Simestime Posted May 27, 2018 Posted May 27, 2018 Hi guys,recently i gave my dad a couple of clocks to see if he could fix them. He went right over them and did fix them. So i gave him another members clock to fix and he repaired this one too! So i have asked him if he would like me to post an ad on here to generate some business for him,which he obviously accepted. My dads retired these days but still has some light work coming in from wesfarmers as he repairs electric fences for them. Im just trying to keep dad active and help you guys out too with this offer as i know theres not too many working clocks in the zeds out there.Im sure he'd be able to takle the rally clocks also. Because of the time involved in this repair hes asking only $50 per clock plus postage.He will only fix the clock, not refurbishing the entire housing and making it look pretty. As it takes about 2 hrs to fault find, replace dead component's and then get the time calibrated over a couple of days. If your interested PM me and ill forward on my dads details to you. Thanks,Simon. RAP260, Zedhead, AndBir and 1 other 4 Quote
dat240z Posted May 27, 2018 Posted May 27, 2018 Silly question, but can you reach the clock in the 240z without removing the entire dash? Heater panel removed should provide enough yeah? Andrew_L26 1 Quote
Cozza Posted May 27, 2018 Posted May 27, 2018 Quite possibly but I got mine out after removing the glove box. Mind you, I was a little younger then and more of a contortionist Simestime 1 Quote
Andrew_L26 Posted May 27, 2018 Posted May 27, 2018 Silly question, but can you reach the clock in the 240z without removing the entire dash? Heater panel removed should provide enough yeah? Should be able to get it out if you take the heater panel out. Once the heater panel is out there is one screw under the clock holding the it in. If that fails then it can be helpful to remove the glovebox as mentioned by Cozza. Andrew Simestime 1 Quote
Riceburner Posted May 27, 2018 Posted May 27, 2018 Glove box door and glove box inner out and you can get to all three of the middle gauges fairly easy. Simestime and peter t 2 Quote
Administrators gav240z Posted May 27, 2018 Administrators Posted May 27, 2018 What kind of clocks has he worked on so far? Early 240z clocks sound different to the ones you describe. Quote
Simestime Posted May 27, 2018 Author Posted May 27, 2018 My clocks are from early 75 260z 2+2 and the other members clock was 77. These clocks were slightly different in bold nubering but yes they are different from the 240z clock which he hasnt worked on yet. But they are the same principle being pre quartz design and im certain hes up to the job. Hes very electronic savy and was a tv technician when i was a kid so this simple circuit board definitely doesn't overwhelm him. I wouldn't post this ad if i thought id be wasting peoples time. He has even gone to the extent of ordering bulk capacitors and resistors that hes has found to be the failed components in the clocks so far. Zedhead 1 Quote
chamboz Posted May 27, 2018 Posted May 27, 2018 Silly question, but can you reach the clock in the 240z without removing the entire dash? Heater panel removed should provide enough yeah? Andrews got it sorted, its really simple as i found the other day; Remove the 4 screws holding your heater panel, once your in behind that there's one screw under the clock on the 'strap' holding it in place, take that out then it just takes a bit of a jiggle and the undoing of an electrical connector then the clock will pop right out, the 'strap' stays attached to the dash. Only a 5 min job Andrew_L26 1 Quote
peter t Posted May 28, 2018 Posted May 28, 2018 Got two spare clocks repaired that I tried to sell but no one wanted them. Out of 75 2+2 Quote
Simestime Posted May 28, 2018 Author Posted May 28, 2018 Yes definitely interested mate. Ill pm you. Quote
lightmaster240z Posted May 28, 2018 Posted May 28, 2018 This sound good to me but the last five min job I did is still going on and it been eight months so far gav240z 1 Quote
Simestime Posted June 5, 2018 Author Posted June 5, 2018 Dad is sending back a fixed Jeco clock to its owner today. The same member will be forwarding on another one or two for repair now. So he has now worked on all the pre quartz clocks and is willing and has all parts for a quick turn around. Pull your finger out boys as dad does have health issues and wont be round forever. Just pm me and ill forward on his details. I dont get anything from this,just piece of mind knowing hes pre occupied with somthing to do. RAP260 and gav240z 2 Quote
Administrators gav240z Posted June 5, 2018 Administrators Posted June 5, 2018 I've got a few sitting in a box. Need to pull the 1 out of HS30 01415 and replace it with a Quartz modified Jeco. May send them up to your dad then. Quote
Simestime Posted June 5, 2018 Author Posted June 5, 2018 Good stuff Gav. Ill pm you his details and let him know who you are. Thanks. Quote
Administrators gav240z Posted June 5, 2018 Administrators Posted June 5, 2018 No rush might be a little way off yet. Quote
BMT Posted June 12, 2018 Posted June 12, 2018 On 6/5/2018 at 4:53 PM, Simestime said: Dad is sending back a fixed Jeco clock to its owner today. The same member will be forwarding on another one or two for repair now. So he has now worked on all the pre quartz clocks and is willing and has all parts for a quick turn around. Pull your finger out boys as dad does have health issues and wont be round forever. Just pm me and ill forward on his details. I dont get anything from this,just piece of mind knowing hes pre occupied with somthing to do. Quick note to say we received the clock back very promptly and is now installed and working well. Many thanks to James for a job well done. Second clock on its way. PB260Z, gav240z and Simestime 1 2 Quote
Simestime Posted October 2, 2018 Author Posted October 2, 2018 I would like to send out a big thanks to the many members who have given my old man their clocks to be repaired. He has been very successful in getting them all working again. Could i ask that the people that he has helped out to write some feedback on here on your experience so people sitting on the fence can feel at ease and not be hesitant to send theirs off too. Cheers guys gav240z 1 Quote
Administrators gav240z Posted October 2, 2018 Administrators Posted October 2, 2018 Hey mate, I started to have a play with mine and got a few of them working. So I decided to keep going, however I went to JayCar to find the replacement capacitors and resistors for the later 260z clocks, but haven't had a go at repairing it yet. If that fails I'll send you mine for the old man to fix. Simestime 1 Quote
zeds4ever Posted October 2, 2018 Posted October 2, 2018 Fixed mine for me & it hasn't missed a beat . Regards : Alan . Simestime 1 Quote
greggy2710 Posted October 4, 2018 Posted October 4, 2018 I just wanted to say a huge shoutout and thanks to Jim for fixing my clock. My clock was intermittent and needed a good thumb to start it. I sent it to Jim and he found pick up coil was open circuit on one winding. He even got hold of a microscope to try and find the brake. He has worked miracles and got the clock working again. He is a legend. Can’t recommend his work highly enough. Quote
