3,086 -
25
Everything posted by d3c0y
Yeah i saw thanks, i'm an idiot though i bought a new box to send yours while i was there but forgot to take the bits!
OK all of the round one customers have been sent out. We still have 6 made up if anyone wants to buy.
MCA did it for what i thought was a very reasonable price. I just got the blues (even though the bits are red) and will have them re-valve it when the package is together and can be tested.
Rear brakes are done! I've really enjoyed doing something different with the brakes and not just following the mod your 240Z by numbers approach. BHSS in Capalaba have done all the fab work and Johnny there is an ex240z owner and have been great to work with. The setup we landed on uses the rear Boxster 986 calipers to match the front. While they look the same these have smaller pistons and pads. A VS/VZ HSV rear rotor was bang on for offset, thickness and centre hole, so only required the 4x114.3 PCD drilling to fit and they are cheap at $100ea in an RDA. BHSS said they prefer to buy plain rotors and slot them opposed to the off the shelf RDA slotted as they make the slots too wide and dont offset them on the faces of the rotor so they are noisy and cause vibration, which I can attest to having had those rotors on my 350Z and XR6 ute previously. Here are the numbers for those who care: 986 Boxster weight: 1280kg 240Z weight: 1050kg Non 'S': F Disc 298mm x 24mm, Pistons in Calipers 2x40,2x36 mm , pad area 216 cm^2 R Disc 292mm x 20mm, Pistons in Calipers 2x30,2x28 mm , pad area 196 cm^2 "S/996 Carrera": F Disc 319mm x 28mm, Pistons in Calipers 2x40,2x36 mm, pad area 254 cm^2 R Disc 299mm x 22mm, Pistons in Calipers 2x30,2x28 mm, pad area 196 cm^2 "240Z" F Disc 323mm x 24mm (RX-8 Sport), Pistons in Calipers 2x40,2x36 mm , pad area 216 cm^2 R Disc 315mm x 18mm (HSV), Pistons in Calipers 2x30,2x28 mm , pad area 196 cm^2 My friend went a different route with his 260Z and got all new gear from one of those China/Taiwanese brands, Ceika to be specific. The cost has turned out to be pretty much the same, his brakes are bigger 6 piston calipers with 335mm front rotors, but heavier components, brackets etc. However, he is still trying to deal with some guy overseas to get parts changed that don't quite fit (probably a bit his fault as he left it so long to get back to the guy). I think that using Australian based suppliers for this kind of custom is definitely the right way to go and is the reason I ended up with MCA doing the suspension. I actually looked into Ceika doing a custom suspension setup as it was really really cheap, but the lack of communication and trying to relay details over email did my head in and promptly got him to refund the money. Just my observations from having done this sort of stuff for the first time and obviously nothing new here, but you can beat being able to pick up the phone or go and see the guys with the parts.
Proof is in the pudding I guess. Really at the end of the day it comes down to the fact what of what does it need to be better than? Even if they are 1/10th slower than the Ohlins but half the price who cares? I'm sure they will be great. One thing I realised when doing sprints with my 350Z was that I could have spent a million dollars modifying it or just try and get the best possible time I could from the stock setup. All that changed would change was the lap time on the print out.
Yeah it's supposed to look like a zero, it has some bullet holes to come. Just picked up a big rear wing and splitter for the front of it too.
BHSS have talked me out of a two piece rotor initially for the rear, as it will only save around 200g a side and the HSV disks are like $100ea which is a welcome saving when the caliper brackets are so expensive. I would like a two piece on the back for bragging rights, so i'll change them over when they come up for the right price, which is how i got the fronts. Another advantage of the two piece is not putting heat into your wheel bearings which again is less of an issue in the rear with such big brakes for the size. The handbrake comes down to the fact that EVERYONE says they suck. The Brembos are used by lots of OEMs, but I just don't want to spend $1000+ mounting and cable mods to fit them when there are other areas that need the money more to get the car drivable.
I like to try and be mindful of the weight of the parts I put on my cars and I had a stack of wheels in the garage so I weighed them for interest's sake. Enkie GTC-01 19x10 with 225/35/19 Koya 18x8 with 235/40/18 Linea Sport 17x9 with 235/45/17 Watanabe R-Type 16x9.5 with 245/45/16 Enkies are going on the Rx-7 as the street wheels (with more sensible tyres). I want to find a set of 17x9 and 17x10s for the track. Watanabes for the 240Z obviously.
After pretty much getting the drive line sorted, I decided that I didn't want to potentially destroy a perfectly good R180 LSD. Talking to some of the old hands in the Datsun business, it looked like using an R180 with the L34 on the track and at the drags, that it would only be a matter of time before it broke. On top of that horror stories of uni half shafts braking I chickened out my light weight diff idea. Fortunately a mechanical 4.375 R200 came up for sale with CV shafts from an HR31 Skyline for a reasonable price so i jumped on it. Not having looked into the R200 & CV conversion much I was unpleasantly surprised that it was typical Datsun bolt in modification of having to custom make parts and change everything. For anyone that hasn't done it, you need 27 spline 260Z/280Z stub axles, custom made companion flanges to bolt on to the outter CVs and shorter axles in between the CVs, particularly as it will be a low car with adjustable lower arms, that if anything will probably be adjusted inwards. For what it's worth, doing this conversion in Australia could easily set you back $3k depending on what you pay for the second hand parts! I have also pulled out a rear strut and taken it into BHSS who helped me out with the front caliper adapters. I'm using the rear calipers off a Boxster on the back of the Z to match the front and at this point it looks like an HSV rear rotor is pretty close in the measurements we require and a decent diameter with a skinny width at 315mm x 18mm. I should have this back in the next week or so with caliper mounted ready to go back in the car for some pictures. Many hours were spent looking into a hand brake setup, but it all ended up being either too expensive or not working well enough. In the end both Doug and I have decided we are going to run a hydraulic handbrake from Stewart Wilkins Motorsport in this and the purple car. I know it's not legal, but the car isn't going to be parked on a hill somewhere for any amount of time and its not going to cost $1000 like a pair of Brembo handbrake calipers (which were the other option). We should be able to hide the master cylinder pretty well beside the seat and the custom plumbing will integrate a brake pressure adjustment valve under the driver's seat. It was also great to see the panel beater had managed to get overspray all over my new suspension and drive train parts... Complete R180 LSD setup is for sale for $2000 if anyone is interested: Mechanical 4.444 R180 LSD with fresh oil Brand new solid uni axles Plug in Subi diff stubs R180 Mustache bar with brand new bushes
Everyone has been PM'd so i'll try and send out as many as i can this weekend. Please get your addresses in! To anyone still looking we made extras, so it's not to late to order!
I've got the Restored ones from Otomoto, very nice product, reasonable price.
People were saying that 5 - 10 years ago too.
OK excellent they are the answers i was seeking thank you.
So is the R32GTR axle the same spline count as the Z31? Did they literally just cut the axle in half and join it back together because the axle tapers down after the splines? Why not just shorten the Z31 axles if that is the case? Did you upgrade to 27 spline 260Z stub axles? What did your adapters set you back?
What's involved in the shortened R32 GTR axles and how much does it cost? I have the Z31 CVs and have been looking into this and so far the only option i have come up with is billet axles from SWM for $1200! What companion flanges are you using?
I just did a quick google and that seems to be an american thing F54 with P79 head had flat tops. I thought P90/F54 was available in Patrols at some stage. Probably wrong about that too.
They are the regular ones. To answer your original question the P90 heads generally came with flat tops as the combustion chambers are bigger and had a lower compression ratio. It will be fine with twin SUs and will make about the same as any stock L28 depending on the condition.
Any pics of the finished products?
Hey guys, quick update. I have the circuits built and sitting on my desk ready to post out along with the plugs. We ended up soldering some wire tails to the PCB so all you have to do is crimp the pins for the connectors on. If everyone can PM their address details, i'll take payments and start shipping these bad boys out. Sorry for the delay, I've had a lot on.
I have a Stagea RS Four you can have for $6k then you can spend the rest on your zed!
I was there with the red flared one and saw your car there and wondered who's it was. Did you buy it with the Wats on it?
There you go, I stand corrected.
I'd be very surprised if it's a P90A - does it have hydraulic lifters?
I was running KU36s due to having to have something that had a treadwear rating worse than 180 so basically road car tyres for Lemons. Gordo were those 245s 45 17s by any chance? Our 255s seem to be fine with it but went through 3 pairs of 245s and they all did the same thing... Grip from them isn't a patch on a semi, but i dont think they are marketed as such either.
They aren't hard on the rotors at all in my opinion. Raced for 16 hours and the rotors were still in roadworthy condition. Could have done another days racing if you wanted and they were just DBA T3s. It wasn't a problem with the pads, it was a combination of a faulty set of KU36 tyres that made the ABS favor one of the brakes (front left at wakefield) and it simply ran out of pad on one side and the pistons fell out of the caliper. The pads on the right hand side were fine. The tyre carcass failure caused a heap of problems and we didn't figure it out until the next round at QR. It was only our second time running the car at QR so the first time at Wakefield we didnt know what was normal. The pic of the tyre is after about 10 minutes of racing.
