pauly_adams
  1. heres epp 1, ask and you shall receive
  2. your allowed 15% increase of the largest engine installed in the car and 25% increase in power, the L28e came out in a s30 chasis so no problem putting a L28 in it, there is even a bit of confusion if you can legally put a rb20/25det into a 280zx as they bolt in with factory mounting from a rb20det and the rta engine guidelines state as above 15% capacity increase and 25% power with no structural mods is allowed without a engineers cert.
  3. its 96db and 50cm from the exhaust at a 45 angle, they changed the laws again. most places doing z blue slip wont even check the noise mine was at 100db+ and they passed it, as for your wipers pull of the front cowling and clean the motor and arms going to the motor with WD40
  4. just seen the third one, nearly lost my stomach contents, need less to say my misses was in stitches
  5. that is a real stomach churner I made it about 40sec and that's it, but my misses will love it
  6. still havnt got the engine sorted yet mate, that's sad to hear you wont make it but your not the only one, my wedding is whats stopping me
  7. appears to be a r200 diff
  8. was manual and has both, I will confirm diff though as im fairly sure it was R180
  9. simon showing off some car porn
  10. they look like a good product, I first thought that for $900 they where a bit pricy but then I read further and the come with shocks also
  11. its worth coming to get there is still a good body on it, much better then many I have seen but far from perfect. I need it gone as I might be moving over to NZ in the next few weeks so drop me a offer nothing silly though it cost me $750 so far so my loss
  12. what sort of cost where these
  13. pauly_adams
    Waterless coolant
    im highly considering going this way now
  14. hi George, I just use a thick wall rubber hose, I run a L28et in my 280zx and have had no issues over the last few years
  15. my local guys are good here, not rude will ring if it says no longer available, and will check if there is a new part number for a older part. they are very nice and flash now chris. here is there number (02) 6051 5555
  16. will do guys ill try to get him into gear and pull them all out so we can see whats in there, he did tell me there is a guy he knows who has a massive pile of them, where he got his from I will sus it out
  17. try Nissan in Wodonga they are actuly very good to deal with
  18. sorry nismoz is right im so use to dealing with drift cars, welding the diff on a road car= bad idea,(sorry and im a bit ashamed of saying it) if they break your in all sorts of trouble generally ends in disaster, you can change the centre to a r180 from a Subaru much more suitable.
  19. I still need to go though my mates 6 foot high pile of old bikes for you dimitri
  20. if you get s12+8 callipers they are a strait bolt on with the 2+2, if the diff doesn't handle it just swap it out put a new one in or weld it up so its locked
  21. yes it should as long as its in good condition, you should be fine as its technicaly just a engine swap that requires no engineering or certificate. i would however change the front brakes to hilux calipers at least
  22. yeh the bolt works well , if you drill the clutch fork you can weld a nut onto it, then you can adjust as you wish
  23. your r180 will handle it my L28et is putting out 180kw at the rears and mines fine but mines also a lsd, no idea where it came from though
  24. need this gone guys $500ono would suit someone wanting a strait shell or good interior
  25. I remember taking out the front sway bar and made access a bit easier, just mark your steering rack position with a paint pen then unbolt change bushes and bolt back up, not the biggest job too do wait until you need to do the rear of the car that is the fun part
