737 -
opinions on the width of this front spoiler
Six_Shooter replied to .'s topic in Off Topic Discussions
What do you mean by "cut and shunted at the firewall?"
I just skipped through the last 4 or 5 videos, I can't stand listening to him talk... Man, it only got worse from the start, Only. Got. Worse. I too wonder about the owners reaction once he saw the painted carbon fibre flares.
Wow, some people make things WAY harder than they need to be on themselves. The guy is annoying too. I've just skipped through a few videos because he's so annoying. That is perfect material to show why I do my own work, and why people want me to do their for for them.
I find EFI to be more simple than carbs. Just FYI, there are a number of OEM EFI systems that have datalogging capabilities, the Z and ZX ECMs are not able to though. The GM ECM I use in my 240Z has an ALDL (Assembly Line Diagnostic Link) connector that has all sorts of info sent through it.
:facepalm: I never mentioned anything about sparks, besides "tiniest" is relative. The current draw form those items is more than enough to cause a test light to turn on, used as a ground connection.
Wow, there's 5 minutes I'll never get back.
Going back to the battery connection/test light discussion. There doesn't necessarily need to be something turned "on" to have a draw. Many items will have a draw when turned "off", to keep any volatile memories alive. Things such as radios (with clocks and electronic presets) have volatile memories that will draw a small amount of current. Clocks, especially mechanical clocks, will draw current, security systems will also draw a small amount of current when turned "off". Moving up to the current discussion... Before replacing anything, I would look at the AFM. From what I read, these can go out of adjusment and because of thier switch design, if it doesn't close almost fully at idle, this can cause problems. Also check your Throttle Position Switch. There are two switch points, not a range of voltage in the L28 EFI system. Closed throttle and Wide open throttle. If the closed throttle switch side is not adjusted properly or your throttle linkage is binding up and not allowing the throttle to close fully, that can also cause idle issues. One other thing that seems to be common is the flexible tube between the AFM and the throttle body can tear and this will cause inaccurate readings of the AFM, since unmetered air is allowed to enter the engine this way.
All cars should act the same way in regards to the test light, in this use. Placing the test light between the block and the negative terminal of the battery, with the negative battery connection removed would have the same result as placing the test light between the negative terminal of the battery and the negative battery connection. This completes the circuit, on ALL cars.
That is perfectly normal. With no negative battery connection, the entire car will have a "positive charge". When you attach the test light, to the negative terminal of the battery, and then touch the block, or chassis in this case as well, the test light will light, since the test light is basically becoming that ground connection, conversely, when you attach the negative battery connection the "positive charge" of the chassis/engine block/etc will cease and become the ground plane.
Fairlady Roadster - A moment of weakness...
Six_Shooter replied to gav240z's topic in General Discussions
I don't usually like the Roadsters, but this one has definatly caught my eye... -
If that really is what that guy said and worse believes, do me a favour and go give him a good smack, upside the head. That idea is so wrong. An overcharged battery only comes from a failed regulator (internal or external, doesn't matter), that would allow the voltage to go beyond the 14.4 it should be charging at. To charge a battery the alternator must maintain a voltage of 13.6. This keeps the battery charged and has extra for the car to run on. Even when you're not using lights, or heater fan, etc, the car still needs electricity for the ignition system, at the very least. The gauges all run off electricity, if there is EFI, the ECM needs electricity, so regardless of the accessories not being used, the car still needs power to run. The battery should only need to be charged after start, and only for a short period. The alternator runs the car, period, that is what powers the electricity in the car. The battery is only there for starting, well there is also that AC ripple filtering effect I mentioned earlier, but that's more of an added benefit than a design feature. The alternator is supposed to be charging all the time the car is running. This will NOT damage the battery in a properly operating system. The only time anything gets damaged from the alternator is when a part fails, such as the regulator.
One of the first things I did to my 240 was swap the stock alternator for a GM alternator. Mine was built for 160 amp output (left over from a never complete, long gone project), but a stock version at 105 amps would have suited fine. I would suggest a higher output alternator, even if it just a later internally regulated version, like the ones found in the 280ZX. IIRC these were around 60A or so. Still less than I like to see, but a vast improvement over the 35A OEM alternator. No car runs off the battery, with a "top up" from the alternator. If the car ran off the battery, then it would constantly drain, and the car would eventually shut off, relying on this mythical "top up". Before you get your panties in a knot, I've been working with automotive electrical and electronics for a couple decades now. I would also suggest to not remove the battery from a running car, especially anything with sensitive electronics, such as ECMs, or radios. When a battery is disconnected from a running vehicle there are large voltage spikes that happen, on top of that the battery also serves to smooth out, to the point of removing the AC ripple that is produced by an alternator.
Thought about a rotary, but the only "rotary" I will use will have multiple batteries connected to it. That's a different project though. Yes, For What It's Worth.
I know you're in Australia so it's understandable how you would mis-construe what I say as a compliment, but it is quite the opposite. SBCs are boring, they get swapped into everything, and not because they are "good", because they are popular, and parts are easy to get. The technology is quite outdated by this point, and smaller displacement GM engines (along with many other smaller displacement engines) are out performing the SBC, yet people STILL continue to swap SBCs in to most projects. I swapped an EFI SBC with a 700R4 into my boss' '62 Chevy Suburban, I tried to convince him to do something different, even swap in the extra L28 I had sitting around. In this discussion we got talking about how boring the SBC swap is, and how everyone does it. He said, "That's because you can fix it at the corner store", to which I replied, "If it's done right, you don't need to fix it at the corner store." I view the RB in a very similar light as the SBC, it's getting swapped into everything, and while it does work well, and has great potential (more than the SBC IMO), it gets boring when I see them swapped into many different cars. FWIW, I am very involved in building and upgrading two family toys that have SBCs, and wouldn't have them any different. The one was built by my late uncle originally, and while I am changing some details as it is going back together, the overall look is remaining the same as he wanted it to be. The other was built by my Grandfather, my late uncle and myself, I just recently got the EFI swap working properly on it, and uses an unique intake system.
Nope, no Nissan engines for me. I will NEVER install an RB in anything, they are the Small Block Chevy of import engines. Why the V6 I will be using? Because I like it and know it well. I can also make plenty of power from it.
That would be one of the last engines I would opt to install in a Silvia. I mean I like my L28 in my 240, but it's only still there, because I haven't had time to swap to a V6 yet, and I have some time and money invested in the turbo and EFI swap, so I want to continue to play with that for the next year or so, when I DO plan on swapping to my V6.
I'm Bored ... I know i'll make a strut brace : \
Six_Shooter replied to Scoota G's topic in Suspension
I used a rear strut tower brace in an Acura Integra to mount an amp and electronics racks from. The rack kept the strut tower straight between the two points it attached at, when the car was backed into a pole at about 120 kms/hr. -
I want my 6 and a half minutes back, the 5 for the video and another minute and half reading this thread.
The North American 240 had a dual filament bulb in the turn signal housing mounted low and on each corner. While I don't like the look of the 260/280Z front turn signals, you could install them into the 240, to be legal, but have a better look than the add on turn signals.
No. There is a large plug in the side of the tranny that needs to be removed to fill the tranny.
What's for dinner? lol
Which side is the fuel tank on????? I didn't know this!!
Six_Shooter replied to MaygZ's topic in Off Topic Discussions
While this works on many vehciles, I have found some that don't. Namely my Grandfather's 2001 Ford Ranger does not follow this. -
Ouch. But there is an early '70s Mustang, in the background. I would expect that to be pretty rare, even back then.
I have an Innovate LC-1 installed in my 240. It works fine, logging through the ECM. I've had it in there for about 2 seasons now. I recently bought the SLC_DIY from 14point7.com, actually I picked it up, since the guy that makes and sells them lives a little over an hour away from me. So far I must say I really like the SLC and it's capabilities. I bought it because my second LC-1 that I used to tune other vehicles, would connect through my serial to USB converter, it connects fine to the serial port on my desktop though. The native USB, built in display, and extra logging channels make this a steal for the price. I highly recommend it, even if you don't want to use the display, you can just leave that out. The SLC_DIY took me about 4 hours to assemble.
