3,086 -
25
Everything posted by d3c0y
You can upgrade to a skyline/Z32 unit if you are happy to drill some new holes.
Post to brisbane?
If it wasn't 180 degrees there would no be tension on the hinges in the open position... Assemble the rods and hinges off the car, yes on side will be upside down. You can leave the top button part of the rod disconnected on one side if you want to make it easier to twist Get wife to hold one side together while you bolt the side that's the right way up to the car. go to the other side, thank wife, twist hinge assembly 180 degrees towards the rear of the car Use a tool of your choice to pull the other rod into the tab. Congratulate yourself You can if you want but Brisbane is a fairly decent drive with no bonnet.
I just went through this recently too and i'm trying to remember what I did. But basically you assemble it off the car and if the front of the hinge is on your left spin it to the right after one side is bolted in the car like Retro Z said. Just make it look like my photo if you do it the other way it doesn't look right.
Either way that is a fantastic video. I love it at the start where the camera basically goes inside the tailpipe of the car in front. How does one acquire this software so i can put my zed geometry through it just for fun? I've never thought of the resultant effects of body roll in this way and is very interesting. Do you have a pick of this i'm not following.
They aren't going to take off either. Just because it's old and has a Datsun badge doesn't make it a classic. The only reason 240Ks ever got anywhere was the whole GTR replica thing. C210s were an excellent source of electronic distributors back when they were still in the wreckers.
Come on rookie, you know we want pictures of these simulations. Words are so 1991.
For what it's worth, I read that the different JDM models had different coloured Z's on the horn pad. The 432 had red: http://www.classiczcars.com/topic/23900-datsun-240z-vs-fairlady-z432/?do=findComment&comment=488204
It's not exactly a quality 800 any more though is it... It's basically just a downshift meet now, with some nice classics as the minority.
Doug doesn't go anywhere without his custom dick hat now. Apparently it's all about the fitment?
I'm keen on doing chassis bracing on my car, however i'm kind of at the point where i'm in get it done mode. It seems like a waste to not do it now, while it's apart but I guess there is always room for future development. There is a crossmember under there for the diff already, how much extra stiffness will this achieve and are you going to tie it into the rear diff mounts? Wouldnt it be more effective on the sides of the chassis rail and give you more ground clearence?
So much time... funny to see those CVs in their original home.
Wow the marketing is so good this is the first i've heard of it.
I still go to CNJ motorsport in underwood. Always had a good no bullshit service there.
I've been doing some suspension work recently, to get some bits back in the car and in the process, clear off the work bench. Disks, hubs, bearings, lower struts, and calipers for both ends of the car spread out a lot when they are all separated. So to start the reassembly process, I needed to perform a modification to the lower strut that I had been putting off; not that every modification remaining to do to the car doesn't fall into that category at this point. The coilover setup I used has an inverted mono-tube damper for the front, which when modifying old struts that have the knuckle on the bottom means you end up with the problem of your adjuster knob being inside the tube. This proved to be a massive pain in ass for tweaking the suspension setup another 240Z we built (red one for those who follow SMG) so for the 240Z-G I did some research on the best way to address this. Front shock is far left, the other two are the rears. The trick to making easy adjustments is to use shock adjust extensions, which is basically a cable that is secured to the standard adjuster with an allen screw in a cap that fits over the top. It sounds a bit crazy, but talking to people in the suspension know, it's fine to drill a hole in the side of the strut to route the cable through and it doesn't affect the strength of the strut at all. Some coilovers have large windows cut in the side of the strut big enough to get your finds inside to access the adjuster without even using an extension. The next consideration when making this modification, is to get the hole low enough in the strut so the metal cable can make a gentle radius inside and have enough room to wind the shock down in the strut to get your optimal strut length. The cable can't do a 90 degree turn inside the space of the strut either, so drilling the hole on a 45 degree angle down helped this a lot. You will need to make sure your pilot holes are drilled as close to this angle as you can, as in the case of the 240Z the bottom is very thick and just levering the drill up and down won't get the desired result. My hole was close but I did snap a 10mm drill bit trying to relieve the hole a bit more on the first one finding the right angle. So we finally get to the end product of adjustable shocks again! I really like the size of the damper in a McPherson strut setup like the zed and with a small amount of work you can have the best of both worlds!
Hey Jeff i'm interested in what spring rates you went with on your setup?
d3c0y replied to XRQTR's topic in Parts and Tools for Sale
Why does everyone insist on running 7" cheese cutters on the front? -
I've got 275lbs in the rear of mine, not that I've tried it yet.
I think maybe US buyers with this kind of money, just don't value these kinds of cars and there was a bit of a spike when they were a "new" thing to the market. I think that is fair enough too, as they are very niche cars. We just happen to be be very niche enthusiasts that like them. They aren't (in the foreseeable future) going to have the appeal of the stalwart euro marques like Ferrari, but look how far they have come in being brought out of total obscurity in terms of the US market.
The PMU dealer i talked to said they are a very similar compound to the absolutely fabulous H16-03 which I have used. The main difference is the amount of laps the RC-09 can take the punishment for. If you are doing 10 lap sprints they should be good.
Not at all with those sizes i had 16x8 +4 with a 225/50 on a 240Z.
That's the Jaycar box with some bits screwed too it. Nice work turned out very similar. Did he just make a few for you?
Man that thing with the chopped roof is thoroughly ruined...
Sounds like something you would do hahah. -
Subaru Sti R180 4.44 Mechanical Lsd Bolt In Package
d3c0y replied to d3c0y's topic in Parts and Tools for Sale
Bump
