Six_Shooter
  1. Yeah, if it isn't an L-series, LSx, or RB, they can't fathom why you would want to swap it. Oh and don't forget the Rota/Watanabe wheels.
  2. I don't know why there is so much emphasis on using ITBs. A well tuned and matched single throttle body system can work very well. Personally I have around $600 (CDN) into my EFI system, using a Delco ECM, and some other donor parts. Which is why I said at the elevated prices in Australia, this should be able to be replicated for around $1200 or so depending on the deals you find. If you went all new parts, then about 50 to 75% more I would say. Before you scoff at this, the Delco ECM has been proven reliable and very suited for performance applications. If you look on delcohacking.net, which is also an Australian based site, there is information about using the ECMs available in Australia, and even custom code to add some functions. My 240 has been running on a Delco ECM for about 3 years now, it was only carbureted for a few months after I bought it. I would do it all over again, even if I was offered a more expensive system. I like the fact that, if I ever needed to, I can find a replacement at a local wreckers, it has a limp home mode, is very easily adaptable, and has on board diagnostics.
  3. What would cost $10,000? Even at the elevated Australian prices I'd say it's possible to go EFI for around $1200, or so. Being a little innovative wouldn't hurt to help keep the costs down.
  4. If a '73 had a rear defroster, they would be horizontal lines. Only the '70 and if I remember correctly early '71 had the vertical lines. My '73, a US spec, has horizontal lines, FWIW.
  5. It's easier to get forgiveness than permission. lol Good luck with it.
  6. My GF's '65 will not (likely) have a Ford engine in it, if it does get a Ford engine, only the block will be Ford, the Head will be from a different brand. Yes, I said head, as in singular. leaning towards a turbo 4 cyl currently. I love the Tokyo Drift Mustang, the fact that the engine was an import engine in a domestic car (for me), is perfect. For all those same people that scoff at the Tokyo Drift Mustang, 99% of them would say it would be fine to drop a domestic (Ford/Chev/Dodge) into an import chassis. :facepalm:
  7. On my '73, the positive power is connected directly to the fan motor. The speed control is controlled on the ground side. The diagram above sort of shows this, but the one switch position would short the positive supply to ground. You say "AC fuse", does you car have Air Conditioning? This may change the way things were wired.
  8. The '73s I have seen have both an electric pump and a mechanical fuel pump.
  9. Just on the idea of donor lights, there are a lot of round or roundish head lights on new cars. The ones I have measured all measure larger in diameter than the original headlight. This would make it difficult to retrofit and not block some of the forward lens. The closest I have found so far has been about 1/2" larger in diameter and seems to be actually round. The Mini Cooper and new beetle head lights are huge compared to the S30.
  10. That's pretty cool.
  11. It's the same "problem" everywhere... People just copy many of the same elements from other S30s that are known to look, work well, and be liked. There are only a few of us that will push the envelope and do something different. I just want to rip into mine, but I need to get the girlfriend's Mustang going first.
  12. I guess I should have really said "not being used", instead of old. Really it doesn't matter where they are from, no preferred state, and no preference on age, just something to hang on the wall beside all the other plates. Most of his are from Canada and the States, he some from Hawaii, and Guatamala, where his Cutlass came from. I just figured it would be nice to get him some from other places too. Post up some pictures of what you have and give me an idea of what you want for them. I don't want to pay much, especially since shipping will be a bit pricey, but let me know.
  13. I would like to get a few old licence plates, singles are fine. A friend of mine collects licence plates and sounded like he would like some from Australia, something that would be especially rare in Canada. lol Let me know what you have. Thanks
  14. ROFL 100 amps..... That's more than what the stock alternator would put out by almost 3 times. It would be best to know what brand and model of pump you have and use their recommendations for fuse and wire gauge. Most electric fuel pumps will run on a 10 amp fuse. The thing to make sure of is that the fuse you are using is not a higher rating than the current capacity of the wire. The use of a fuse is to protect the car, not the equipment it is attached to. The fuse should blow if there is a short in the wire or a malfunction of the equipment that it is attached to. This is why you will find fuses generally nearer the source of power than at or near a component. The exception is aftermarket equipment where they install a fuse in the equipment, but the purpose is the same, to protect the car, by blowing the fuse in the even that a problem occurs inside that piece of equipment.
  15. You can use R200 output flanges from a 280ZX without CV shafts, maybe late 260Z (280Z here in North America) will work as well, I don't know for sure that they are the same as the 280ZX flanges. This would allow you to retain the original axles shafts. I would upgrade to the 300ZX (Z31) anyway, since they are stronger and in my experience smoother while driving than the universal equipped shafts.
  16. I was in contact with Antus a little while ago when they were looking for pointers. Last update I saw was discovering the turbo had issues. GM EFI really is easily configurable, and inexpensive to boot.
  17. Wow, I think I might finally have to invest in a PS3 and GT5.
  18. Eff, no!!! That thing is FUGLY!!! I agree there seems to be a lot of Mazda influence in the front end, so much so, I had to look closely to make sure that was a Nissan logo on there.
  19. It definitely is a photoshop, the person who did it made one fatal mistake. They did put a lot of thought into it though, trying to keep the wheelbase as short as a 2+2, though it would likely be a little longer in actuality, but they moved the entire cabin forward, notice the shortened fenders and lack of cowl. I would say this would seriously hurt leg room, unless switching to a 4 cylinder (or other shorter engine) to move the firewall forward as well. That fatal mistake was the windows on the other side of the car (driver side for me, being in Canada, passenger side for you Aussies. ), were not changed to reflect the changed door arrangement.
  20. I'm not sure what's worse... The spambot posting these links or that some people respond to the threads or create new ones like there is someone sitting there that might say "Oh, ok, I'll leave you alone now." I am an admin on a couple sites, one of which was getting hit everyday, sometimes several times a day by spambots, mostly for porn, but occasionally pills and other such items. I tried deleting and banning the IP addresses of each one, and that got tiresome, especially when I went back through the registered members and noticed the thousands of spambot accounts. Most were just in active. What I noticed was that most of these accounts were g-mail accounts, so I simply disallowed any new members with g-mail accounts from registering. It was an option in the Admin panel. Might be something to look into, common e-mail account providers.
  21. Sorry to go off topic here, but d3ecoy, I just read your sig and and it's friggen awesome! LOVE IT!
  22. Yep.... If I had a GF or wife tell me I couldn't spend any or more money on my hobbies, the next breath would be me telling her to walk out the door and never come back. A true GF or wife wouldn't tell you not to enjoy your hobbies.
  23. I think all 280ZXs had the R200. Here are a few pictures to compare with: R200: Beside an R180: Installed in a 240Z:
  24. I like it.
