dat2kman
Everything posted by dat2kman
  1. Eh?? I know that you can run pit to car comms, on individual setups, but this radio reciever is one way, ie Race Control to all cars. It worked a treat at Lakeside, we had a number of incidents, you are full nouse, and BANG your ears are full f verios messages. Can see merit in this for sure. Find out just what psscraq are doing re coms. The unit can ge programmed with gazillion UHF type channels, similar to an ICOM transceiver.
  2. Well done!!! It's good fun! Bit of advice, Start off taking baby steps, both you and your car. First, dunno what size rims you have, but a second set of rims, with really good semi slicks, nice soft onesa full set of decent shocks, i'd suggest Koni Yellows, start them on softest setting, and play with settings experimenting with under/over steer. Just that. Do Collingrove as often as you can. Watch others Youtube videos f it over and over. Your fronts are locking due to cheap ChingLong tyres, worry about super dooper brakes later, Our stock brakes work very well, believe me, i know! For front pads, Lucas TRW. To improve 4 seconds on ne day is excellent. Forget all the "wallet " doomsayers above, you can do this at reasonable cost!
  3. Qld R/Way and Lakeside R/way both use a small clip on voice radio reciever, so control tower can "talk/advise/warn" etc whilst out on track. I now have a brand new one , unused, still in packaging, for sale. Their regular price is $120. Selling at $110 If PZG wants it, it's cheaper again, as he lent me the timing transponder they use at both tracks now.!
  4. S'awlrite Lurch, i haven't a clue what it means to "embed" it just sounds cool to say it, ie, "come here you nubile nymphette, i wish to embed you" That line, by the way, just never works.
  5. Video. James Flett in his 260Z, vs Porsche 2.7 ( it blows an engine on first lap) and the DeTomato Panty Tearer Voila, enjoy! Check out this video on YouTube: If it doesnt work directly from above, please, someone embed it?
  6. Touch of thread mining, just for the old bloke with the un-classifiable un-logbookable butchered ZX, that can only use fifth gear top speed circuits. This Logbooked fully compliant multi purpose well sorted, with further development pitential car,now, hold class lap records at, Lakeside Raceway, Queensland Raceway, Morgan Park long circuit, and is 0.2 seconds off class lap record at Winton Long, it laps PI in 1.55's, and Mt Panorama in 2.45's, Eastern Creek in 1.53's. These are very good credentials for a steel bodied 6" wide rimmed, stock factory braked heavy shell 280Z. Apparently, some old keyboard racer type would dispute the above. From the comfort of his Namco pladtic chair. Seriously, after having had extensive upper engine work done recently, with Les Collins Racing, and done two events since, and bodywork repaired, she's ready to race.
  7. Solution, record the 1000, watch the start, then the hourly update, each hour, then the last few laps! The rest is one taxi after another!
  8. Lee, pull the diff out, and get it to Diff&Gearbox Industries Newmarket ard Windsor, behind the Matilda servo. It sounds very much like the centre was removed and replaced, but set up correctly, it may also need some bearings.
  9. Caged and lgbooked?
  10. Just a suggestion, sell off what you have now, so you are cashed up, and in meantime, something may come up. The 260 2+2's will be more plentiful, and a lower cost, so your $$$ left over can be spread further on a rebuild. There is a good Z community in SA, something should come up for you!
  11. Mid/early 1980's Skylines had L20a engines fitted. I GAVE one away a while back. Models were four door MR or HR designation. Still a few around.
  12. Be interested to know,,, what did the time waster say or do? I have mentioned it is still avail on a ACT based rally forum, you may wish to tempirarily join up, in order to post it up. Based on what it has, i'd suggest at $1500 it is rather low priced. Put it up for 2500-3000, but mention you'll accept near offers. Most on there are genuine types Good luck! If i was closer i'd grab it, stick in a 2.4 and go club racing, alloy cage and all. Btw a replacement for a "lost/missing" logbook at CAMas is around $70 and 10 minutes of time!
  13. I got a ronded shape fits in my palm, spinning random orbit jobbie of ebay, its air driven, the tube outlet to catch dust in a bag is useless, the stock disc attachment is crap, i bought a 5" screw on Velcro disc wheel, cushioned, and a selection of common sized round varios grade white sanding discs. Supercheap has the common round discs, check which sizes they have a lot of, before you buy anything It cost me about $50 Three cars later it is still going fine! Biggest job was a near metal strip on a 1966 Chevrolet Belair Dont use it for fine finish sanding, wet n dry for that.
  14. One of my cars has a set of tyre valve fittings attached to the screw on lids on the master cylinders, it runs balance bar, so two cylinders, two caps, two threaded tyre inflating valves. There is a hydraulic handbrake in rear line, By using a bicycle pump, i can put approx 3psi, ie one pump, into the half filled large master reservior. When i crack the bleed nipples, fluid comes fair shooting out. There is no need to have anyone sitting in car pumping pedal X3, hold, crack/bleed, ,,, repeat etc.
  15. With some 11 hours to go, bidding is at $3900 Turns out Les Collins /Dateally did rhe head, back in early/mid 1980's. Thought it might be a good one!
  16. The sets i have here are brand new! I buy the Performance mag rims for race use, but am not permitted to use the centre caps for racing. Private message me back, if you here from me via your contact details as above.
  17. Some in life, are simply destined to be keyboard racers, others, on the other hand, get out and do something, they crawl, then walk, then run! The running part, alongside 40 or so others, is at a level well above the keyboard racers, who, have NFI what they are on about! Not only are we pushing for Gp T cars, but also for Gp U, ( genuine historic sports sedans) We are getting there though! The HRCC Qld, is holding a Sports Cars Carnival at Lakeside on 21/22 Sept, as pzg302 above, and at this stage there are low entries from the Qld Group S cars, atm, only 7. Of which two are Gp T, three are coming up from NSW. I have put a proposal to HRCC that they consider opening up the field to other "invited" cars, of a production nature, with modifications in period, ie triple carby big braled wide rimmed 240 and 260 Z's This will be discussed by HRCC early next week. In meantime i have contacted a few of the ZCCQ members, to garner interst and let them know of the opportunity to come and race, with the slow ancient 40 year old real and fake cars. This happened a couple years back, at QR, a few Z's turned up, ran with a few Gp S cars, and we all had a great time, so much so, many wish to do it again. The stipulation of period type mods, unfortunately will not allow 260det's oddball ZX that is, apparently, so fast, it can only "race", on only THE fastest fifth gear circuits in the country, like PI, and soon, Bathurst! ( car setup is wrong, but what would I know!) Anyway, hopefully, the HRCC agrees to the request to include pre 1976 Z's with mods, ie the regular MP Sprinter guys, and a few will get to have a play, in proper races! Last year, John McKeon's red/yellow 240 ran with us, and that is a very modded car!
  18. I once,,, a very long time ago,,, rebuilt a fuel pump. It didnt work! Turned out i put the valves in backwards, it was trying to suck fuel out of the carbs, and back into the tank! Try fitting a basic clear plastic type filter just after tank outlet, but after you have disconnected all lines and used air compressor to blow lines back through.
  19. Rubbish! For a Muira SV, i WIL make room! Just whack in another houst, problem solved!!! Bwaahahahaaaa!
  20. I'd still like to know, what is the OPer's budget? What price for one, if one was able to be accquired? I have to say, i would not desire a 432, a Lamborghini Muira SV is what i am interested in. My budget? $500 to $800 k. I have a space in a shed waiting. And no, not the fake one built on a Pontiac Fiero floorpan ( it does have a proper Muira windscreen, cost him some $8000)
  21. Be-Zed may be kind enough to let you know when the next ZCCQ monthly? Or is it every second month?, club meeting night is on, and maybe pop along as a guest, and let them know. You are certainly planning well ahead, for your impending day of doom,,,, ooops, sorry, day of bliss!
  22. The white Stang is the ex Geoghan car, now owned by the estate of Des Wall, his son David drives it. Yes in appendix J, it is a famous and genuine car. Just like the ex Mingay/Carter Datsun, now a Group T car. CAMS Historic commission encourages event organisers to allow ALL historic categories a go, and places the Gp T cars, ( prod based sports) within Group S fields ( prod sports) The Group S association make strong demands and threaten to boycott events if event organisers accept entries from genuine original prod based spirts cars, ie Gp T. The Group S assoc is 150 members strong, and gets "listened to" hence no more Group T cars at VHRR Phillip Island or Winton Historic meetings. In NSW the HSRCA, politely ignore these demands, and allow the proper cars to run. The OTHER white Mustang, in Victoria, driven by a rather influential Victorian member of VHRR, may have taken umbrage, at, a, and it is in writing, as a "complaint" to the Historic Commission,,, "A crappy Red Datsun passed my very expensive car at a recent Phillip Island Historic meeting, i want it banned, i am rich" etc etc etc. Even the pukka Austin Healey club of Victoria had a bloody huge public whinge about "old Datsuns" God forbid if a genuine, with race history ex USA John Morton, Pete Brock or Bob Sharp original race 240Z was to be raced here in Australa!! Cant have that now,,, can we!!! By the way, I DID ENTER MCM13, brian Henderson in the Gp A Gazelle was all set to take me and the car down and back, but the ARDC rejected my paid entry and application, with NO readon given.
  23. And what is your budget, give or take $10,000 or so?
  24. +1 Yes, be good to share/upload pics!
  25. How many you need? I got around five sets! Shouldn't be an issue pisting to UnZud for you!
