  • 1 month later...
Cool good to have them on the road isn't it? You forget how fun they are and the attention they grab.
it is the best feel i waked up 100km on it that day .every one looks or trys to race you
Looks awesome Bryan - great work!  Who did you do your club reg with?
its at djm getting a tune up atm .team tuffcore its just a group of mates that drift who opened a club so every one knows each other.
  • 2 months later...
  • 3 weeks later...
Some new shoes in 15x8 +20 front has nankan semi slicks and rears are skiders atm till i get some 255 60 15s mikys
Im going to attempt fuel injection conversion this weekend as i have all the kit siting there.
will be all stock kit then upgrading to a tunebale ecu with ls1 coils and bigger tb sr or xf with cable throttle.
Thinking of upgrading my diff theirs a 4.64 ratio diff for sale atm would that be street able ??
Heres a diagram i found hopefully it helps but if any one has better info pls link me
11330009_10152957099896476_4325296016462165701_n.jpg?oh=dd3df88fd9374ebb45ef3f293a23857e&oe=55F35286&__gda__=1442830471_26d84b4f09301d0000a52af8c344feff
Hi Bryan,
mate your Zed is looking good, congrats. Lately we have the 2+2 boys showing some really outstanding cars and maybe changing some perceptions. I put a 4.11 diff in mine when I found 3.5 was no fun with triples and mild cam-breaking speed limits just to hear the sound of the triples and be on cam ;D
My 2cents, 4.64 is pretty high for street however might be ok for 255 60 15. Thats going to have a big rolling diameter, might look a bit odd but hey, it's your car. Drag car look?
Just a couple of questions for you, what size wheels/tyres are you running on those two pics on you just posted?
cheers, Mike
4.6 is too short for driving on a highway with a standard 5th gear.
Which standard fifth gear?
The 255/60x15's he is proposing, wont be fine, with a 4.6 diff at highway speeds?
Cars with 225/50x15, and standard fifth gear of 0.83 and 4.6 diffs are quite capable of more than double legal highway speeds. From my experience.
A 255/60 tyre will romp it in.
I'm happy with the 4.6 in my car. I'm running 205/60 15's. It's great for normal street driving and Wakefield Park.
But as d3coy suggests, long highway trips would be a bit of a drone.
I also have a 3.9 for highway or long tracks.  :)
Mick
Hi Bryan,
cheers, Mike
woops i ment 225 and yes hoping to see it run down the 1/4 eventually .
first pic is ssr wantanbe in 15x7 +20 ish next set 15x8+20 enki rpf1s i will be going to +0 soon
  • 6 months later...
was time to get a tune on my frst engine build
l28
n42 head with 68 deg works copy
.40 over bore with dished pistons
high flow oil pump
stock manifold and cheap extractors
i wasnt to happy with the power out put but was my firsst attempt at building a motor plan to try some new things in the new year with a modified intake and suggestions or tips would awsome .car drives amazingly now.
as for original steer is fine if u using original pizza cutter wheels and tyres.
but ask any of the guys with 17"x8" with 235 tyres and drive the car daily. it won't be fine.
u be sick of it within a week.
so running bigger wheels and tyres and driving it as a daily u will hate it.
Not really, If the offset is correct you can park them using one hand and i had 245's fitted.
  • 3 years later...
Few years on I find myself still enjoying the car and really haven’t had any issues but I do feel it’s time for upgrades again so I find myself looking and reading up on things again.
to do list
new exhaust to fix leaks .
suspension   Probably to bc coilovers as the current setup is nothing special.
new front air dam.
heads getting a little noisy so ill adjust the valve clearness or build another one.
