3,086 -
25
Everything posted by d3c0y
These are the only guys i would take my car to in Brisbane for carb tuning and we have taken many zeds there in the past. If you go there put in a fresh set of plugs before you drop it off.
Three of those plugs looks super rich to me (and the other three are still rich). I bet it's running mainly on one carb too. If you take the air cleaner off you should be able to lift the piston in one of the carbs and still have the motor run, but only just. That's how i set the mixtures on each carb and then sync them and repeat. This will make life a lot easier: http://www.ebay.com.au/itm/Carburetor-Syncroniser-Weber-SU-twin-carb-throttle-body-motorbike-sync-balancer-/161057523703?hash=item257fc6c7f7 Warm the car up pull the vacuum advance off and set the base time at around 10 - 12 degrees depending on the fuel you put in it. If that's all too hard just drop it off to CnJ motorsport in Underwood.
R180 4.4 Ratio Lsd, Crown And Pinion. (Or Similar)
d3c0y replied to MyEnquiringMind's topic in Wanted
I got mine from Chesapeake Nissan. They have a great list of parts on eBay and you can just message them direct with specific requests. It's the the purple one fwiw. -
Not sure if that is a sarcastic thanks or not. I just know because this is the diff i have in my car. Don't forget to get a new speedo pinion. -
That diff ratio is out of a very specific model GC8 - STi version 6 Type RA in case you didnt know. -
Being the radio king i'm sure all your DINs are full lol.
Apparently everyone but you, Matt and myself haha.
Garage San Maru is proud to be taking pre-orders for one of our new products (one of currently 2 haha)! DIN triple 52mm gauge surround for 240z heater fascias. Sure you can make your own, but these are laser cut and all the hard work has been done, so it's bolt in. We are doing $50 posted special for AusZ or you can find them on our FB store here: https://www.facebook.com/Garage.San.Maru/app_251458316228. These will come in a natural finish so you can choose to spray them or leave them silver, and can be ordered in a number of configurations. Config 1 No bolt holes. Surround will be held in place with gauge mounts. Config 2 4 x 3mm holes. The top two holes will be used to hold the surround in place, whilst the bottom two holes are purely for aesthetics unless drilled to a larger size to mount along with the heater fascia. These will also be supplied with 2 drilled square washers and 2 threaded square washers to secure the surround. Config 3 2 x 3mm holes in the bottom corners. These can be drilled out and used to secure surround to the heater fascia. I'll test this on a 260Z this weekend to see if it works upside down.
2 door Qashqai - end of an era.
S130 Fairlady Z 280zx 2 seater aka "BADWOG"
d3c0y replied to Fairlady Z's topic in Members Project(s) Journal
I wouldn't be fitting cam sprockets until you figure out why your engine is under performing. Have you checked that your cam timing right now is correct? If they are retarded by one tooth it makes them super slow and not rev out. Does your son have the same car? 260Z 2+2? what ratio diffs are you both running. That will make a huge difference. Also while you are in there checking the factory sprocket has three positions and you can set it to the most advanced hole if you want to get a little extra.Haynes manual explains which is retard and which hole is advanced. Can't remember off the top of my head sorry. I doubt with a stock L28 like that you will notice any difference going to a vernier sprocket and that one looks a little agricultural in my opinion.
Boi Performance (Bits Of Italy) 240Z/260Z Air Box For Triples
d3c0y replied to GongZ's topic in Fuel Systems
Interested to see what their initial filter setup was and what the run was like with just straight stacks and no filters and what the delta is while driving not parked on a dyno. -
"If you want to go tenths faster, spend it on the motor" "If you want to go seconds faster around a track, spend your money on suspension and brakes buy an Evo." Fixed.
I don't know how tall you guys are but i'm 6 foot and the headrest is like around shoulder height on me. And that's probably why they give me no lateral support too.
Yeah i was just joking around. Thank's again for the parts you've made my life a lot easier! Thank you for your generosity!
If you look at the pic of the seat in the car i have the headrest sitting on it.
My Recaros are really uncomfortable, feels like there is no padding in the back. They will most likely be going back in first for re-rego.
Double post! But not the usual bad kind. Even though I should be focusing on buying parts the car actually needs to get on the road, three parts came up that I couldn't resist. The first of items are a pair of reproduction Japanese racing buckets. Matt found them on GumTree for a price I couldn't pass up, after looking at them longingly on Yahoo Auctions many times. Having now sat in them, I can say they are definitely way more for aesthetics than function. You don't need a "No Fat Chicks" sticker with these bad boys as your manly friends won't even be able to ride shotgun with you. They offer no lateral support and would probably break your neck in any sort of accident. Definitely a no-no for any serious track day action. I will be buying a race seat and putting it on another set of rails to swap in when the car goes to Lake Side.
For those of you who aren't subscribers of the BookFace... Obligatory text wall: It's been back for months now and I've just had other shit to do than write about my garage gratuity project. As I've probably mentioned, I went through three sets of flares to get to the ones I've fitted now. A lot of people probably think that a majority of Z-G flares are all the same, but if you are thinking of fitting them make sure you know the measurements you want because all three sets have been widely different and on top of that both Matt and I have bought our flares from Otomoto who have supplied us with three different sets of flares. For reference the ones I currently have fitted are Restored brand and are 60mm rear and 70mm front. This size will fit the 16" Watanabe R-Tyre the closest. They are attached to the body using aluminium Rivnuts and M8 allen cap screws. The holes in the flares needed adjusting with a round file to line up some of the holes in the flares with the ones drilled by the panel beater in the body. The cap screws also burred up some of the paint on the flares when tightened, so they will be fitted out with nylon washers to help stop this happening (If you want more detail on the rivnut stuff let me know). So far I have decided to not fit any welting on the flares, as they fit pretty close to the body and it would be introducing a third colour into the mix and that would detract from the clean look. Also welting seems to be a somewhat American thing, as you really don't see it on cars in Japan. The Z-G nose has gone together really well for aftermarket fiberglass parts and will need minimal fettling to get a decent fit. It's more Restored parts bought through Otomoto and was worth every last dollar of the $1200 it cost. I first wasted a ton of time and money, with another generic five piece g-nose from Japan and just was not even close to being able to fit. It wouldn't even bolt together properly. As Doug always says, if you are going to buy fibreglass, buy the absolute best you can! My panel beater lost some parts in his tenanture of the car; half a lower door hinge, corner of the rear window trim and a whole lot of screws for the door catches and the hatch hinges. It really has highlighted how hard it's becoming to get second hand parts for these cars in Aus now, with the current boom in interest with the model. The front wheels aren't staying and are being swapped to the same size as the rears: 16 x 9.5 -19. As it sits, they are 16 x 8.5 (-9 i think?) Hopefully when the lower control arms are adjusted to have sufficient camber they will fill the flares enough. I have a pic of the plates I got for the car. Not sure if they are crap or not. Leaning towards crap tonight, you decide and let me know below.
No he didn't, what a prick! I heard he has been away on business, hiring staff and doing a merger though (and did offer to do a good deal on hosting the forum). I'm sure he will get around to it shortly from what I heard.
That's where i put mine, I don't plan on sitting in traffic too much as my car is just not designed for those conditions. Should be plenty of airflow when moving and it's behind the thermo fans. I'll let you know how it goes.
Re-attached up the right way now. Yeah there is a lot you can take out of there. I am removing all the fuel lines from the chassis rail and have moved the coil to the block etc. Then you can have specific details like the radiator and the engine bay inspection light that really pop. Best of all I did my engine bay with rattle cans and you can touch up anything you scratch.
That is a crappy pic for the satin black engine bay argument. The idea with the satin black is about making the engine the centre piece of the engine bay. Mine is obviously far from finished but gives you a better idea.
Wow an R100 just isn't worth anything like that to me. I was already struggling with the RX3 coupe for $35k!
