geoffdy Posted April 20, 2017 Share Posted April 20, 2017 (edited) Some new 260z 2+2 measurements.. Front: 16x8 +8 with 205/55 (Sit about 5mm from the spring perch) Rear: 16x8.5 +12 with 225/50 (plenty of room either side) What suspension setup do you have? I'm planning to order toyo tires with the same size as yours but I want to lower my car a bit. Edited April 20, 2017 by geoffdy Quote Link to comment Share on other sites More sharing options...
Dionysus Posted April 20, 2017 Share Posted April 20, 2017 What suspension setup do you have? I'm planning to order toyo tires with the same size as yours but I want to lower my car a bit.Car is lowered with aftermarket Springs and does not rub. Depends on what wheel offset you're going. Quote Link to comment Share on other sites More sharing options...
OdinZ Posted April 5, 2018 Share Posted April 5, 2018 does anyone have fitted currently or in the past, 15 x 6.5JJ +17? I'm curious how the positive offset might sit, and if i will have issues. my 2+2 is currently on standard suspension, but will eventually be lowered somewhat Quote Link to comment Share on other sites More sharing options...
gerrardq Posted August 2, 2018 Share Posted August 2, 2018 Hi all, Have just read this entire thread, I am more confused than how I started, I have a 260 2+2, I would like to run flares, Is there a wheel offset/size that in the members opinion works best? Thanks in advance, Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted August 2, 2018 Administrators Share Posted August 2, 2018 Try watching this, as it might help. 3:49 seconds. I tried to restore the images Sulio attached in the first post here, but they are gone and I cannot recover them. Would be great if someone could supply images and I can fix the first post of this thread. Quote Link to comment Share on other sites More sharing options...
peter t Posted August 17, 2018 Share Posted August 17, 2018 A handy reference. Quote Link to comment Share on other sites More sharing options...
peter t Posted August 17, 2018 Share Posted August 17, 2018 On 8/2/2018 at 2:22 PM, gerrardq said: Hi all, Have just read this entire thread, I am more confused than how I started, I have a 260 2+2, I would like to run flares, Is there a wheel offset/size that in the members opinion works best? Thanks in advance, I have a 2+2 and running 15x8 -6 front and rear with 225/50/15 tyres. 1" lowered King springs and NO flares. OdinZ 1 Quote Link to comment Share on other sites More sharing options...
CBR Jeff Posted May 23, 2020 Share Posted May 23, 2020 (edited) This is a handy site if you want to look at different wheel tire combinations. https://www.wheel-size.com Jeff Edited May 23, 2020 by CBR Jeff Quote Link to comment Share on other sites More sharing options...
Millerman Posted August 21, 2020 Share Posted August 21, 2020 Www.rimtuck.com can look through it as thumbnails with specs or can simply view the setups in numbers For those who are more numbers inclined Quote Link to comment Share on other sites More sharing options...
54f-Jed-CQc-aLS Posted October 17, 2021 Share Posted October 17, 2021 So after reading all that I think that 15x9 with -10 offset will fit my stock 260z. Can someone tell me I am doing it right? Quote Link to comment Share on other sites More sharing options...
Agno Posted October 17, 2021 Share Posted October 17, 2021 No that will poke significantly out of the rear guards and will need either flares or a skinny tyre and a lot of camber to fit. 54f-Jed-CQc-aLS 1 Quote Link to comment Share on other sites More sharing options...
54f-Jed-CQc-aLS Posted October 18, 2021 Share Posted October 18, 2021 5 hours ago, Agno said: No that will poke significantly out of the rear guards and will need either flares or a skinny tyre and a lot of camber to fit. Thanks I am happy to go with flares and understood I should be ok at the back without having to cut. But will they fit on the front without rubbing and having to cut? Again happy to go with flares but don’t want to cut. Quote Link to comment Share on other sites More sharing options...
Agno Posted October 20, 2021 Share Posted October 20, 2021 On 10/18/2021 at 4:25 PM, 54f-Jed-CQc-aLS said: Thanks I am happy to go with flares and understood I should be ok at the back without having to cut. But will they fit on the front without rubbing and having to cut? Again happy to go with flares but don’t want to cut. If you don't cut your guards for flares you won't be able to run the car particularly low because the lip of the old guard will get in the way of the tyre. Quote Link to comment Share on other sites More sharing options...
