d3c0y
Everything posted by d3c0y
  1. So using circuit #3 from the first link you posted will work for what you want to do, although you will have to get the tools to write the code to the chip, which isn't that hard or expensive if you can use a computer for more than just browsing the web. This circuit has 4 outputs for driving LEDs as indicators which can definitely be made to trigger two solenoids and lockup torque converter if you have one. You wouldn't need the 120 ohm resistors as shown in the diagram. Then for the gear indicator i would simply hook the ebay indicator setup up to the same switches that you are using to trigger the gear change and be done. If you were worried about packaging and you wanted it to be super slick, you could combine the driver IC from circuit #2 to drive the 7 segment display on the same board. Here is an article on how the 7 Segment display works and shows you what is going to be output from the ebay indicator box: http://www.electronics-tutorials.ws/blog/7-segment-display-tutorial.html Every time the gear switch is triggered it either increments or decrements a counter in the microprocessor and the code built into it drives the different segment outputs as per the above article. You could use an IC like the one below with AND gates to drive the solenoids based on the output to the display, but obviously not the best way to do it, given the much better solution above. I was recently thinking of building this exact setup for my Soarer 24 Hours of Lemons car which has an auto to give it paddle shift for lols but have an RPM requirement for being able to lock the converter.
  2. So you are trying to shift the gearbox through this system right? You haven't posted the most important thing which is how the gearbox is shifted. Do you need to fire multiple solenoids in a specific order? Driving the gear display off it won't be that hard.
  3. You are going the wrong way, Too lean causes the popping and you probably leaned the mixtures out by fitting a freer flowing exhaust. Then you made it even leaner with the mixture screws.
  4. Not if you have to fit the adjuster knob each time you want to change the setting. Mine are permanently mounted and can be accessed by simply turning the wheels as they are external to the strut.
  5. The display comes with magnetic pickups and it already has a driver so you don't need the circuit that you linked first. How do you put your transmission in neutral? Are you using a stick or paddle shifters?
  6. Just get them to send you a set of inverted fronts with adjuster extensions. If anything they are a slightly better design, but just require greasing periodically and it's easy to install the extensions.
  7. First off i'm talking about natural aspiration and peak performance. I thought it is all about creating a smooth transition from the required throttle plate size to the back of the valve and accelerating the air into the chamber regardless of how the air is getting mixed with the fuel. Usually throttle bodies are really short so it's not a big deal, where as these are long. Could be wrong though.
  8. I'm going to have tons of droop with my setup i'll be like 40/60 bump/droop. As long as my aero doesn't touch the ground too hard it should be ok.
  9. They look interesting, I wonder if they are taper bore and available in bigger sizes? Just looking at them the quality of the machining would be my worry, but i'm sure this is exactly what you are thinking hence the thread. At least having a fuel injector means you dont have to rely on the quality of ITB to control the fuel. Might be one of those suck it and see things? Please post your findings
  10. Compression/Pin height is 38.10mm Check out the program i attached, if you are looking for engine info it's pretty good, although it's known that a couple of the calcs are out on extreme combos. lengine.zip
  11. Any reason the inlet area is so big? Is the cooling with the RB marginal?
  12. But you should adjust the ride height with the spring adjustment, but I'm sure that MCA would have told you that. So the only scenario i can picture is that your struts are too short and your springs are really stiff so you don't get any droop?Depending on how far off you are, you could make up some thicker top mounts to effectively lengthen the struts. Think about how thick the factory strut top insulators are. Either way, for the Z31 you know the travel of your shock and you know your target bump/droop ratios so these are all static numbers, you just need to add them up. Then if you are still worried put a bit more length in to give you more adjust-ability. I honestly don't think the stock measurements matter at all, you just need to know where you want it to end up.
  13. I just tig welded my frames together FWIW.
  14. I went with 6kg front and 5kg rear then, which is 340lb and 275lb. The blue strut isn't mine, we got three sets made at once, i just didn't have a pic without brakes getting in the way.
  15. You don't need the heavy stuff in it to work out what your strut lengths are. I didn't realise that you already had the suspension, i didn't read your earlier post properly sorry. I don't think not going low enough will be a problem either. I looked back to my emails with Josh and the coilovers in the photo can make an S30 so low that the engine cross-member is about 30mm off the ground on their shortest setting with the setup in the photos. This is how i see it: A) Get the fully compressed length: 1. Get your factory suspension, take the springs out and mount it back in the car 2. Attach wheel and tyre combo you are running 3. Jack the wheel up as far as you can go 4. If the strut fully compressed still isn't low enough (for your full bump length), just measure the distance to the closest fouling point. B) Get approximate ride height (ideal length) by lowering the wheel until your arms are flat C) Take into account the fact that you aren't going to be running factory insulators on the top and adjust measurements for the pillow ball strut top. Your strut will need to yield you at least 50mm of bump travel + bump stop 15mm for a racecar with stiff springs. Then you have the lengths you need the shock to be, just take out your new shock length from them and the remaining length, plus about 60mm of overlap for strength and adjustability, is the length to make the threaded tubes, or if you add it all up the new assembled length. Ya dig? Also I'm interested to know what the problem with your 280ZX's ride height is with the three way shocks? Was it too low? My experience is once your strut length is optimised, there is no real point in changing it. Ride height is another story but that generally comes down to how much total travel your shock has more than anything else. I love this suspension stuff, I find it really interesting.
  16. Race car above with history is a whole other ball game...
  17. They certainly do and it's what i have in my car. They even modified my original struts to suit. I thought i would have the strut length issues, but i don't i have tons of room from the shock to the bottom of the strut tube, to the point that i have adjuster extensions coming out the bottom of the strut as i'm using inverted mono-tubes on the front.
  18. I went through this with MCA when I did my coilover setup. For optimal performance you want your control arms parallel to the ground, or as close as you can get them; that is what Murray Coote told me anyway. You might not be able to get it that low, like in the case of an S30 where flat rear arms is really damn low. Have no idea about setup for trailing arms at all though, sorry. If you are going to run a cut strut with threaded tube welded on and a modern coilover on the front, you just get the shortest strut you can. The MCA struts ended up being plenty short enough in my application to the point that I was lengthening them to get the correct compressed length. For a race setup you only need about 60mm of bump travel and that leaves plenty of room for droop (80mm ish from memory). The old MCA site had a great article talking about what sort of travel you needed in both directions, but i don't seem to be able to find it anymore. Yes, I'm an MCA fan boy and if you buy their shocks, (which you should) Josh and Murray are more than happy to discuss setup over the phone to point you in the right direction.
  19. I'm surprised too, however you cast your mind back to when Alex's (Edward Lees) red Fairlady Z sold for $35k, that really kicked this whole thing off for zeds in Australia. I think auction prices tend to be a bit over the top and people like to make a statement with "record prices" so I don't feel it's an apples vs apples with private sales. Let's be honest the early 80s was the end of anything worth being considered a classic and the Rx7 was the last of the good batch for Japan. Who knows though, maybe we are going to be paying $50k for MA70 supras and Z31s in the future?
  20. Moustache bar depends on the diff you have, R200 or R180.
  21. Well that's a bit selfish, what about us people with high performance motors! Are you going to put a 100L tank in or just have a weird inaccurate fuel gauge? Regardless of the ignition system you use the tacho will still not be great.
  22. What about tacho accuracy? I'm interested in this but i need an accurate tacho at high RPM which the factory unit is not. Any thoughts? Could you put this face on a speed hut gauge?
  23. Sorry I've misused the the HS30 code by lumping the plain S30 models in with them. What I really meant was that maybe it's a pre-MY74 thing, and/or that no export markets received the spreader plates. I wonder if there are any HLS-30 cars in that have these? I would think that's not the case, as this is the first I have seen of them.
  24. I'm assuming this is a factory cost saving option and if you think about it, it was probably an easier option if a dealer wanted to fit in Aus. Sine we didnt get different specs like Japan it would be easier than ordering them from the factory like that.
  25. That's the old supply and demand thing right there though. I've seen 280ZX two seaters regularly on both of my trips to the US.
