Administrators gav240z Posted April 8, 2020 Author Administrators Posted April 8, 2020 https://bringatrailer.com/listing/1971-datsun-240z-133/ Didn't sell. Quote
Administrators gav240z Posted April 8, 2020 Author Administrators Posted April 8, 2020 https://www.ebay.com/itm/1971-Datsun-240Z-Sports/184234410977 Price:US $99,000.00 (listing ended) Quote
Administrators gav240z Posted April 9, 2020 Author Administrators Posted April 9, 2020 Stunning Z432 in 919 yellow. https://www.goo-net-exchange.com/usedcars/NISSAN/FAIRLADY_Z/700057058930190531001/index.html Quote NISSAN NISSAN FAIRLADY Z Z432 1970 Saitama Japan Tokyo Japan 2020/03/27 Up Stock Number:0570589A30190531W001 NISSAN FAIRLADY Z Z432 ¥33,000,000 Send Inquiry Send Inquiry Car Price ¥33,000,000 You'll need close to $450k AUD though at today's exchange rate. Quote
Administrators gav240z Posted April 9, 2020 Author Administrators Posted April 9, 2020 Z432 in white, price is available on application. https://www.goo-net-exchange.com/usedcars/NISSAN/FAIRLADY_Z/700057075330190719001/index.html Not wearing original Topy's for some reason... Price not disclosed. Quote NISSAN NISSAN FAIRLADY Z Z432 1970 Saitama Japan Kanagawa Japan 2019/08/15 Up Stock Number:0570753A30190719W001 NISSAN FAIRLADY Z Z432 ¥ASK Send Inquiry Send Inquiry Car Price ¥ASK Quote
Administrators gav240z Posted April 10, 2020 Author Administrators Posted April 10, 2020 This 73 Fairlady Z seems to have reached $180k+. https://buyee.jp/item/yahoo/auction/s728710183?lang=en Quote
HS30-H Posted April 10, 2020 Posted April 10, 2020 1 hour ago, gav240z said: This 73 Fairlady Z seems to have reached $180k+. https://buyee.jp/item/yahoo/auction/s728710183?lang=en Not surprising really. Its a very nice spec, and done well. No 'helpful' comments from Lstepp4re a la Bring-a-Troller either. Win win. gav240z 1 Quote
Administrators gav240z Posted April 11, 2020 Author Administrators Posted April 11, 2020 It's an excellent price for an early-ish S30z tail lamp car. At those prices it's worth restoring these cars properly. And it is a lot of work, so it's not like easy money. Quote
Administrators gav240z Posted April 17, 2020 Author Administrators Posted April 17, 2020 https://page.auctions.yahoo.co.jp/jp/auction/q357347561 July 73 model. Current Price 7,890,000 yen (AU $ 121,821.60) Quote Fairlady Z ★ Showa 48 S30 Kai ★ One tail of the previous year ★ L28 official recognition ★ Many maintenance and tuning ★ Car inspection You can ride quickly and comfortably until July 3rd. It's not a full restore, but it will be a very good S30z that has been tuned to leave the atmosphere of that time. The engine is in good condition and you can get on in the best season right now. The restoration history will be unknown considering the year, but I don't think there will be any major accidents. It is the maintenance and tuning contents that will be understood by both the former owner and me. Body: The whole body is beautifully painted with sheet metal (the interior and engine room are as they were at the time). Under undercoat finish. Indoor: Dashboard cover attached (dash cracked) Others are almost genuine. All instruments are working. Engine: L28 officially certified, it turns smoothly and lightly. L28 modified short stroke specification 89φ piston L24 crank L14 connecting rod surface polishing Kameari 75 degree A cam reinforced spring lightweight flywheel damper pulley reinforced oil pump Gold Solex 44 funnel 50mm stainless steel equal length tacoashi 42φ stainless steel one-off muffler 60φ outlet 50φ with dual volume control valve Maloney Full Tradesby WAKOZ Coil MSD Plug Cord Kameari IC Regulator Mitsuba Electromagnetic Pump Radiator OH Repainting Drive System Differential R180 Mechanical LSD 5 Speed Mission 71B Kai (Internal 71C240 Cross Specification) Kameari Reinforced Clutch Undercarriage Kameari Front Carriage with Rear Helper Spring Made roll center adapter Rear lower arm reinforced Satatsubar brake caliper: MK63 Wheel: Watanabe R type 16 inch 8.5J (2 gun metal + 2 gold plated left and right color difference) Tires: Yokohama / Flavor 195/55/16 (Approximately 500km after replacement with a new one in August 2019) The front bumper is an original water car with a lower lip and longer lip than conventional products. (There is a normal bumper) The latest maintenance of Kameari rear spoiler October 2019 It is more than brake fluid, engine, mission, differential, oil change . However, I think that there is a mistake in the content, we can not guarantee the content The current car will be all. If you are considering purchasing and want to check the current car, please enter your e-mail address and name with the at sign in katakana in the question column. We will contact you by email from here. (It will not be disclosed because there is no response to that.) The payment amount will be "the highest bid + deposit of 50,000 yen until the transfer of ownership is completed". After delivery, please make a no claim no return. (Added 17:43 on April 4, 2020) The mileage stated in the vehicle inspection is 68,300km in 2017 and 71,200km in 1 year. Currently it is 72,000 km (It will increase due to condition maintenance) It will be an additional image https://box.yahoo.co.jp/guest/viewer?sid=box-l-snjwzs2vjtp7o42b7puqffp37y-1001&uniqid=b2b1e7c6-ee27-440f -b3ce-926efee90cd6 ( Added 18:02 on April 10, 2020) The engine start video has been uploaded to YouTube. https://youtu.be/EPPmXM_g9Oc Quote
Administrators gav240z Posted April 17, 2020 Author Administrators Posted April 17, 2020 https://page.auctions.yahoo.co.jp/jp/auction/r394133616 Car name: Fairlady Z Color: White Year : 1976 Current Price 6,780,000 yen (AU $ 104,683.20) Quote L20 modified 2.6L engine After manufacturing 4000KM E30 block N42 Cylinder head camshaft 68 ° Reinforced valve spring Solex carburetor 44Φ Nismo heat plate Large capacity fuel pump Fuel delivery pipe Fuel regulator Fuel pressure gauge Ultra plug code MSD Wako Technical Super Z Coil factor Exhaust manifold Camellia steel muffler 71B breaks 71C mission OS Giken single clutch R200 differential electric shock before and after harmonic drive KIT roll center adapter front tower bar rear tower bar S15 Silvia front calipers rear Al fin drum Stainless steel mesh brake hose Watanabe, 15 inches wheels front 8J × 15 , rear 8J × 15 Bridgestone Potenza RE003 -front 195 / 55-15 rear 205 / 55-15 Wanteru one tail garnish Recaro operation Sekishi Door SMITHS tachometer RAMCO additional meter , water temperature gauge , oil pressure gauge Quote
Administrators gav240z Posted April 18, 2020 Author Administrators Posted April 18, 2020 https://page.auctions.yahoo.co.jp/jp/auction/c814513227 77 Model Fairlady Z 2 seater. Quote Buy it now price: 7,272,728 yen [Tax included 8,000,000 yen] (Tax included AU$122,720.00) S.52 (1977) Nissan Fairlady Z S31Z, high original degree, actual running, no restoration Black running 55460km ☆ Weber 40Φ ☆ Engine L20 normal ☆ MK63 caliper ☆ EX mani ☆ Camellia front spoiler ☆ The picture is a "genuine wood handle" , "Datsun competition handle" is also available. ☆ ★ New vehicle harmonics ★ ☆ ☆ ★ New muffler ★ ☆ ☆ ★ Re-seat seats New ☆ New pug code ★ ☆ ☆ ★ New wheel "Watanabe F15 R16" ★ ☆ ☆ ★ New tire "Dunlop Direzza" ★ ☆ [From person in charge Comment] ■ Thank you for visiting the BANKING page. ■ The Fairlady Z S31Z, which is in very good condition, has arrived. ■ Since it was made from almost normal, the originality is very high. ■ The body is superb and there is no single crack on the dashboard. ■ Also, there is no restoration history and the actual running is 55,460 km. ■ The color has been changed to black, and it is also possible to hand over all paint. ■ It's a lifetime, so it's worth seeing it once. You can also check the current car, so we would like you to come to the store and feel the goodness of this car with your own eyes. ■ Also, I will shoot the engine room and engine sound in the video. Eyes and ears I hope you can experience the goodness of this car. ■ We look forward to all the staff. Quote
Administrators gav240z Posted May 26, 2020 Author Administrators Posted May 26, 2020 https://bringatrailer.com/listing/1972-datsun-240z-124/ Nice 72 got a good price recently. $53,000 USD. So just about $80k AUD at today's rate. Quote
Administrators gav240z Posted June 25, 2020 Author Administrators Posted June 25, 2020 Vintage Z Program restored 72 240z in the US was recently offered on BAT. Sold for $105,000 USD which is approx $150k AUD at today's price. https://bringatrailer.com/listing/1972-datsun-240z-127/ gilltech and mossy 2 Quote
Administrators gav240z Posted July 4, 2020 Author Administrators Posted July 4, 2020 Worth a watch... 49-Years-Owned 1970 Datsun 240Z https://bringatrailer.com/listing/1970-datsun-240z-51/ Quote
Administrators gav240z Posted August 31, 2020 Author Administrators Posted August 31, 2020 https://buyee.jp/item/yahoo/auction/v727068612?conversionType=search_suggest Looks like a real GTR, engine out, bad floor plans and probably more rust .. Still $250k+ Quote
Administrators gav240z Posted September 11, 2020 Author Administrators Posted September 11, 2020 Works Rally 240z Tribute on BAT. https://bringatrailer.com/listing/1970-datsun-240z-61/ DattoZ 1 Quote
DattoZ Posted September 11, 2020 Posted September 11, 2020 3 hours ago, gav240z said: Works Rally 240z Tribute on BAT. https://bringatrailer.com/listing/1970-datsun-240z-61/ My Goodness! This would be my ultimate version of the s30 vehicles. I hope it goes to a good home. Quote
HS30-H Posted September 11, 2020 Posted September 11, 2020 15 minutes ago, DattoZ said: My Goodness! This would be my ultimate version of the s30 vehicles. I hope it goes to a good home. I don't want to be too harsh here, but what exactly are people swooning at here? It's a nice car but it is nothing, nothing like a Works rally car, let alone the '71 East African Safari Rally winning car. It's not really much more than a paint and stickers job with a few fabricated add-ons. Do people understand just how special the Works cars were? I don't think they do. gav240z and DattoZ 2 Quote
DattoZ Posted September 11, 2020 Posted September 11, 2020 3 hours ago, HS30-H said: I don't want to be too harsh here, but what exactly are people swooning at here? It's a nice car but it is nothing, nothing like a Works rally car, let alone the '71 East African Safari Rally winning car. It's not really much more than a paint and stickers job with a few fabricated add-ons. Do people understand just how special the Works cars were? I don't think they do. Nah not harsh at all, I just love seeing the old rally builds of these cars. It's interesting to see owners build "Tribute" cars. Quote
gilltech Posted September 11, 2020 Posted September 11, 2020 Well I for one would be proud to own it. Someone has gone to a great deal of trouble with all the decals & graphics. Quote Do people understand just how special the Works cars were? I don't think they do. How could we, unless we saw them being built. But we can still appreciate their history and tribute cars keep that history alive and not confined to museums. DattoZ 1 Quote
Ponyo240z Posted September 11, 2020 Posted September 11, 2020 12 hours ago, HS30-H said: I don't want to be too harsh here, but what exactly are people swooning at here? It's a nice car but it is nothing, nothing like a Works rally car, let alone the '71 East African Safari Rally winning car. It's not really much more than a paint and stickers job with a few fabricated add-ons. Do people understand just how special the Works cars were? I don't think they do. Hi Alan What is the most accurate resource for reading out there at the moment? Thanks Quote
HS30-H Posted September 11, 2020 Posted September 11, 2020 13 minutes ago, gilltech said: Well I for one would be proud to own it. Someone has gone to a great deal of trouble with all the decals & graphics. How could we, unless we saw them being built. But we can still appreciate their history and tribute cars keep that history alive and not confined to museums. I wish I could lead you by the hand and show you *The Real Thing* whilst pointing out the hundreds, if not thousands, of details that went into them. Honestly, I think you'd be in awe. As I always am. Quote
HS30-H Posted September 11, 2020 Posted September 11, 2020 6 minutes ago, Ponyo240z said: What is the most accurate resource for reading out there at the moment? There isn't one. I sometimes post about them here, or on classiczcars, and try to do them justice but - to be brutally frank - if you could see *The Real Thing* it would tell you much more than I could ever witter on about. So, if you can, try to get near to a real one and marvel at the work that went into it. Ponyo240z 1 Quote
hmd Posted September 11, 2020 Posted September 11, 2020 (edited) Taken in Tokyo a couple of years ago. Edited September 11, 2020 by hmd HS30-H and DattoZ 2 Quote
specialp3 Posted September 12, 2020 Posted September 12, 2020 https://bringatrailer.com/listing/1972-datsun-240z-149/ CBR Jeff 1 Quote
specialp3 Posted September 12, 2020 Posted September 12, 2020 (edited) I have to say this is one of the best looking zeds I have ever seen. The stance of this car is perfect and the photography is very nice. Talking about photography, is there anyone in Sydney that can take photos like shown in the BAT auction. Edited September 12, 2020 by specialp3 Quote
