d3c0y
Everything posted by d3c0y
  1. Hi Guys, It seems that the guy that was plating my parts has lost the roller and pin from my lower door hinge which is getting in the way of my car having doors. If you have a door hinge in parts or a whole hinge I'll take it! It won't matter which side it's for or what model car.
  2. Doug's got an R34 GT-T with 600rwhp on a stock RB25DET NEO as you have seen on Facebook. These motors can do it but his car is far from daily status. You also don't have any expectations for the Jimmy to be fast so it's kind of different. You seem set on the idea of buying one and aware of its downfalls, so I don't know what else someone can impart on you?
  3. I have a 240K steering wheel if you are interested.
  4. d3c0y
    FS5W71B bellhouse
    Hey Kent, if you are still looking for a bell housing I have one.
  5. Same reason you are missing some marbles, they just got lost over time. A couple of studs and an intake manifold (throttle body assemblies?) aren't a big deal.
  6. Oh and you will want to check the front drive shaft unis have been done at this point too. Very common, and mine needed them replaced.
  7. I had a S1 RS FOUR for a little bit. I picked it up for like $2000 and I hated it. It was painfully slow feeling every bit of its 1600kgs and the cheap crappy coilovers really didn't help it out either. They are pretty old to have as a daily now too and feel every bit of it. These are more on par with R33 Series 2 Skyline than R34 too so don't get fooled by the 34 in the chassis code. It had the usual FMIC, exhaust, 12psi of boost and pod filter. I don't think an auto RB25DET (they are all auto unless it's been converted or a rare RS FOUR S) is a good motor for something that isn't a sports car/lighter weight sedan. An M35 with a VQ35 in it would be so much nicer to drive and they aren't even really any more expensive. Go drive a 260RS and see what you think of it, it's the only one of the WC34s I would consider, just because it's a special model.
  8. If it gives you any encouragement I just did a similar thing to my relocated battery in my Rx7. I just used an eBay clamp, rods and some aluminium brackets I made up, secured by 4 rivnuts.
  9. As someone that has been in this position, this is completely untrue and I would never spend $12k on carbs. When you get to the end of the build, I assure you that you are not looking for more ways to spend money on it. I picked up brand new DCO 50 Webers for $2200 delivered which give the same performance and 80% of the drivability of the Mikuni and put them on the same Harada big-port manifold. For the kind of money you are talking here, you could have a top of the line ITB setup with a good ECU and crank triggered ignition. I get that they are cool, but if you are just after the performance there are better and cheaper options.
  10. Got me on the old technicality -_-
  11. It's already been made by Ford controversially. Just needs a LibertyWalk kit to make it obvious! Flat front like a 240Z, recessed headlights, the taillight panel with 3 elements tail lights, it's all there. Shame it's not a 5.7L because they could have even called it a 350Z!
  12. d3c0y
    Vq35 in S30
    Yes there is a red one in NZ with flares that has a VQ. They even sell a kit for it in america. http://hokeperformance.squarespace.com/project-vehicles/
  13. d3c0y
    tripples
    It's fine, but only if your spelling is right when you put on.
  14. 3.36 is crap ratio not worth the effort. At the end of the day all R180s have 180mm crown wheel so not really any stronger than a standard one. For any decent turbo you want an R200.
  15. Did you read this: https://www.qld.gov.au/transport/licensing/driver-licensing/applying/provisional/restrictions It's pretty clear on what you need to prove to get an exemption. So really I was right, unless you make up some bullshit which is probably what your mates did.
  16. I told you a series 3 was illegal in your other thread. You can't get an exemption for it, that's just for turbos that have a low kw/ton rating.
  17. It's only been 2 years...
  18. This is a terrible option. Would you really have a 260Z 2+2 as your daily Gav? Or any S30 for that matter? They are just too old to be a sensible choice for anything other than a weekend car these days.
  19. I doubt any of those cars are better on fuel and they are all turbo which you can't have on your Ps in QLD right?
  20. If you can't afford 98 octane fuel, buy a corolla mate. I'm not being harsh, but if $10 a tank makes the difference you can't afford a sports car.
  21. I have owned series 1 and series 3 350Zs and they are actually good on fuel. You will need to put 98 premium unleaded in them though which is pretty expensive these days. I think for the money you will be hard pressed to get a better first sports car that is p-plate legal.
  22. So you are saying SUs are better than badly setup Webers?
  23. Oh yeah try these guys: https://www.facebook.com/wheelrevolution/ They put new lips on some 3 piece wheels for me.
  24. Must be a sweet set of wheels? What are they?
  25. I used -10 braided 200 series aeroflow hose, fits well.
