Linton
Everything posted by Linton
  1. Faceboook::site datsun_restoration_exchange. dont go any where near it..... the guy I bought from an {ADMIN) is no longer a member but all of a sudden there is another new administrator different name.
  2. As the title suggests, I bought a car with out any boot plastics need black but I will take any colour, any help would be appreciated Linton
  3. As the title suggests, I bought a car with out any boot plastics need black but I will take any colour, any help would be appreciated Linton
  4. always thought I was pretty savvy to these buggars, but yeah got done 3 weeks ago on a so called datsun web site on facebook.
  5. sorry everyone we cant make it, cant fix the brakes dunno whats wrong, and the boss wont give me Monday off as well, so merry Xmas to you all have a safe and wonderful Xmas and new year "spoiler and wheels gone" Linton and Cathie Portland.
  6. Hi all, my rear brakes have finally collapsed, having a devil of a time locating new cups i think the part number is p6283 anyone have any? or a source ? would be great Thanks Linton
  7. sorry every one cant make it this year, hope you have a great day merry Xmas... Linton
  8. Linton & Cathie hopefully once again a great day out
  9. gear box cross member between outer bush and chassis, main bolt
  10. i got two sets was going to chuck em as I have no where to store
  11. Linton
    VicZed 2021 BBQ
    Great Gordon, I have have booked the week off looking forward to it. I will bring your diff with me.
  12. old school testing.. to test your advance:.. forget the fsm... plug the vacuum line off, watching timing mark on pulley with timing light, rev engine up to about 1000 rpm watching the timing mark, it should increase with revs if it does its fine. remove the vacuum line off the controller while holding the revs at about 1000 rpm push the vacuum line onto the vacuum controller the timing mark should raise again. to test the vacuum controller pull the hose of the manifold which goes to the controller stick it in your gob and suck on it, if it works like a straw then the controller is stuffed. The fsm can cover various models and yours may not be the same as the book, it would not run if there was a major problem. my controller is stuffed and blocked off, I run the timing set to static 12-15 deg at Idle and it purrs and doesn't have any engine ping HTH
  13. Hi Gordon I have a z32 auto diff lying in the shed if its any good to you, out of my car TT its in good shape.
  14. very nice they wouldn't fix mine and sent it back
  15. I believe spacers like those are not legal in australia
  16. don't be sorry, I am sure some one else has had the same thought/idea, I didn't know that.
  17. "plugs read quite rich is it running lean" bit of a contradiction ,, maybe a vacuum leak at the manifold since only happening after the headers, the fact that you are making it richer suggests a vacuum leak, a really wet plug often will not come back to life unless the engine is running correctly to burn it off, and black soot will cause the plugs to short at the electrode, it might not be your problem but when mine was breaking down it was the coil, I removed the ballast fitted an electronic one off a commodore, small little black one, the engine will redline the tacho every time.
  18. he picked up mine
  19. the engine and radiator will need a good flush, gunk could be oil contamination but more likely it has had an anti freeze or stop leak added to the coolant which has congealed in the system, either way fix this first and worry about the carbies later, the jiggle valve faces the front of the housing, towards the radiator, it is in the right way.
  20. the fact that the radiator top tank is not getting hot after 5 min let alone 20 is a serious problem, did you put the thermostat in the right way up? maybe your engine is seizing not over fueling I wouldn't run it till you sort this out.... take out thermostat and refit the cover, remove the bottom hose and reverse flush the engine through the bottom hose, water should run out the water pump.. HTH
  21. Linton
    tripples
    no sorry gone long ago
  22. not looking likely for us this year very dissapointed
  23. Same as mine Ben 76" i used a commodore fuse block 3 live and an earth makes perfect sense, if I remember right 40,60,and 80 amps
  24. I got one too but locked out of melbourne
  25. the short answer is no it wont bolt up without modifying and yes the original filter is available i got one off ebay way back before the tripples my new car has su's but a 240z air cleaner
