d3c0y
Everything posted by d3c0y
  1. d3c0y
    Fuel Cell
    Sorry standard JZZ30 ecu and dash doesn't seem to support this....
  2. d3c0y
    Fuel Cell
    Mines because I do endurance racing with 2 hour stints in the car.
  3. Yes they are the same diff.
  4. d3c0y
    Fuel Cell
    They sell a send in 12" and 9" that is a float inside a tube so it works with the foam. For a filler, we fill straight in the top, just open the boot.
  5. d3c0y
    Fuel Cell
    I don't think it would be very easy for the foam to break off and just run a filter. In the soarer we have a 120L JAZ circle track tank full of foam and it doesn't have a sump like mentioned above and just has an outlet in the back. That goes to a filter, carter rotary pump, surge tank then 044 high pressure pump and works with no problems.
  6. Still for sale.
  7. Ahh good photo of it, thanks Gordo.
  8. Hey Guys, I have a pair of 2+2 Stainless gutter trims in good condition. $100 for the pair, located in Brisbane
  9. Hey Guys, I am selling off a wing, 3 piece as per pictures. It has been fitted to a car before obviously and there are some holes along the back where it was riveted on. Paint is flaking off but appears to be in good condition and should just require a good sanding to be ready for priming. Located in Brisbane $250
  10. Hi Guys, I am selling my complete R180 LSD package: Subaru STi 4.44 R180 Mechanical LSD - Imported from Japan with around 100,000km on the clock from memory. Billet 4340 clip in stub axles (these are not the crappy Wolf Creek Racing nasty ones). Heat treated to 40-43 Rockwell hardness, double draw on the heat treat as well. Rebuilt axles with solid centre unis (un-used still in the bubble wrap) R180 Mustache bar with urethane bushes New genuine Subaru front seal Fresh Castrol LSX90 oil All you need is your old R180 pinion flange, which you can unbolt from your old diff and bolt on to this one. I ground off some of the casting dags and painted both diff and mustache bar in gloss black, but the panel beater got a bit of over spray on it. It's still clean at least. This diff came out of a 2000 model WRX STi, so is significantly newer than most LSD options for zeds out there. Located in Brisbane asking $2000.00
  11. The best bit is, in the approximately 10 years doug has owned a zed, he would lucky to have driven a zed in total for more than a year, maybe 2?
  12. Hey guys, I have one of the ZCCJDM G-nose front air dams and i'm trying to figure out how exactly i'm supposed to mount it. The mounting surfaces between the air damn and the nose are very far apart. Do people just use big long self tapping screws and just screw it on? If anyone has some detail pictures on how they have secured similar air dams to G-Noses i would really appreciate them.
  13. You have no idea... that's not 1/5th of it...
  14. Looks like we made a mistake with the wiring. I have an updated PDF here with a correction for the plug pin out. Don't worry, as the circuit has reverse polarity protection if you hook it up the wrong way. readme-with-correct-polarity.pdf
  15. RB26s have crap rod to stroke ratio for what it's worth too, less than ideal for N/A. What's it's relevance in this conversation?
  16. Yeah maybe 40 years ago when it was new...
  17. You've probably already explained this, but why electric power steering? Packaging and ease right?
  18. Aaahh damn is google broken again!?!
  19. Hey Tom, can you post some pics on how your front lip is mounted to the lower half of your g-nose please?
  20. My 89mm block is grout filled, 3.35L with the RB30 crank and used on the street too fwiw.
  21. They just look S5 Mikuni 44s to me?
  22. This link should prove very informative in answering your questions: http://lmgtfy.com/?q=how+to+turbo+an+L28 I know it's really tough to find information on this as they are such a new engine and turbocharging them is relatively uncommon.
  23. Interested to see how well the fender vents work. What about cutting the back out of the flare?
