Hunter Posted April 13, 2010 Share Posted April 13, 2010 I have noticed there is a lot of confusion with tyres/rims under our zed cars and it is hard to sift through the information on this site to find your answers especially for new members. If you would Please share with the forum your tyre/rim combo and model car you have. Please follow the exact format as below (copy paste). No BS or comments. If you need to comment or ask questions please PM the person who posted the info. If you are unsure of any details just leave them blank. (If there is any info that should be in this list but is not PM me and I will add it into this post) Year/Model: 1973 240Z Suspension: Standard, Coilover, spring type, shock type etc. Body Modification: Bolt on flares with guards cut, rolled guards, etc. Comments: Front tyres rub on full lock, rear tyres scrub guards on bumps etc. Rim Brand: Rim Diameter: Rim Width: Rim Offset: Rim Price: Tyre Brand: Tyre Width: Tyre Profile: Tyre Price: Picture: use attach feature to keep pictures small in thread Quote Link to comment Share on other sites More sharing options...
NZeder Posted April 13, 2010 Share Posted April 13, 2010 Year/Model: 1971 240Z Suspension: Standard, lovell springs, koni red. Body Modification: rear fenders rolled in the past for larger setup but not required for this setup Comments: Clears perfect - test fitted to 260z stock suspension rims fowl on the front due to 260z lower spring purch Rim Brand:Arrow Wheels Rim Diameter:16 Rim Width:9 Rim Offset:-6 Rim Price:came with car Tyre Brand:Bridgstone Potenza S03 Tyre Width:225 Tyre Profile:45 Tyre Price:can't recall Quote Link to comment Share on other sites More sharing options...
NZeder Posted April 13, 2010 Share Posted April 13, 2010 Year/Model: 1971 240Z Suspension: Standard, lovell springs, koni red. Body Modification: rear fenders rolled in the past for larger setup but not required for this setup Comments: Clears perfect - test fitted to 260z stock suspension rims fowl on the front due to 260z lower spring purch Rim Brand:Rota RB-R Rim Diameter:16 Rim Width:8 Rim Offset:+10 Rim Price:$1100 NZD sometime ago Tyre Brand:Bridgstone Potenza S03 Tyre Width:225 Tyre Profile:45 Tyre Price:can't recall Quote Link to comment Share on other sites More sharing options...
NZeder Posted April 13, 2010 Share Posted April 13, 2010 Work in progress still Year/Model: 1976 260Z 2 seater Suspension: Sectioned struts (Spring purch in stock 260z location), lovell springs, koni yello adjustable. Body Modification: Custom steel flares and rear have new inner/tub Comments: Clears perfect no springs in pics and blocks of wood for fully compressed spring setup to check flare clearances Rim Brand:RS Watanabe R-Type Rim Diameter:16 Rim Width:8.5 Front, 9.5 Rear Rim Offset:-6 front, -19 rear Rim Price:much $$$( Tyre Brand:Toyo Proxes T1R Tyre Width:225 Front, 245 Rear Tyre Profile:50 Front, 45 Rear Tyre Price:under $1000 NZD back then Quote Link to comment Share on other sites More sharing options...
Moderators Zedman240® Posted April 13, 2010 Moderators Share Posted April 13, 2010 Year/Model: 1970 240Z Suspension: Standard, Heavier springs (280/300lb) Koni Yellows Body Modification: rolled guards. Comments: Just lower from standard height; yet to hear any rubbing. Rim Brand:Performance Superlite Rim Diameter: 16" Rim Width: 8" Rim Offset: +4? Rim Price: $231 each Tyre Brand: Dunlop DO1J Tyre Width: 225 Tyre Profile: 50 Tyre Price: $100 S/H Picture coming soon! Quote Link to comment Share on other sites More sharing options...
herrods Posted April 13, 2010 Share Posted April 13, 2010 Year/Model: 1974 260Z Suspension: Tokiko Illumina Damper adjustable, Tokico Illumina Spring Body Modification: Standard Comments: Extreme cornering with 2 people + a bump mid corner = scrub on the rear, no other time. Rim Brand: Konig Rewind (watanabe lookalike) Rim Diameter: 16" Rim Width: 7" Rim Offset: 0 i think..? Rim Price: 1400 w tyres i believe Tyre Brand: Federal .... Tyre Width: 225 Tyre Profile:45 Tyre Price: came with rims havent swapped them yet Quote Link to comment Share on other sites More sharing options...
PZG302 Posted April 13, 2010 Share Posted April 13, 2010 Year/Model: 1973 240Z Suspension: Standard struts, spring seats dropped 2". Body Modification: Front guards "pumped" and rear guards have Susuki 4WD "eyebrow flares. rear inner guards tubbed for clearence Comments: Tight fit and wheels need a maxiximum backspace of 100mm to clear spring seats. Rim Brand:Simmons OM18 or Performance Challenger Rim Diameter:Simmons 18" Performance 15" Rim Width:Simmons 8" Performance 7" Rim Offset:Simmons -3mm, performance +4mm Rim Price:Simmons $3000, performave $400 2nd hand Tyre Brand:Yohohama slicks18", Toyo Proxes 15" Tyre Width:225-235 Yoki's 215 Toyos Tyre Profile:30 Yokis, 50 Toyos Tyre Price:Expensive for slicks, about $230 per tyre for Toyos Picture: Quote Link to comment Share on other sites More sharing options...
Mr240z Posted April 17, 2010 Share Posted April 17, 2010 Year/Model: 1972 240Z Suspension: Koni's classic reds, lowered Kings, Noltec bushs. Body Modification: Comments: 5mm spacer on front, std studs. No scrabing or rubbing..No problems Rim Brand: Rota Rids Rim Diameter:16" Rim Width:8" Rim Offset:10+ Rim Price:$1000x4 corners Tyre Brand:Maxxis MA-Z1 Tyre Width:215 front 225 rear Tyre Profile:50 front 55 rear Tyre Price:$200 a corner I no longer own my Zed, Andrew asked me to post. Quote Link to comment Share on other sites More sharing options...
acf321 Posted April 17, 2010 Share Posted April 17, 2010 Year/Model: 1971 240Z Suspension: Coil overs, unsure of dampers, but i think they are Koni. Body Modification: none - car has electric power steering, significantly improving track maneuverability Comments: NA. This car is running 270hp 2.8 L series motor, according to owner. Rim Brand: Minilite Rim Diameter:15" - Sean says this is as big as the 240Z should go for that old school authentic look/ Rim Width:8" Rim Offset: standard minilite sizing Rim Price:$230 + $50 extra for custom paint colour Tyre Brand: Yokohama R888 Proxies Tyre Width:225 F&R Tyre Profile:50 F&R Tyre Price:~$250 a corner This is Sean Dezart's car, an Englishman living in France. Quote Link to comment Share on other sites More sharing options...
bullzed Posted November 8, 2010 Share Posted November 8, 2010 Year/Model: 1982 280zx 2+2 Suspension: Standard with King SL's Body Modification: Shaved Guards Comments: 30mm Spacers front and back. Rear tyres rub guards on hard cornering, fronts fit perfectly. Rim Brand: XXR 513 Rim Diameter: 15 Rim Width: 7's front, 8's back Rim Offset: +15 front, 0 back Rim Price: $560 Tyre Brand: Trans Am G/T (American Brand) Tyre Width: 205 front, 235 back Tyre Profile: 50 front, 60 back Tyre Price: $320 Quote Link to comment Share on other sites More sharing options...
aidannn Posted March 7, 2011 Share Posted March 7, 2011 Year/Model: 1973 240z Suspension: Standard with King SL's Body Modification: Rolled rear guards + zg flares Rim Brand: Hayashi Streets / SSR Professor SP1R (at the moment) Rim Diameter: 15 / 15 Rim Width: 9.5" Rear / 8.5" Front Rim Offset: -19 / +2 Rim Price: too much / 900 2nd hand Tyre Brand: Firenza somethings / Toyo T1S Tyre Width: 195 / 225 (yes i know) Tyre Profile: 55 / 45 back Tyre Price: not sure Comments: The Hayashi Streets fit perfect with zg flares on the rear. Very flush. The SSR Professors sat nicely on the front with stock guards. Would sit conservatively on the rear. Now as my car has zg flares they are too sunken for my liking. They came with 45 profile Toyos which are too small and have a huge wheel gap. Quote Link to comment Share on other sites More sharing options...
Agno Posted July 17, 2012 Share Posted July 17, 2012 Year/Model: 1975 260Z 2 seater Suspension: Sectioned coilover struts, RCAs on the front Body Modification: None Rim Brand: Work Equip 03 Rim Diameter: 15 F&R Rim Width: 8" F&R Rim Offset: -3 F&R Rim Price: $900 /pr Tyre Brand: Toyo T1R Tyre Width: 225 F&R Tyre Profile: 50 F&R Tyre Price: $220 Comments: No scrub on stock body at all, front has quite a bit of camber because of the RCAs. I would prefer another 5/10mm -ve offset on the front to match the rear's "flushness" or vice versa but I'm sure this would be different if I had less camber on the front. Rim Brand: Performance Superlite Rim Diameter: 15 F&R Rim Width: 7" F&R Rim Offset: +12 F&R Rim Price: Tyre Brand: Dunlop Formula R Tyre Width: 205 F&R Tyre Profile: 60 F&R Tyre Price: Comments: No scrub on stock body, fronts would rub castor rod on full lock. jacksonneaves 1 Quote Link to comment Share on other sites More sharing options...
260z.76 Posted August 20, 2012 Share Posted August 20, 2012 Year/Model: 1976 260z 2+2 Suspension: Standard, Body Modification: rolled guards Comments: rear tyres scrub guards on bumps with 3-4 people and a full tank Rim Brand: rota Rim Diameter: 17" Rim Width: F9 R9.5 Rim Offset: F-13 r-19 Rim Price:900 Tyre Brand:? Tyre Width: F 225 R 245 Tyre Profile: 45 Tyre Price: 450 set Quote Link to comment Share on other sites More sharing options...
chris240 Posted August 20, 2012 Share Posted August 20, 2012 Year/Model: 1973 240z Suspension: lowered kings 25mm, koni yellows Body Modification: flattened lips to guards Comments: no scrubs , clear all round Rim Brand:rota RBR Rim Diameter: 16" Rim Width:8 all corners Rim Offset: +4 Rim Price: whatever ottomotto charged back then Tyre Brand:Kumho KU37 Tyre Width: 225 Tyre Profile:50 Tyre Price: $145 from memory Quote Link to comment Share on other sites More sharing options...
d3c0y Posted August 20, 2012 Share Posted August 20, 2012 Year/Model: 1973 240Z Suspension: Standard, king springs, koni red. Body Modification: rear fenders rolled Comments: Fits easily, needs lower springs in the front Rim Brand:Rota RB-R Rim Diameter:16 Rim Width:8 Rim Offset:+4 Tyre Brand:Various second hand tyres Tyre Width:225 Tyre Profile:50 Quote Link to comment Share on other sites More sharing options...
alex.a Posted January 1, 2013 Share Posted January 1, 2013 Year/Model: 1973 240Z Suspension: Standard, king springs, koni red. Body Modification: cut guards, bolt on zg flares Comments: lots-o-room Rim Brand:work equip-01 Rim Diameter:15" Rim Width:9.5" (f) 10.5" ® Rim Offset:-25 (plus 25mm bolt on spacers front/rear) Tyre Brand:el'cheapo "hero" Tyre Width:195/205 Tyre Profile:forget.. 55/60 maybe Quote Link to comment Share on other sites More sharing options...
Moderators PB260Z Posted March 5, 2017 Moderators Share Posted March 5, 2017 About time I added my comments to this thread Year/Model: '77 260 2+2 Suspension: Kings lowered F & R Body Modification: Nil Comments: Very close to front valance on 1/2 steering lock Rim Brand: Simmons Rim Diameter: 15" Rim Width: 8" Rim Offset: 0 Rim Price: can't remember Tyre Brand: Tyre Width: 225 Tyre Profile: 50 Tyre Price: Picture: Quote Link to comment Share on other sites More sharing options...
44014 Posted March 6, 2017 Share Posted March 6, 2017 Year/Model: 1974 260ZSuspension: Standard, king springs, koni red.Body Modification: Rear fenders rolled front guards rolledComments: Rubbed everywhere Dont do this, Would need like 215 tyre stretched to fit.Rim Brand:XXR 527Rim Diameter:16Rim Width:8.5Rim Offset:0Tyre Brand:Kumho Ecsta Ku36Tyre Width:245Tyre Profile:50 Quote Link to comment Share on other sites More sharing options...
