote a low pressure zone to help suck the air OUT of the vent. Radiator opening only needs to be 25% of radiator area from memory.
  3. The area where the cowl panel meets the windscreen is a big stall area, so it probably does SFA. In the wind tunnel testing i linked earlier, they popped the bonnet up and it had no effect. For effective pressure venting I think you would need to run the vents further down the bonnet like the Scuderia race car pictured below:
  4. I'm pretty sure they were used on JDM S30 series cars, as they couldn't put the Datsun one on there could they?
  5. Have you tried genuine under 280Z from the states?
  6. Complete interior is out bar the roof lining which i'm considering replacing Heater core is stuffed fix fan duct hoses ( one is split) reinstall dash reassemble doors refit doors swap R180 to R200 make CV companion flanges fit CV axles fit all rubbers fit tail lights fit tail light trims fab up new fuel tank breather fit fuel tank mount fuel reg modify fuel line remove return line wire out voltage reg get smaller alternator belt make front caliper brackets make rear caliper brackets figure out what rear rotors to use figure out handbrake caliper setup refit exhaust wire in rev limiter install temperature switch in thermostat housing for thermo fans zinc plate all old hardware fit headlight assemblies fit bonnet springs fit lower nose section fit front spoiler make brake ducts get panel beater to align the front of the bonnet setup coilovers setup front and rear adjustable arms Should about cover it.
  7. I need a trip meter reset knob if i'ts got one!
  8. Hey i posted a 2 seater. I didnt say they all were!
  9. P.S. to anyone that has been on the forum for a while: I moved the mirrors when i repainted it
  10. Damn i made two posts, if you haven't seen the brakes yet, go back a page! Oh and I reinstalled the fender mirrors way too early, because JDM bling improves motivation!
  11. I spent part of my Australia day, doing the same thing as the previous two years working on the zed! At least it was something exciting, finally getting start piecing together the brake system. You think that bolting on new rotors would be easy, but as with everything there were multiple things that had to be done just to be able to do this: - Buy, sandblast and painted a pair of 260Z hubs - Install new wheel studs - Install new wheel bearings - Remove old gear The RX-8 sport rotors really make the 16" Wats look small when you are looking at them in person and as you can see there is no room to spare to the inside of the wheel. The calipers have a nice flat front on them and have no trouble clearing the spokes even on the 8.5" wide wheel which isn't what i'll be running. The rotor offset was designed to try and position the caliper as close to the stock one, so mission accomplished there! I'll go into more detail on the brakes when I do a post on how I got the mounts done, but for now you get a gratuitous shot of the calipers behind the wheels (even though they are just zip tied there). Interesting note, the stock Z brake lines screw into the Porsche caliper; shame they are ruined... P.S. i know the caliper is on the wrong side.
  12. That car sir, is as ugly as a hat full of arseholes. If you are going to have an evangelical 280ZX thread, at least post a bad ass one.
  13. Come on now Alan, calling it a "240Z shell", is that really correct?
  14. d3c0y
    89Mm Crank
    No i have a 4.4 R200 LSD now with CVs!
  15. d3c0y
    89Mm Crank
    You will see a full Subi R180 4.4 LSD setup, stub axles, reco half shafts, mustache bar etc for sale shortly for this reason...
  16. d3c0y
    89Mm Crank
    Mine was a lot more than that by the time it got to my door... and the Green Hornet is a step up from mine. Don't forget engine dyno time and all the other little extras that go into it. Plus then you will instantly destroy your stock gearbox and then you need to upgrade your tail shaft, UNIs diff etc, etc. I thought that the stock gearbox would be ok for a bit, but when I say destroy i mean the engine literally destroyed it in basically 10 outings, none of which were in the hills or at a race track and more like test and tune trips around the streets to iron out the bugs. Les said the box would have suffered catastrophic failure at any minute if I had kept driving it and the internals were completely unservicable when i sent it down for exchange.
  17. Yeah but the 280ZX was the second generation, just like the FC. Fatter, heavier more luxury. As the lineage started a decade later I don't think the direct correlation between the years applies. As for the FD comment I was just talking about the different front bumpers, and the notion that the most attractive/popular option doesn't always go on to be the most collectible (referencing back to your comment).
  18. d3c0y
    89Mm Crank
    OK, yes just fitting the crank isn't that much more and it's a no brainer in my point of view to do that instead of a V07 as the costs are similar. But 50mm carbs, bigger exhaust, bigger intake manifold, billet flywheel all that stuff that goes with it to really take advantage of it. This is what I did.
  19. I guess with Zs they started with the best looking one first! Also 280ZX = FC so i don't think using a 280ZX in your comparison like that is fair. Do you think that the S6 front on the FD will ultimately be more popular than the S8? Maybe so, but only for the reason is that they will be rare because everyone swapped them.
  20. d3c0y
    89Mm Crank
    Not only that but the cost of all supporting components and machining required to fit such a radical crank...
  21. That thing looks tidy! You can't say that about many Z32s these days.
  22. The series 3 looks so much better though and it has a non-stupid PCD that you can get wheels for and a 13B! I personally jumped ahead and bought an FD. I think there is no way they won't be collectible as they are pretty much the ultimate form of the rotary sports car. I have also changed to a single turbo and V-Mount setup which some people will say is the wrong maneuver, but keeping the stock turbos is just as expensive for worse result and i feel is on par with the setup that I have in my 240Z.
  23. d3c0y
    89Mm Crank
    Does it count if you are cheap and the car is the other two?
  24. But 2+2s don't look as good and weigh more so they are slower, I used to own a 2+2 so i'm not biased.
  25. d3c0y
    89Mm Crank
    And to clarify it makes a 3.35L with an over-bored and clearenced L28 block not an L24.
