gilltech
Everything posted by gilltech
  1. To fit a 240 or early 260 the gap at the top of the rear strut needs to be filled with something, piece of vinyl maybe; this as the late 260s have taller rear struts hence the window panels are different at rear (two fixing points instead of three). Nice set of trims though.
  2. Wow. Nasty. Would have been a powerful beast until the sudden stop. At 6.6L I presume the motor is a Chev 400 cu in. Not for the faint hearted in a light car like the Zed.
  3. Definitely not 260Z. Maybe 280ZX 2+2 or 300ZX?
  4. Better to have the ends meet at the middle of the sill, as at least the pinchweld's butt joint is mostly covered by the inner sill trim.
  5. Most interesting to see this car surface. (But bloody hell, poor rear quarters, that's a pretty brutal way to get a body kit to fit...)
  6. Might be easier to find 260Z dashboards wouldn't it? A conversation with a Z parts supplier & guru many many years ago indicated that one will fit the other with alteration to the mounting brackets. He was commenting about a 240Z/260Z 'cut'n'shut' race car, IIRC it was a 240 with a 260 front clip & dash.
  7. I have a very early 260 2-seat. AFAIK the seats are the same as the 240. But in any case they use plastic spacer blocks on the seat track studs to adjust the seat height. So while I can measure for you it depends on how many spacers I have fitted. But the later 260s had a different seat rail mounting bolt system, is that maybe what you are referring to?
  8. Sounds like issues such as 'roadworthy' is even more relaxed there than in QLD. In NZ one has to get a fresh 'roadworthy' or safety check - called a 'Warrant of Fitness' - every 6 months for all vehicles including motorbikes and trailers. No WoF, then no registration, no valid insurance, and big penalties if one is caught without one. But sure does go a long way towards keeping a lot of dangerous and rusted out old piles of shit off the road. Keep us posted. Most interesting hearing from Zed owners in less well known Zed markets. Do you have any history on your cars? Are you required to convert them to RHD (I presume not) or is it just your preference? Are you in Brisbane for very long Chamindu? Studying or working or both?
  9. Do you still need a LH door? I discerned from a reply of yours that your LH door matched the RH one so must be 240Z not 260Z. Or were you talking about the door cards? Enjoying following your build BTW.
  10. That's good news. Be aware there are some differences between steering racks from early to late Zeds, typical running changes. Hopefully not an issue in your case. Do you have to get a 'road worthy' of some kind in Sri Lanka?
  11. Interesting - so you drive on the left there. So with LHD cars, do you have to convert them to RHD? How did your two LHD 240Zs end up there? How did you convert them to RHD? Did you find some RHD dashboards? Presumably you have to swap the wipers across to get the correct windscreen sweep coverage? It shouldn't be too hard to find some steering racks, but you can reckon on them being flogged out so reckon on getting new tie rod ends, inner knuckles and boots while you're here.
  12. Rather than shipping one to Sri Lanka wouldn't it be easier to simply rebuild yours?
  13. I agree, I have an early 260Z and the moustache bar is the opposite way to that in the 240Z diagram above - the curled ends face forward. But then it has an R200, which is longer than an R180. Presumably when later 260Zs went back to the R180 then the bar was reversed once more. Maybe that's why all the confusion.
  14. Nice work. All seems good then! The shells did change several times across the S30 series, also depending on the market sold in.
  15. Good to hear Eric, the project is an absolute credit to you. Awesome work! And the colour really blings in exterior daylight if that makes sense. BTW, what does one do to open Photobucket? Does one have to subscribe?
  16. Either Nissan or the Datsun parts guy at Caboolture was advertising them not too long ago. They do come in LH and RH versions, but from what I see the basic handle is the same and the connector and spring can be swapped across.
  17. I suspect the square-ended door handle is off a Datsun 1200 or Stanza or something like that. Your driver's door looks to me to be 240Z, with the two apertures at the bottom; whereas AFAIK a 260Z door just has one large central aperture at the bottom. Edit: just behind the winder pivot on your driver's door is an oval shaped pressing - that shaping accommodates the spring on a 240Z winder. The 260Z doesn't have that, as the spring is mounted on the other side of the mechanism. Post a photo of the inside face of the other door and we can soon see if it's 240 or 260Z.
  18. Hmm, I don't know that the blue tint is all that rare, the NZ-new (including mine) and JDM cars seem to have it. Don't know about other markets like the UK and Nth America. Maybe it was an option, anyone know? The blue tint is very pale, whereas clear glass if anything has a slight greenish tinge to it, as seen in the photos above.
  19. If you are to have retractor belts then the retractor can't use the existing lower mount anyway as that impedes seat travel, a no-no under the ADRs.
  20. The inner door face of the 260Z door is quite different in appearance to that of the 240Z. The cut-outs or apertures are different in size, shape and location. The impressing for the winder mechanism is very different due to the winder spring being on the opposing side of the winder mechanism for the 260Z vs the 240Z. I don't see how the winder mechanism can be interchanged between the two. But if the inner faces of your doors are very similar but not exactly the same then more likely you have different 240Z doors - there were at least 2 different versions I believe. The main thing is whether your door card trims - a matching pair? - will comfortably clip on what you have or whether you have to relocate some of the fixing points in the inner door face including that of the winder handle to suit the door cards.
  21. 240Z, early 260Z 2-seat and late 260Z winder mechanisms are all slightly different in their layout geometry and of course that means that their respective door trims don't just easily interchange. The 240Z winder differs from both the 260Z types in having its winder spring mounted on the other side, making for differing shapings to the respective door inner faces. There may well be a number of 240Zs and 260Zs around with transposed doors following accident repairs, sounds like two examples discussed above. Repairers must have found ways to adapt the original door trims to suit replacement doors somehow but I can't imagine it would be easy with many mounting holes all 'off'.
  22. FWIW. very early 260Zs like mine have 51mm struts just like the preceeding 240Zs. But the hubs are different, as HS30-H points out. 240Z and 2-seater 260Z doors are different on the inner skin - obviously different door trims, but also different geometry and spring locations for the latch/lock mechanism and window winders, all mean that some modification and reworking is required to make a 260Z door fit a 240Z and vice versa.
  23. Your car appears to have the late-260Z taller radiator set-up; I can see what appears to be the radiator bottom tank hanging out below the valance panels in the front-on photo.
  24. Personally I'd stick to the original colour range. However, tastes are different today from what they were back in the '70s. Also, paint technology has moved on a great deal. 'Modern' colours often have more colour depth than those back in the day, and the paint systems are different too. So sometimes it's not easy to match 'old' colours closely and one has to experiment a bit. Unlike American cars, the body colour is not recorded on a door tag but on a sticker on the radiator support. So if you pull a Zed apart and remove every trace of the old body colour then no-one subsequently would know what colour the car was originally anyway, except from some old photos. At the end of the day it's your car rebuilt to your tastes. And if those are pretty much those of the rest of the car loving fraternity then on-selling the car later shouldn't be an issue. Some colours sell better than others of course, worth bearing in mind.
  25. Tiny very thin flat screwdriver.....
