Dragonball240z Posted June 17, 2020 Author Posted June 17, 2020 I purchased the Kia seals from the wreakers. 2 hours ago, gilltech said: Can/did you buy the Kia seals new or are they only available second-hand? What year(s)? I've already put new repro S30 door seals on my 260 as the originals were perished, but they're too fat and haven't squashed down, PITA as after two and a half years I still have to slam the doors I'm pretty sure you could get them brand new from Kia. The are off a 1998- 2002 Kia Sportage gilltech 1 Quote
AndBir Posted June 17, 2020 Posted June 17, 2020 2 hours ago, Dragonball240z said: I'm pretty sure you could get them brand new from Kia This post has the part numbers and a link to the korean supplier I used , they fit the 2 seater door frames but not the larger 2+2 door frames : Quote
gilltech Posted June 18, 2020 Posted June 18, 2020 Thanks for that, much appreciated! Yes this is for a 2-seater. Quote
Dragonball240z Posted July 12, 2020 Author Posted July 12, 2020 Finally getting a chance to post again with some more progress. The original diamond vinyl trim was cleaned up and reinstalled into the car. We also cut and installed some carpet underlay. I need to source some carpet and choose a colour. I'm thinking of going a gety to lighten up the interior. Ponyo240z 1 Quote
Dragonball240z Posted July 12, 2020 Author Posted July 12, 2020 We have also tackled the roof and front pillar vinyls using our own patterns and the materials in the pics. I sourced some closed cell foam from clarke rubber, and the vinyl was left over from my dads last project. The contact adhesive we used is made to deal the heat generated off the roof. Ponyo240z 1 Quote
Dragonball240z Posted July 12, 2020 Author Posted July 12, 2020 We sprayed the adhesive on on the foam and the roof. We made sure not to spray all they way to the edge of the roof (see cardboard in first pic) and the foam. This was very important to achieve the result that we did. If the adhesive went all the way we wouldn't have been able to tuck the vinyl & foam in (see third pic). AndBir, Ponyo240z, theremm and 1 other 4 Quote
Dragonball240z Posted July 12, 2020 Author Posted July 12, 2020 For the next step we put a bit of adhesive on the top of the vinyl, then locked it in with a pvc pinchweld. Adhesive was then added body work under the foam (we didn't put any on the foam so we can work any kinks out at a later stage) and the last 20mm of the vinyl. The vinyl was folded over the pinch weld and stuck to the body work. The door seal will also help lock it all in. Quote
Dragonball240z Posted July 12, 2020 Author Posted July 12, 2020 The drivers side pillar vinyl was stuck directly into the bodywork. This same process was used to complete the front and the passenger side roof vinyl. I was super stoked with the results... over the next couple of days, my dad wasn't happy with a couple of fine creases and managed to work them out. SO the finish was even better. The last photo probably doesn't do it justice. I will try get a better one in the coming days in better light theremm and Ponyo240z 2 Quote
Administrators gav240z Posted July 12, 2020 Administrators Posted July 12, 2020 What was the spray adhesive you used and where did you get it from? Quote
Dragonball240z Posted July 13, 2020 Author Posted July 13, 2020 18 hours ago, gav240z said: What was the spray adhesive you used and where did you get it from? I used heavy duty automotive headliner adhesive from Autobarn gav240z 1 Quote
Dragonball240z Posted August 13, 2020 Author Posted August 13, 2020 (edited) Over the last month we have made some more progress. Most notably passenger door, fenders and interior. Its was so excited seeing the door and the fenders on the car. Edited August 13, 2020 by Dragonball240z hmd, OdinZ, C.A.R. and 3 others 6 Quote
CroS13 Posted August 19, 2020 Posted August 19, 2020 looking great! interior turned out top notch! Rudi. Dragonball240z 1 Quote
240ZBUILTBYME Posted August 26, 2020 Posted August 26, 2020 Great work Julian btw what’s your paint code/color? Ryan Quote
Dragonball240z Posted August 26, 2020 Author Posted August 26, 2020 On 8/19/2020 at 11:48 PM, CroS13 said: looking great! interior turned out top notch! Rudi. Thanks Rudi Quote
Dragonball240z Posted August 26, 2020 Author Posted August 26, 2020 3 hours ago, 240ZBUILTBYME said: Great work Julian btw what’s your paint code/color? Ryan Thanks Ryan! The paint colour is norfolk mustard yellow (lotus colour) Quote
Dragonball240z Posted November 25, 2020 Author Posted November 25, 2020 It has been a while since I have updated this thread. Since August I have made good progress to to try and meet my goal of having her on the road by Christmas. There was a massive delay on getting some key parts from america due to some very ordinary customer service. One of the jobs we tackled was to install the new shocks (Koni Yellows) and king springs. These coil spring clamps worked a treat. The install went relatively smoothly. Ponyo240z and 240ZBUILTBYME 2 Quote
Dragonball240z Posted November 25, 2020 Author Posted November 25, 2020 The colour of the shocks are very close to the exterior paint (the only reason why I didn't go Koni reds ). Ponyo240z 1 Quote
Dragonball240z Posted November 25, 2020 Author Posted November 25, 2020 Then we worked on refurbing the rear brakes From this.. To this.. Ponyo240z, 240ZBUILTBYME, AndBir and 2 others 5 Quote
Dragonball240z Posted December 2, 2020 Author Posted December 2, 2020 The next job was to go refurb/ replace the front brakes. These probably hadn't been been used for the last 20 years. They were ceased and the brake fluid channels were blocked solid. The only for me was to split the brake caliper. Cleaned, sprayed, new seals etc looking through my photos, I don't have one of them installed in the car Ponyo240z and 240ZBUILTBYME 2 Quote
