3,086 -
25
Everything posted by d3c0y
I've developed the setup a bit more Jeff, and I'm going for 2:30 flat! If any of us are on together we should start an online game and do some zed racing.
I have these seats and for some reason they are really uncomfortable, so I'm interested to see how you go with this.
I think increasing the angle of the extension will have a better effect than extending it further. I hypothesise that the making it much taller than it is will only increase drag. I also think extending your diffuser strakes down at the back so they are lower if possible and putting L shapes on the bottom (vortex generators) will help increase it's efficiency and intern make it generate more downforce. L shaped strakes: First off usual disclaimer, I am no aero expert, but I enjoy talking about this stuff and when i get the chance will be playing around with it in a similar fashion on a few different cars. I agree with the theory of changing the airflow with the new spoiler could be helping/interacting with the diffuser. I disagree that it's the same effect that's happening on an F1 car though. On the F1 car, I believe that the acceleration of air over the low pressure side (bottom) of the aerofoil is causing a "sucking" effect if you position it close enough to the diffuser exit (low down and rearward as possible) it multiplies its effect. In this case, I think it's more to do with cleaning up the way the air comes off the back of the car. The original Z-G/432 wing reduces drag, just like the tiny "track" wing on the back of a 350Z which in return reduces rear lift (and in turn a better CD number). As we aren't dealing with an aerofoil, I think that a gurney flap is not really what you want when you can just angle the extension right up. My guess is that without the rear spoiler, the air coming off the back of the car is blocking the diffuser exit which would have obvious knock on effect. Obviously an optimum height for this spoiler, which I think is very close to the height of the factory type 2 kit, 3 piece spoiler, which with Gordo's extension, i'm guessing is pretty close. If you look at the pic of Gordo's car, his spoiler is a different to the factory type-2 3 piece spoiler which has a lot more rake on it, which effects it's overall height too. Of all the old pics I have of race cars with decent aero, I only have one of a car running any extension on the aforementioned spoiler (Central 20 car) and there are other pictures of it without the extension too. By the mid 70s Nissan clearly cared about aero and was developing the zed shape as much as possible within whatever rules they had and were operating (from what I have read) at a similar HP level to Gordo's car. My point here is they probably had it developed to good standard. This car is obviously a US spec car that has to replicate the standard Z-G/BRE wing made and has added end fences and i'm guessing a little higher than a factory 3 piece but is obviously a different design. Of course I could be totally wrong too. Sorry for the hijack Gordo
Don't forget that parts manual shot is a RS30-H too, so they might have redesigned it for the later models? Thanks again for making the effort to photograph this stuff.
I have the copy produced by Restored Japan will be interesting to compare. Thanks for your effort! I just noticed that your bracket is different to the one in the parts manual photo at the top of the thread. I remember reading that there was a difference between the models with and without air conditioning and i'm guessing yours is the latter?
That's awesome thanks Alan! It does look super easy to fabricate. So inside the nose does it have two studs moulded into it to mount this on, or are there just two bolts that go through both pieces?
For the record i understood Cassette Deck and i'm "only" 34.
We don't even need to know the holes, as it will have to be changed for Aussie plates ha.
I saw this one over on Kat's thread on classicZcars.com which is at least a starting point, and a proper JDM one would be no good because of the whole spacing but it would be nice to have some pics for reference to fab an "Aus Spec" one up from for my car. I'm hoping to take it for it's first drive so number plates are now some what of a relevant priority!
Does anyone here have any pictures on how you are supposed to mount the front number plate on a 240ZG? I know I could just fab up any old thing, but i'm interested to see how it was done from the factory and how others have done this.
They are just trying to do their own take on the Singer 911 by the look. I think if you want a full house restoration with a big hp stroker AND get someone else to do all the work, the money sounds about right to me. RockyAuto have been doing this for decades and charging this money. I think you need to re-read the ad, it's not even for one specific car.
I have brand new OEM screws to put your quarter windows back in with if you are interested.
I don't know why i bother replying but anyway: Is this still a problem? Did you replace the fuel filter right now? Did you check the fuel pressure right now? In your idle thread you said it runs fine on the highway is this not the case now? If the choke fixed this, you added more fuel, which means your are running lean, which is what we have said all along. If this is the case you need to richen the carbs. After you have performed/answered the above questions, you need to go through this guide step by step and purchase some sort of airflow meter for your carbs: https://www.z-car.com/blog/cars/tuning-su-carburetors If you can't get it right after following the guide, the way i see it is you have two choices: Take it to a mechanic run it on a dyno and get them to set your mixtures Return carbs to original settings and refit the exhaust it ran fine with and move on with your life. Now this is the most important step of all, don't start a new thread until you have posted before until everything above has been completed. Good luck.
I got - "I ZED I" for $475
It's actually pretty easy to fix, the hardest bit is getting the filler neck on and off the tank. I had to heat mine up with a butane torch to get it back on.
The lap above I did in the 240ZR 2:30.759 is my fastest so far. There is more in it. Are you on PC?
Are you going to make a takeover bid for ausrotary.com?
You need to head to a dyno with those stacks. I'm so curious to see if they work!
