3,086 -
25
Everything posted by d3c0y
thats' not the end of the world, but definitely look at the problem areas and think about the areas on the underbody you cant see that may have lead to rust in these areas.
Thanks for the answers guys. Maybe i need to go deeper into what I am doing so we are on the same page. Basically I am building an entirely new brake setup consisting of: Porsche Boxster 986 4 piston monoblock calipers all round (They have different size calipers front caliper pistons - 40/36mm - rear caliper pistons - 30mm/28mm) 15/16th master cylinder (which is what the Porsche has) Custom braided lines (required to fit the calipers anyway) Obviously custom brackets to mount calipers 323mm 2 piece DBA front rotors 26mm thick (from an Rx-8 sport package - 47mm rotor offset - 8% increase in size) 260z hubs Handbrake caliper setup Willwood Line Pressure Reduction valve At this stage, I was thinking of going S13 Silvia front rotors for the rear (easy to get in 2 piece 280mmx22mm) or Z31 front rotors. (274mm x 20mm - correct width for the caliper). The Boxster comes factory with: F Disc 298mm x 26mm R Disc 292mm x 20mm From what I have read, a rear engine car will have a more rearward brake bias from the factory than an front engined car. So what I am trying to do is have a more rearward bias than a factory zed to allow for fine tuning but at the same time run the smallest rotor I have to at the back for unsprung weight advantage. Roberto's answer has been helpful for giving me a ball park to base my targets around at 70:30 and probably aim for 65:35 as a minimum. I think the Boxster is pretty close to 50:50 and obviously I need to figure this out too. As Jason has suggested previously I can do this using % increases and decreases from the stock setup, but this becomes hard with drums at the back. The other question i need to answer is will a caliper designed to work with a 292mm rotor work on something as small as 280mm as that might be another limiting factor?
Stick a little filter on the rocker cover? I don't see this as a big deal. My engine doesnt even have a crankcase vent anymore.
Lol you two, not always "because race car".
MSA sell reproduction ones for a reasonable price. My car has them although i can't find them on teh website. Might be worth a call or email to them.
Schneider 300F Grind Camshaft To Suit L6
d3c0y replied to gav240z's topic in Parts and Tools for Sale
Is it kind of like clearing out men's clothing from your cupboard after a sex change? hahah -
Because you aren't a real man? -
Big cam. -
Well i don't have any chromate at the moment, so short term no, but I do know where to buy it. The only thing that is still yellow zinc in my car is the new g-nose bonnet hinges at the moment so i was thinking of just stripping them back to silver too.
Hi Peter, Thanks, but I know how the stock system works. What I want is a starting point for the new brake setup i'm building for the car in terms front/rear bias. I want to have the bias 5% more rearward than stock at a minimum. Ideally i want to shift the bias too far rearward so i can then turn them down with a proportioning valve.
Can't wait to zinc plate some stuff tonight using my boat anode haha.
OK so bit of a San Maru hiatus due to moving house and so on, Matt (Deus Ex) took me to Cars and Coffee on the weekend and reignited the zed fire for me. Even though I haven't been posting, as I have said before, I have been taking a few pics along the way and I finally have some time to post some new content and progress on the various projects. First up, one of the things that was really holding up my Z-G reassembly was the lack of new bolts and a collection of old rusty bolts and catches, half stripped by my panel beater. Since the US dollar has gained so much strength, it has made ordering parts from the US a not so cost effective endeavor these days.The next best thing (and sometimes the best due to parts being NLA or ridiculously expensive) is to get your old parts cleaned and re-plated with zinc. I found a couple of places willing to do my parts and for a pretty reasonable price, however i had to clean my parts first and the minimum order was $85 and 6kgs. While looking into the zinc plating on the net I came across away to not only make your own zinc plating setup at home, but the same principal can be employed to make an electrolysis cleaner. Basically you are just pushing all the rust off the parts using the power from a power supply. One of the best things is, that because it's using electricity, you don't need to remove any rubber or plastic parts! It's also non-destructive cleaning, literally removing only the rust from the good metal. In saying that, if you have a heavily rusted part there might not be much metal left by the end of process. After you pull the part out, simply give it a quick scrub with a scourer under the tap, as it ends up with a black film on it. I literally made this setup for $3 for Bi-Carb Soda and things i had lying around the garage. You can find really good instructions at the link below, so I won't bother going into detail here on how to build it. However, you can see in the pictures i'm using a 99c bucket, 3 bits of scrap metal and some wire I had lying around. The multimeter is put in series and set to Amps so I could keep track of the current draw. http://www.instructables.com/…/Electrolytic-Rust-Removal-a…/ For the power supply, you can literally use anything from a car battery charger, to a hobby power supply or even an old laptop power pack with the end cut off. The more I play around with the setup the better you can make it work, I am currently using a 7 Amp hobby power supply and have manged to get it operating at around the 6.25A mark. The more surface area the parts have, the more current you will draw and the current draw also went up the more bi-carb I added to the water. At 6 Amps the water starts to get warm so i wouldn't want to push this small bucket setup much further. In the second picture of the bucket you can also see a third big bit of plate steel in addition to the two steel bars i was running. Again big surface area is best and the closer you put your item to the anodes the bigger the current draw and the faster it works. I plan on getting a big rectangle tub and setting up a mesh i can just place parts on for the next setup. Don't be intimidated if you want to have a go as it is super easy and you can try different things to find the setup that works best for you. I'll be trying out the zinc plating setup next so I'll give a run down and some pics of the results from that experiment too.
I was wondering two things: Does anyone know what the factory brake bias for a 240Z is? What sort of brake bias are people running on their race cars? I'm aiming for around 5% more rearward bias than factory, but i dont know what that is, or how to put drum brakes into my bias calculator to get a baseline. My current proposed setup will have 70% front bias which I think is way too much. If anything i want it too far rearward so I can use a bias adjuster to turn them down.
Don't have the dizzy 180 degrees out from when you reassembled the motor?
Is the rocker cover painted 2 pack black or is it some kind of shadow chrome?
Its a 260Z one.
I think i saw this car in West End a couple of weeks back too. It's a 260Z 2 seater right? I've just moved to East Brisbane, so one day there will be another driving around the area too.
He also forgot to add that it's an E88
How much do you want for the Nostalgic heros?
I would definitely sell locally. There have been a few of these come up with turbo motors for less money over here recently.
The problem with twin plates isnt the pedal weight, it's the off on nature of the take up. As i said previously i dont think you will be able to go too light with a standard configuration single plate. How much torque are you pushing anyway? A twin plate is a waste unless its on a race engine or a turbo that pushing big numbers.
I stand corrected.
Will these rubber boots fit my earlier model arms?
Did you know that it has a 280Z lower front valance on it? Just get lowered springs. King springs do a low in progressive rate and linear here in Aus.
You used to post bad ass flared ones Gav, you've just turned into an old man since you got that clock and radio fetish.
