737 -
I would love to get my hands on one of those Tamiya 240 models. I'm not usually into diecasts, but I have 4 Diecats S30s now, all aquired since I bought my 240. lol I have 3 1/18 scale 2 "1970", one is Green, the other is painted in a similar style to the BRE 240, but has no "BRE" specific markings. A 1/18 scale silver 240, this one actually has door window molding that stays on the door when it's opened! The 4th one sits on my computer desk between my monitors, it's a 1/24th scale orange, similar to ones already pictured in this thread with the large wheels and SR20 under the hood. I'm keeping my eye out for more. I've been VERY tempetd to buy at least one of the 3 RC car kits that are available now, but that's a lot of cake to sit on the shelf, and probably never use it as an RC, just because it would cost more cake to get it running.
I really like those resevoirs you made. Car looks good overall, I like the S30 in white, even though I would never own one that colour.
This: But in this colour: It was the green one (pictured above) as seen in the movie, The Rookie that caught my eye and have loved the Esprit ever since.
Thanks for the welcome, and kind words. I know parts are available in Oz to do very similar conversions, where the EFI is concerned. I'm on another forum that happens to be based in Australia as well, and there is some Oz specific Delco information discussed there. I hope to have some more updates soon. I was supposed to work on the 240 tonight, but a good friend of mine "conned" me into working on his audio install. lol Hopefully have some time tomorrow night, I need to get some stuff done by the weekend, we have our annual downtown Car show this Sunday. Is it accepted to post non Z related projects in here?
This past spring, I did some repair and upgrades. First order of buisness being the timing chain. I didn'realize just how bad it was until I removed the timing cover. I decided to completly remove the engine and tranny to make everything I needed to do easier. Anyone see a problem with this? lol New chain installed: After the timing chain was replaced and the new oil pan gasket was installed, I turned my attention to the rear suspension. I had the stock R180 with 3.54, I kept the R200 from the 280ZX parts car I bought for the tranny, cleaned that up, painted, new gear oil, etc. I was also given a proper R200 mustache bar for my car. Brackets all sand blasted, ready for paint. Brackets all painted: Ready for new parts: R200 all ready to go in: just a comparison picture: Diff and brackets installed: I also decided to install CV axles from a 300ZX at this time too. For the CV adaptors I used information found on the internet, along with some information discussed with a local Z enthusiats and some of my own interpretation. My Grandfather made the plates from some steel. I then sandblasted the companion flanges, welded and painted. It wasn't until I had them all together and in the car that I was informed about needing to grind down the end of the axles, like I had suspected when the passenger side (driver side to those of you that drive on the wrong side of the road. ) was difficult to get in. So out the axles came and more modifications. I had already flipped the cages on the first go through. CV adaptors welded to the companion flanges: Close up of my TIG welding. Comparison of CV companion flange and stock: CV shaft installed: I also decided to add a proper crank case EVAC port: Inside: The latest picture I have of the exterior. I have changed the front end. I am still working on this: After the timing chain and gears, it needs a new tune, and it's getting there, even smoother than last year as expected, but I think I may have lost some bottom end. Thanks for looking.
I decided to take the 240Z apart to do some up grades and other planned changes, but since my garage wasn't insulated (working on that), I didn't get a whole lot done when it was cold out, and then everyone wanted to me work on their vehicles (along with house hold chores), put the 240 on the back burner. I had been able to get the DIS conversion almost done, just some wiring to the ECM and power are all that was left at that point. I already had some parts that could be used for this conversion, due to needing to make an external crank position trigger system for my aformentioned GMC Jimmy. I retained the reluctor wheel and part of the CPS bracket, along with the ICM and coils. I started by having my grandfather (A retired machinist) redrill the reluctor wheel to fit the Datsun harmonic balancer. I then went ahead and made a new base for the CPS mount, with some adjustablility built into it. Some of the parts: The only glitch I've had was getting the stock (280Z) tach working with the DIS. The tach, which I installed last year, worked with the dizzy set-up connected to the negitive side of the coil. It seems that the output of the DIS module is too weak to trigger the 280Z tach (works fine with an Auto Meter tach), so a resistor needed to be bypassed inside the tach, now worked fine, until I hit about 5000 RPM, at which point the tach would either peg, or drop to zero. After doing some reading, I think this was due to the dwell of the tach signal getting too short at upper RPM for the tach to read correctly. I got tired of the ECM sitting on the floor, so I found a place to mount the ECM, so that I could take passengers, and not worry about them kicking the ECM or cables. The Brackets, which are made from textured ABS sheet: Attached to the ECM: I cut the MEMCAL cover to allow for the EMU cable to come out of the ECM without being pinched: Details of the ECM mounted: And finally, the view the passenger will have of the ECM: Interior In the time I've had the 240Z, I've had a few gauges set-ups in. Obviously I started with the original gauges, then I swapped the Amp gauge to a 280Z Volt meter. Swapped the 240 tach for a 280Z tach. I then wanted more information on my dash I swapped to this: I modified a quad gauge from a Turbo Sunbird GT gauge cluster, to fit into an original tach housing, this gave me, Oil pressure, Volts, Water Temp and Fuel Level. I then installed my boost gauge, a 2" tach and my AFR gauge into the trio location. I found that I really didn't like the small tach, part of that might have been due to the poor illumination of it, good thing it was a cheap tach to test the theory. The LEDs that I installed in the small tach (as seen here: shift light test ) were too far out of my peripheral vision to be useful, at least during the day. More pictures of the above gauge install HERE I decided to pull the rest of my Auto Meter gauges out of retirement, I Left the boost gauge where it was previously, I then installed the Oil Pressure and Water Temp gauges where the other trio gauges were. I gear clamped the volts and AFR gauges to my steering column and sat my fuel level gauge in the pocket left by leaving the fuse panel cover out of the car. I got sick of this ratty look, and decided to remove the radio, to install the 3 "loose" gauges into. I had other audio plans at the time. I retained the 280Z tach for a while, then decided that I needed something that will keep reading above 5000 RPM, so I borrowed a Pro-Comp 5" "tattle-tale" tach from my Grandfather, that isn't being used in any other project. I installed this where the original tach would have been, and it fits snug, without any retaining hardware. I also installed an Auto Meter Shift (which is now triggered by the ECM), on a custom arm above the tach, on top of the dash. Unfortunatly I don't have any pictures of this right now. I am now looking for a new gauge set-up for a few reasons. According to my datalogging program, and my known thermostat temp, the water temp gauge reads about 10 degrees low, this is an annoying quirk to me. The Boost gauge might read about 2 PSIG low, but there is some question to the accuracy of the datalogging definition file in this specific data output, so I will need to do some other testing before I condemn my boost gauge. I also want a gauge set-up that illuminates the font, graduations and needle directly, instead of the "flood lighting" that the early Sport Comp gauges I have now uses. I also want a radio again, the iPod and computer speakers just aren't cutting it, and as a Car Audio/Electronic Accessory Installation Technician, I should have something better for sound in my car. I may go back to the Quad gauge where the tach was, and install a digital tach/shift light above the dash or in one of the trio gauge locations. I also have a couple other ideas. Suspension I have made some suspension changes, which include Tokico strut inserts, a solid front diff mount and aluminium torque arm bushings. I have mostly suspension changes planned for this winter, along with getting to finishing off making the FMIC, relocating the air filter outside of the engine compartment and a few other changes. Misc Here is a picture from the track, before I turbo charged it. This is a picture of my girlfriend, and I at her brother's wedding, with the Datsun. Here you can see the 280ZX wheels I have on it currently. Video I have a few videos of the car. Please right click and save as, to save my bandwidth. Short Video of the old gauges installed Short video of the last time the car ran when it was naturally aspirated Short video of the car running just after getting the DIS swap done Some people said that it couldn't be done. LOL Video of the 240Z running down the track naturally asprirated Thanks for looking and reading through, let me know what you think.
I figured I'd start a build thread here, to show off some of my work and the car I am doing it in, or is it to? LOL I bought my 1973 240Z from a guy in Richland Washington that had bought it with the intent of installing a SBC, but decided it was too small for him. So after a couple months of flying out to see the car, finalizing the deal, and getting the car shipped I had my 240Z home, and in need of some TLC to get road worthy. It was a less than typical 240Z, brown (eww), Butterscotch interior (double Eww), and Automatic (tripple eww)! But it was solid underneath, and I got a good deal on it. The first thing I did was swap out the brakes, since they were in desperate need of repair. I decided on going 4 wheel disc, using Toyota 4 piston front calipers, and 280ZX rear disc set-up. I also had some electrical repair work to do, to get everything working right. The only pictures I seem to have of the exterior are after a couple months of driving it, so there are some changes that I had already made. I had already added the Spook by this point. Here is a picture of the rear, that I believe I took on the day I got it on the road, due to the old tires being on it, the mudflaps and a box of spare parts in the back, that came with the car when I purchased it. Tranny Well after driving the Datsun for a month in auto tranny form, I got sick of not using my left foot, and just resting my hand on the shifter, though I had been shifting it manually... I had also been able to locate the rest of the parts I needed, to complete the swap. I started the swap about 2 PM on a Saturday, and had most of it done by about 8 PM, just a few details I couldn't finish in the dark. Sunday came and didn't have much time and spent most of it trying to find a nut to install my solid front diff mount, which I couldn't find and re-surfacing the exhaust flange to eliminate the exhaust leak I had there. Then family obligations meant no more time to work on the Z. Monday I re-installed the exhaust, checked everything over, and then took it out for a drive. A manual Z is one billleeeeon times better than an auto Z. I'm using a Centerforce Dual Friction, and it grabs HARD!! The tires screaming for traction going into 3rd made that apparent. I was actually enjoying the L28 that's in this car, the auto just made that car a real dog, a real slow dog. This tranny was a 4 speed, since I couldn't locate a 5-speed at that time. On to the pics: Not enough pedals: Ahhh, that's better: This shifter only moves forward and back: This one also moves side to side. CFDF: This is where/how it was done: More pictures: http://domestic.3400z24.com/sixshooter/My%20vehicles/Datsun/Tranny%20swap/ Now I have a manual Z, just like it should have been. EFI and Turbocharging When I first got my 240, it had Weber down draft carbs that had seen better days. Here is the engine in the form that I recieved it: Well since I'm a fan of EFI and turbocharging I decided to play with the engine that was already in the car, which turned out to be an L28, F54 block, with a P90 head, N/A version from a 1981 or 1982 280ZX, is as far as I can narrow it down. I started with an N47 intake, which I cut off excess parts and smoothed out, it was also modified to accept "O-ring" injectors, which are more common than the stock "barbed" injectors, and many more sizes available. I also had a throttle body adaptor made to use a GM 3400 throttle body. This is a 56mm TB and would also serve to house a compatible IAC motor and proper range TPS. Onto the turbo and exhaust: I used a stock L28T exhaust manifold, and mated it to a Borg Warner turbo, pirated from a 6.5L diesel. This required the use of a small spacer between the manifold and turbine inlet. The wastegate actuator started as an actuator from a Pontiac Sunbird turbo, combined with some custom brackets and arms, it now controls the internal wastegate of the BW turbo. I chose that actuator, because I had one and it also opens at about 2 PSIG, giving me a large range of control over the pressures I am able to set. the exhaust is 3" from downpipe to tip. All fitted and TIG welded by yours truely. Muffler, a Moroso Spiro-flow and tip: Turning attention to the ECM and wiring: I first had to chose a place to come thorugh the firewall with the wiring. I used a stock firewall feed through ("grommet" ), from a 1988 Chevy Cavalier, since it was part of the harness I already had, prviously installed in my 1985 GMC Jimmy, that had a turbo 3.2L V6. Here is the ECM, which is in it's "easy to access" location. You can also see the grey "EMU cable" that attaches to my EPROM emulator to allow real time tuning. I use a custom code called "Code59", which is a modified version of a stock GM code called "$58", which was originally used in the Syclones, Typhoons and Turbo Sunbirds. This allows for Wide Band O2 fuel control, extended VE and spark tables (up to 30 PSIG!) and many other refinements that the developers have done and they plan even more! (www.code59.org for more information.) Working on the wiring: (Mostly) Complete harness: Fast forward to a running installation, which didn't have an intercooler, since I ran out of time, seeing as I got running the day before 2008 ZFest, and had a few other details to iron out. I had to turn the TB upside down due to the dizzy cap interfering with the TB linkage. I didn't really mind this since I was already planning on a DIS swap later on. (more on that later.) I've skipped over a lot of details, like modifying a 280Z speedo to accept a GM optical Vehicle Speed Sensor, oil supply and return for the turbo, modification of the throttle pedal to use a GM throttle cable from a Buick Century (IIRC), using a GM ignition control module between the 280Z dizzy and the ECM, E-fan install, electric fuel pump and larger fuel pick up from the tank, along with many little brackets and adaptors to make it all work together. I also swapped in a 5-speed from a 1981 280ZX that I bought for parts in this time. I was able to get it tuned and work well up to 10 PSIG, but the weather was turning cold and time to park it for the winter.
Switching to DIS depends on a few other things. Are you also wanting to add/retain EFI? I added DIS to my 240Z. I also added EFI. I used a DIS ignition system found on North American 60 degree V6s. They are plentiful here, and I had a few already at my disposal. lol I had already a few years ago built a 60 degree V6, for my truck, using a generation 1 block, that didn't have DIS provisions, with a later (generation 3) top end that basically required the use of DIS, so at the time my Grandfather and I designed and made an external crank trigger system for the DIS, that was installed between the crank pulley and harmonic balancer. I decided to use this reluctor wheel and part of the mount on my Datsun, since I was no longer using nor needed the DIS trigger for my truck. This wheel was redrilled for the Nissan crank pulley, and had a couple roll pins added for extra measure, and to ensure proper alignment at anytime it was removed, when re-installed. In the above picture you can see I am also setting up the crank position sensor mount location. I mounted the base off the same two bolts that are used for the timing tab. In the next picture you can see the crank position sensor parts. The part that the sensor is mounted to directly was left over from when it was installed on the truck. The plate is new for the Datsun, and made adjustable, though not nearly as much as the first time this was made. I found I really didn't need much, especially with the ability to tune for base settings in the ECM. I don't have any pictures of the final product, but this is pretty close. The only changes from this were a spacer that was installed behind the reluctor wheel to support the whell ahen a longer crank bolt was installed to hold the assembly all together. I didn't feel the 2 6mm bolts were enough to hold the wheel on, and didn't want to chance it. I don't have any pictures of the coil packs uploaded right now it seems. You could do something similar using Holden 3800 coil pack, I believe those engines are found in the Camira? I'm not entirely familar with the Holden line up, but another website I am on that deals specifically with Delco EFI seems to mention this car a lot, for parts like this. Ford EDIS is also another option. I'm not sure of the availability on Oz though. Both GM coil packs and the EDIS can be controlled by Mega Squirt (not a favorite EMS of mine), or by thier respective manufacturers ECMs. I am using a Delco (GM) ECM in my car, with some custom code that adds a bunch of functionality that the original code didn't have. I believe there is a Mega Squirt item called a Mega Jolt that is capable of controlling these DIS systems, if you just wanted DIS ignition. Both the GM systems and the Ford systems do have built in base timing, that can be used in bypass or test modes, and still run the engine without an ECM connected to them, but it's not recommended to drive the car that way. There are other more expensive aftermarket EMS options too.
