d3c0y
Everything posted by d3c0y
  1. Well you don't have to be dumb about it. I do track days and if you are up in the hills you can still go fast without big numbers in a relative sense. Haha yeah I know that one, I used to do track days with the local BMW club
  2. That's very presumptuous of you in this case then isn't it! So i'm guessing when you are slower than a faster car you always say "ok that guy is just better than me" not "if i had more horsepower...." hahaha Look at that Rx7, oozing purity of the linage. Can't say the same for the dumpy youngest sister of the MX-5 line, it's even got traction control! The NA would be ashamed of it...
  3. I would call turn 1 at QR pretty high speed too. In the lemons soarer and the 350Z it was around 150kph so your race car should be doing better than that. I wouldn't be relying on the squeal more than the feel.
  4. I don't know what you mean when you say purity of the line. Do you mean the latter models stayed true to the original concept? I think the Rx7 stayed very true to it's original design concept from the SA22C (1978) right through to the 2002 FD3S. You can see the design evolution and the FD is still very much a no-frills sports car with the later models only weighing in at just over 1200kg. They even removed the instrument cluster dimmer in the later models as it was superfluous lol. Have you driven any model of Rx7? That's what all the people with slow cars say. Why can't you drive the fast car fast?
  5. If you are going to this much effort, why not go just test at a high-speed track if you are worried about the high-speed handling? I don't think using a cheaper tyre will make that much difference in terms of masking issues and going one step down on an excellent tyre isn't a massive change. A less grippy tyre can't simulate high g-loading either. Why aren't you just running slicks on this thing? Is it a regulation that you have to run street legal tyres? Slicks are generally cheaper than Semis too.
  6. I've got one too. 450rwhp on 15psi and haven't switched it to the corn juice yet. It was spinning the tyres in third on the throttle getting the boost controller dialed in. Absolute 0 want for an MX-5. Gilltech I'm worried for you.
  7. Yes run flat tops, yes run a bigger cam. There done, next question. But seriously, as Gav said it depends what's been done to the head. Personally I would flat tops in regardless if you want any sort of performance going forward.
  8. But isn't the point moot from PZG's post above highlighting how the MCAs aren't cheap chinese shit? The blues even work out to be around the same price as the Feal setup. I have a car with Tein Flex and two with MCA blue and XR (both S30s) and even the Teins aren't as good from face value (I haven't had a chance to drive my RX7 since i had the Teins rebuilt, but 40mm high bump stops that don't compress aren't a good start on a shock with 100mm of travel) .
  9. This is exactly why I do as much work myself as possible. I can't stand paying good money to people to do shit work. At least if you stuff it up yourself you know who is to blame.
  10. Also who is using the H-pattern gear shifter when they are doing their lap? That would have to slow you down a second or so....
  11. One hour a day!? Sweet jesus, wish i had that much free time! Do any of you have going zeds?
  12. I feel the urge to go home and try it now, damn work getting in the way!
  13. I have been out of this thread for a while now, but i can't believe i'm pretty much out of the top 10 now. I watched your video driving the stock setup and I'm blown away. On my time doing a 1:30 i have the thing crossed up and sliding everywhere and teetering on the edge of disaster at most corners. You look like you are on rails in comparison to the point if the dash was turned off i would say you were driving a different car. Not to take anything away from your laps, but maybe the stock setup has been improved in one of the updates over the past couple of months because as mentioned a few months back the standard car was borderline un-drivable on PC!
  14. That Hako is hot.
  15. I don't think it's just the mechanical advantage. When you are using paddle shifters, you don't have to think about changing gears. That frees you up to concentrate on driving and because it shifts so fast you can sometimes use an extra gear; i.e. more likely to put it in first than with an H-pattern manual. I feel this thread is kind of stating the obvious though unless it's not about "shifting gears faster makes you faster"? Also i have an auto in my Lemons Soarer race car and it's definitely slower around a track than an H-pattern manual, by absolute shed loads. "So flat shift manual or else get an auto" doesn't stand up at all. The more I type the more I feel this thread is pointless.
  16. You can just cut the auto pedal, they are the same apart from the foot plate.
  17. Are those paddle shifted transmissions really "autos" with a torque converter though or automated manuals? One of these things is not like the other.
  18. Pretty sure this is a mechanical 1.5 way. That's the one I had when i was doing this conversion. The late model wagon shape ones come with a 3.54 and that's the only Torsen I know of.
  19. No problem, what year and spec STi diffs are you looking at? Do you know the ratios and the centers they come with?
  20. The ones that were snapping were the stubs supplied Wolf Creek Racing, but the owner of Wolf Creek Racing is no longer alive. I was talking to a guy John Williams on Facebook who apparently supplied WCR with the stubs, and told me that in later batches made WCR made him cut the price, which in turn lowered the quality (against his advice) that resulted in them failing. He was even nice enough to send me a two pairs free of charge from the states, as a make good for WCR which he definitely didn't need to do. He works in aerospace and makes the stubs himself in the states and are $300USD a pair which is a bargain (WCR used to sell them for $550). You can contact him at Wmi73@verizon.net or on facebook: https://www.facebook.com/profile.php?id=1691345565 Just remember you need to use an STi diff as the regular WRX just has an R160 and even then the STi has 3 different ratios and 3 different diff centers.
  21. Great thanks for that, I'll see what i can come up with
  22. To be honest i need the measurements more than anything, because then i can draw it myself. If you click the "More Reply Options" button in the bottom right, you can then just attach files.
  23. Any reason you need that box? Kind of a hard expensive option, when there are much easier and cheaper choices?
  24. I can't vouch for the order of the three hoses coming from the back but the rest of it looks right. Do you have a filter before your pump?
  25. Nope nothing! No rush but if you can dig it out one weekend that would be great.
