Six_Shooter
  1. Is there a reason you don't want an LED 3rd brake light? By the sounds of it your car isn't a resto, with an LS1... I used a LED 3rd brake light from a Chevy Astro van (north america market), and it fits well. Took a bit of work to get the wire through the hatch itself, but it really does blend in, and makes my car noticed when I hit the brakes. I wouldn't be surprised if the same light or something very similar was offered on a Holden. I'll get you some pictures if you are interested in seeing what I used. If you decide to install the light inside the glass, you really need to make a shield (not the word I want to use there, but can't think of the proper term), that directs basically encloses the area between the light and the glass, so that none of it gets reflected off the glass and to the interior. Without that shield, not as much light will make it through the glass, making it less effective that it could be.
  2. Yes it was. It was also the very first episode of Criminal Minds. Yep, ZX in that scene for sure. I'm not surprised by that, I just wish I paid more attention to the background cars back then, instead of just watching the hero car. There are 2 S30s in that video, a red one and a white one. I believe it's the same red one used in both the G6 video and Fast and Furious. The guy is on HybridZ.
  3. A weak battery will not cause that. So I would suggest to go ahead and adjust the regulator.
  4. Check the voltage, I'd bet dollars to buttons that the alternator is either under charging or overcharging, once the RPM rises enough. I'd have to say overcharging, looking at this thread and your other thread, where I think I also suggested to check the charge voltage..... Hmmm....
  5. That was the very first episode of Criminal Minds too.
  6. They belong to a couple guys on HybridZ. I remember the big hoola over this a while ago, but could never find the video that the S30s were in, just some really terrible video for this song. The worst part is I sat through the song more than a few times trying to find the video with the S30s.
  7. The sad thing is, that car is local to me, IIRC the guy lives a couple hours away, and I've never seen it in person. :-\ The Viper V10 240 is awesome... I know where there is a Viper V10 as well, that I could have VERY cheap. If it wasn't for insurance (biggest reason) or lack of cheap tuning options (semi-big reason) it would be going in my 240Z. I'll just swap to a different 6 cylinder...
  8. Vehicles run off the alternator, NOT the battery. The battery is only really there for starting purposes, it has the by-product of filtering out AC ripple from the alternator, but that is beyond the scope of this thread. A properly functioning alternator will charge at a voltage between 13.6 and 14.4V. Ideally 14.4v, but most alternators when they get warm go down to high 13 volts to low 14 volts. Remember battery voltage is 12.6 volts (6 cells at 2.1V each = 12.6V), and to have the alternator effectively run the car and recharge the battery after start, the voltage needs to be at least one ull volt higher than the battery voltage. So with the newer, properly functioning alternator, the vehicle now has proper voltage and the lights can function properly as well. I would check to make sure you're not over charging though, because that can be equally as bad as undercharging. If the charge voltage is over 14.4, this needs to be addressed as well.
  9. If you say so.... There's an extra R and a random Q... MAYBE Executer, but even then there is a random/extra R....
  10. What's EXRQTR?
  11. Huh... I just noticed that I now have negative karma..... What a useless thing to have on a forum...
  12. There is no one correct answer to this. There is no magic primary length or type of design that is "best". Sure one design might work best on one engine used in one application, but not for a similar or same engine in another application. General rules are, equal length headers generally created a "peakier" power range, where as unequal length will help create a broader power band. One engine might like longer primaries than another, one might like a dual system, another might like a single, some might like a stepped primary... The only way to truly find the "best" for your application is to try several different sets. Barring the ability to do that, an educated guess would likely get you what you want. grapeaperacing.com used to have a great article on exhaust design and theory, but seems to have removed it.
  13. I like it.
  14. To be different... If I wasn't planning to replace the L28 in my 240 next winter I would mess around with making a new intake for my car...
  15. There's a reason it's called "Armstrong Steering."
  16. Please excuse my ignorance here, but I'd like to understand more about the permits being discussed here. Just FYI, I'm not located in Australia and when I was there I wasn't nearly old enough to drive yet, so I didn't pay attention to9 the road laws back then. Can I get a brief description of these plates, and what is being changed here exactly? I'm wondering if this is similar to our "Historic" plates we have here.
  17. I've been trying for two days to have that video load, just minutes ago I sad *EFF* it, it's not worth it....
  18. I wouldn't use fog lights in place of headlights, the beam pattern is different and you may find that you have less illuminated in front of you than you have now.
  19. If only you weren't half way around the world.
  20. Technically the number would be infinite as long as the supply was upgraded to support as many fog lights as you wanted. The real question is how many do you want or need, and on what car?
  21. Ok, so you're just looking to modify the existing part, or modify the existing part then make a mold to create a completely new second part, that has the modifications? If you're just looking to modify it then it's a different ball of wax.
  22. No, in regards to a mold for copying an object, mold without the u is correct, mould with the "u "is what grows on left over pizza from the previous night's party. Trust me, I'm all about the "u"s in everything, including colour, and other words that aren't coming to me currently. Anyway... The wax does help fill in those small imperfections, but it is mostly to make the surface more "slick" to release the mold from the object you are copying, or buck. I don't always use the term buck, because I use it in very specific cases, but that's beside the point. The PVA is pretty much always used. The only exception is when you get a well seasoned mold, then the parts will release easier. This is likely due to a build up of wax and PVA that never quite gets washed or buffed away, but also likely due to some chemical changes with the heat created by curing resin. I would still prefer to use the PVA anyway, it's pretty cheap anyway, considering the alternative of having your part get stuck to the mold and then starting from scratch. One of the biggest things that will help with releasing the part from the mold is getting the correct draft when making the mold, here is where choosing how to place the mold on the buck, and how it will release is important. Sometimes when making the buck, adding some Plasticine, or modelers clay to add draft to the buck can help a lot. Then when you get to actually releasing the part, you will think you're breaking either the part or the mold, you will hear some pretty nasty cracking sounds as the part separates from the mold, this is heart wrenching the first few times you hear it, then after a while you get used to the sounds and start to learn how much of a separation there is by the intensity of the crack and the tone. You can buy some plastic wedges to help this go more smoothly too. I know my local-ish fiberglass supplier (about an hour and a half away) sold wedges of different shapes and sizes to get the part and mold separated. PVA is also water soluble, so sometimes using warm water poured between the mold and part will also help separate them. If you're looking to make production molds, don't skimp on the gel coat for this, get the tooling gel coat, it stands up to a lot more use than gel coat used to make the parts themselves.
  23. First off it's "molds" or "mold", no "u", mould with a u is something different. lol. If these will be one time use molds, you can make them just using fibreglass resin and chopped mat. Just make sure you put a release agent like wax and/or PVA. Add at least 3 layers. Release the mold from the panel you are taking a mold of, then, clamp it back on. The reason you release it and then clamp it back on is so that after the next step you will be able to get it back off the part you want to replicate. At this point use some material, to make a frame work to re-enforce the mold. There are a few techniques that can be used. For production molds and even some one time use molds, I have used plywood to create a frame work around the perimeter of the mold. Another technique I have used was to use copper pipe insulation that was cut in half, cardboard rolls, similar to what is used for paper towel or toilet paper cut in half also works well. With the wood technique you only need to bond the wood to the mold, with some fibreglass to create a stiff mold. Using the pipe insulation or cardboard tube technique you need to completely 'glass over the pieces added. This techniques relies on the added fibreglass to add the strength, after that has cured what you used to create that shape adds no structural value to the mold, it's just there to create a shape for the glass to use while curing. If this is your first time getting into using fibreglass, I strongly suggest starting with something smaller, to get a feel for the working time and mixture ratios before you try to mix up enough resin to create a mold for a large panel, which by the way, will usually be mixed up in smaller batches as you use them up, using new containers for each batch. The little bit of already curing resin can cause issues when you try to mix a new batch in that same container. Once the resin completly cures though, you can break out the hardened resin and re-use that container, provided it is a re-usable type. I like to use windshield washer fluid containers, like you would buy in the store, with one large flat side cut out. You also have a handle this way too. There's lots more to it, but that's some of the basics.
