KatoKid
Everything posted by KatoKid
  1. Speaking of engineers.....I had an appointment with these guys http://www.enkelman.com.au/ today. Some of you may remember a guy called Mayhem on here, had a white 260 with an RB25DET in it? I had spoken with him just before he sold the car and he had a good experience with Enkelmans, I figured if they were happy to sign off an RB then the M3 engine should be fine. Before I even purchased the M3 engine I had spoken with Bernie at Enkelmans and he was happy to give the OK to proceed in principal. In the meantime I had spoken with Jamo and Sirpent and was considering using Paul Bottomley but was put off by Tom's (Handsandwich) reception from Bottomley so decided to suss out Enklemans in person. Up till today I had only spoken with Bernie on the phone and that was nearly two years ago so I was keen to meet him. Bernie was very professional without being over authoritative, he asked lots of questions regarding all aspects of the conversion. The more we talked the more he relaxed and I found him to be very personable. I had stressed to him that I wanted the conversion to be bolt in and be fully reversable and he appreciated why. He demonstrated a good understanding of Z's and BMW's which was good. After a thorough discussion I asked him to come and look at the car and he said there was no need, he was confident that I was doing everything required and he said to bring the car down when it was finished and he would inspect it, do a brake test and that would be all that was required! You bloody ripper! No torsional tests or chassis mods required! Bernie even asked if I was going to go with coil overs.......my original plan was to get it engineered with standard springs and convert to coil overs later but he confirmed that coil overs are legal and he is fine with them....so coil overs it is straight away. I also asked about emissions and he said there was no requirement to test and clarified that I don't even need to run cats. Yipee! Overall I'm very happy with the way it went and based on my experience today I would be happy to recommend Enkelmans.......so far. And a final note, Bernie confirmed that NCOP VSB14 has been in force in Victiroa for nearly 12 months now.
  2. The WRX rack conversion moves the shaft from the steering column to the rack outboard a fair way, which is good because it provides much needed exhaust room but also puts the shaft right on the chassis rail. You could leave it but engineers wont like it so I tweaked the base of the steering column across towards the centre of the car to give some clearance between the chassis rail and the shaft that runs down to the rack. Just had to redrill the 4 holes on the plate at the base of the column that bolts to the firewall. All good.
  3. Grown men, tightly packed in a circle around a publication breathing heavily.......picture that.
  4. Very rare and Historic.....yeah right.
  5. It is in its final position in the photo and no its not centered. The whole drivetrain (eng/gbox/diff) are set off to the drivers side by about an inch and a half, as they are with the L series from the factory. My choice of guibo joint (rubber donut) at the gearbox output means the crank/transmission centreline needs to be pointing straight at the diff pinion shaft as the guibo wont tolerate any angle. You could centre this engine but would need to use a standard M50 sump or modify the 3.0L M3 sump as it would hit the T/C rod bracket on the LHS chassis....and you would have to convert the gearbox flange and tailshaft to use cardan joints. But why would you when it doesn't need to be centred.
  6. Rat man, well spotted they are bits of wood. I needed to lower the crossmember to get the ideal driveline alignment. I used wood spacers just to get the set up right and Ive had alloy ones made last week but haven't picked them up yet.
  7. Looks brilliant Pete. Must be a great feeling.
  8. KatoKid
    PI 18th Nov
    Let me guess.... that would be the wife?
  9. KatoKid
    RB 28 BUILD
    Crazy we like.....congrats mate. Must feel unreal to drive it for the first time.
  10. Does look good. Next thing will be to strip out and modify the factory wiring harness and hide it down behind the back of the cylinder head. Plan is that most of it wont be seen.
  11. Had a bit of inspiration last night after putting the car on the hoist for the first time........the engine and gearbox was sitting on the test stand next to it and I realised that it would be pretty cool to be able to load the whole lot from underneath by wheeling it under the car and dropping the body on the hoist over it. So this morning after an early coffee I decided that the engine test stand had done its duty as a test stand as the next time this engine runs will be when its ready drive in the car. I put the Z crossmember and mounts on the engine and raised it up 30cm to give me enough height to get under the car on the hoist and do up the transmission crossmember. I used the lower control arm holes in the crossmember for the extensions and just made a cradle to sit under the back of the trans at the back. Pretty chuffed with the way it worked out, it took all of 5 minutes to drop the body over the engine and do up the 6 bolts to secure it in place. I'm hoping that this will also work with the exhaust headers in place as well so that in the future if I ever need to pull the engine or gearbox I will be able to do it this way. It sure was good to see the engine back in its place again, gave a real sense of progress to see it there. I will be asking the engineers to come and inspect this ASAP. Looking forward to this with some trepidation! I needed to check a couple of things that have been niggling away at the back of my mind. I had never actually confirmed bonnet clearance for the engine....it looked like it would be OK but it was time to confirm so I pulled the old bonnet out and dropped it on......the throttle lever which the accelerator cable attaches to is the highest part of the engine and it just cleared as did the oil filler cap at the front of the engine....phew!
  12. Well done Scoota! Will Lucinda be your date at the Christmas BBQ?
  13. Nice!!!!
  14. Noooooooooo! Pete, don't know what to say. Love the way you've done everything so far, great attention to detail, be such a shame to not finish it yourself. Sometimes life makes decisions for us. I'm sure you dwelled on this for a while and its been tough to make this call. Good luck, I sure it will go to a good home.
  15. So 5 weeks ago I bought myself an early Christmas present. Had it bolted into the floor the following weekend and just needed a sparky to wire it, my brother suggested his brother in law so I approached him and he was happy to do the job as long as I wasn't in a rush, which I wasn't as I had plenty of other things to do. Eventually I had done all these things and was really ready to use the hoist this weekend and as luck would have it Mr. Sparky turned up today and had it wired pretty quickly. Spec's called for a 30 amp circuit which seemed like overkill and was....... a load test revealed it was only pulling 7! Anyway, very excited to get the Z on the hoist finally. Will make life much easier for the Z and servicing other cars.
  16. I was going to buy a Radum but they had to quarantine all their shipments due to an issue with the engineering specifications on the arms. Ended up buying from these guys http://www.tufflift.com.au/, $2,500 for a 4T clear span.
  17. So there seems to be a few "bicycle freaks" out there as Mossy calls them......... I need some advice. Ive been battling with a bad knee for quite a few months now and resigned myself to the likelihood of having to give up running so I'm looking at buying a mountain bike (if that's the correct name these days). I used to do a lot of road riding when I was (much) younger as I had a mate who eventually turned pro and he kept on dragging my ass out on training rides. Ive decided that sharing the road with cars isn't for me, plus I live at the base of the Dandenongs with instant access to lots of tracks, not downhill stuff but good terrain for training (I think). So I'm looking for advice on what sort of bike to buy. I don't want to spend big $ as I may try it and hate it, so looking at something that is mid level (not entry level junk but not the latsets and greatest either). Do I go for front suspension only? What brakes and gears? What else to look out for? Ideally Id like to buy something secondhand to get started so any suggestions on brands/models I should look for and roughly what I should spend? I'm a total noob at this so expect lots of dumb questions. Thanks in advance. David
  18. Not dead yet....these guys (and others) http://www.candsspecialties.com/store/html/blowthru.html get some outstanding results from boost referenced carbies.....1,000 + Hp easy and reliably.
  19. Only ask because Ive seen other ITB set ups including my M3 which run a vaccum manifold to all 6 runners to ensure good signal. I was a bit concerned about the T/C rods using steering rack tie rod ends as the T/C rods will see much higher loads than any steering system will.......but...... had a look at the ZCCJDM web site and saw the testimonial from Jon Siddins. That's good enough for me!
  20. Bonus! Not often you get a win - win situation like that.......most of the time there's a compromise trade off. Do you move the valve location to get a bigger valve or is it just to optimise port configuration or unshroud the valve?
  21. Nice to catch up with Alan and Dimitri....brilliant day for it!
  22. Pete, assume that when you make the longer rocker you are lengthening just the part between the cam contact point and the valve stem (the distance from the pivot to cam contact point stays the same), there by effectively increasing the ratio of the rocker and giving more valve lift for the same cam?
  23. Also have to ask, can you genertate enough vaccum from one cylinder to properly run the booster?
  24. Good LHS and new RHS from the front.
