C.A.R. Posted December 1, 2016 Posted December 1, 2016 SOLD. L28 3.3ltr short engine. 89mm bore x 89mm stoke = 3322cc Engineered by Les Collins. Built by myself under his direct guidance. F54 block. Acid dipped, sonic tested & offset bored to 89mm, & finial Diamond honed to exact clearance. Deck milled parallel to crank tunnel centreline. Clearanced crankcase, de-burred & painted in Gyptal. New gallery plugs. Blanked oil pressure relief port. Standard sump & pickup. Modified 89mm stroke crankshaft, oil gallery plugs tapped & plugged. Custom CNC billet steel 8.8kg flywheel to suit crank (no clutch assy). 137mm I-beam connecting rods with ARP2000 rod bolts. Custom SPS 89mm forged pistons – designed to work with a P90 head. New timing chain guides & new Kameari HD timing chain. New OEM front timing cover (de-burred, polished & water-jet blasted) fitted with replated bolts. New Water pump. *This short engine requires a P90 head to be used.* Depending on the specification of the head, cam & induction, this short engine had the potential to make 330hp & 280ft’lbs of torque. Please note: this IS NOT a race engine! I built this as a fast road engine for my 240Z only. I have the full build sheet (in Excel) available to prospective buyers Lots of time & money has been spent on this, so my loss is your gain. To recreate this short engine now, would cost over $14,000, so I’m selling below cost!!! SOLD. Contact me here via PM, or CALL me on: Zero Four Zero Zero Zero Five Four Five Seven Two Payment by cash, certified bank cheque or EFT payment ONLY. Any further information / questions can also be forwarded to Les Collins Racing. Option 2: I can supply this with a rebuilt P90 & suitable camshaft, and make it a complete long motor for extra $. Please PM me if you’d like to discuss this option. Any question pertaining to this engine, please ask J Cheers, Locky. Looks like this, minus the head & tappet cover: gav240z, locklock and scott 3 Quote
Moderators PB260Z Posted December 1, 2016 Moderators Posted December 1, 2016 ....... and let the speculation on what is happening begin Quote
C.A.R. Posted December 1, 2016 Author Posted December 1, 2016 ....... and let the speculation on what is happening begin I'm going to run an LSX... PB260Z and d3c0y 2 Quote
Cozza Posted December 1, 2016 Posted December 1, 2016 Good idea Lurch. Good power to weight I hear. ? Quote
PZG302 Posted December 1, 2016 Posted December 1, 2016 I'm going to run an LSX... With auto? andyk_79 1 Quote
C.A.R. Posted December 1, 2016 Author Posted December 1, 2016 With auto? Yes, with a 280ZX bodykit. Andrew_L26 and andyk_79 2 Quote
Moderators PB260Z Posted December 1, 2016 Moderators Posted December 1, 2016 Yes, with a 280ZX bodykit.Do you need a hand cutting the T-Tops in ?Have just finished sharpening the chainsaw Andrew_L26, andyk_79 and dalee 3 Quote
Agno Posted December 2, 2016 Posted December 2, 2016 LSX454 + powerglide + 9 inch should make your car boogey pretty good, you'll just need to make yourself a fancy 6 into 8 port intake manifold to keep the EFI Quote
CBR Jeff Posted December 2, 2016 Posted December 2, 2016 (edited) Rumour has it he will be selling all of his z car bits and is taking up lawn bowls....................Full time........... Jeff Edited December 2, 2016 by CBR Jeff Quote
C.A.R. Posted December 13, 2016 Author Posted December 13, 2016 SOLD pending payment. locklock and scott 2 Quote
scott Posted December 13, 2016 Posted December 13, 2016 I think Adam will be very happy with this setup Ponyo240z 1 Quote
C.A.R. Posted December 13, 2016 Author Posted December 13, 2016 I think Adam will be very happy with this setup That much grunt in a K will be downright scary...! Ponyo240z 1 Quote
