Administrators gav240z Posted August 13, 2018 Author Administrators Posted August 13, 2018 Been a while between posts. Finally cut off the old lower section, and tack welded in the new piece. Had quite a bit of trouble creating the pressed section, I couldn't quite replicate the original shape exactly. But got close. Since it's hidden behind a bumper it won't be obvious. I also created the exhaust cut out section, but it's not exactly the same as original. I am contemplating cutting out the original section and welding it in. Either that or tidy up this piece more and perhaps use a bit of body filler to sculpt it. I still have to create the bumper mounting points (pressed areas) I didn't want to rely on my template. So I decided I'd offer it up to the car and trace out the exact areas that need modifying and then modify it. RAP260, Zedhead and KatoKid 3 Quote
Administrators gav240z Posted August 20, 2018 Author Administrators Posted August 20, 2018 More progress. Really just tack welding the and upper pieces together. Ran out of time to do more. Photos below. jeff43, CBR Jeff, Zedhead and 1 other 4 Quote
Administrators gav240z Posted December 9, 2018 Author Administrators Posted December 9, 2018 Spent some time this afternoon tracing out the original valance section (tail lamp sections). Here it is for reference. Which looks like this once traced out. Transferred to my repaired panel. Test fit 1 side done. Time to do the other side also. Still need to file it up and hammer dolly the folds better. Top and bottom pieces haven't been joined yet. But already you can see it taking shape. Still plenty of work to do, I must buy a compressor (and air tools) + oxy/acetylene welder because tafe has ended for the year and I don't have either of those tools at home. OdinZ and CBR Jeff 2 Quote
Administrators gav240z Posted March 4, 2019 Author Administrators Posted March 4, 2019 Slow progress, but progress none the less. CBR Jeff and OdinZ 2 Quote
Administrators gav240z Posted March 12, 2019 Author Administrators Posted March 12, 2019 So attached are some of the images of progress. You can see the ends are not done yet. But importantly you can see how close the gap is with an accurate scribe line. The X are there to help make sure the welds align with where the scribe was made since as you move along and weld things can shift. Basically I couldn't get the lower portion to follow the right curve, so by welding it into place and following the line of the upper half, it's forcing it to align with that curve. C.A.R., OdinZ and George 3 Quote
Administrators gav240z Posted May 8, 2019 Author Administrators Posted May 8, 2019 Slowly getting there, need to clean up the welds a bit still, and then put the brackets on that are missing for the rear garnish and the interior rear trim to clip into (since they were all missing as a result of the rusted areas). The thing about oxy welding is it looks really rough until you wirebrush it or sandblast it, then once all the surfaces have a uniform finish it looks a lot better. I will try and take a photo of how it looks underneath the slam panel area, since it actually looks quiet seamless and neat. My welding abilities have come quite far after working on this, which is what I wanted. Although I may re-work sections if I decide I'm unhappy with the finish and I may revisit the other piece I made and re-do sections on that again. It's only taken me what 4 years to get his far with it? CBR Jeff and George 2 Quote
