737 -
So there will be a 3rd colour? This is why I won't be going metallic again with any of my vehicles, at least none with more than a few square feet of body area.
I've mounted dozens of CDI ignition boxes in the engine compartment, rarely had any problems. Any problems we did have seemed to be from inferior product. I've ran them from just adding a CDI box to a stock ignition system, to replacing everything including the dizzy. All incarnations seemed to work well. I swapped some coils around on some of the installations (mine) and couldn't say I noticed a difference between using a good stock coil to a good aftermarket coil. Currently I don't run a CDI box, simply because the GM DIS ignition system, that I use, is VERY strong in stock form. While it is nice to keep the electronics as cool as you can, some systems are designed to take the heat. Also I find most ignition module failures are from using cheap replacement units, and or not the right amount of heat sink compound.
7, 2?? Eh? I forgot about my boss' wife's plate. "TUKNROLL", I work at an upholstry shop. My previous boss (sorta still work there though), has the plate SJ X 4. With him, his wife and two kids, there are 4 of them, they all have the first and last initial of S and J.
Even glue can be cleaned off. Sound deadening to be effective should be attached, I.E. glued to the metal you want to deaden.
You shouldn't experiance any understeer from only .5 difference from front to back, 1" total difference in tire width, if you want to look at it per axle. One of the vehicles I drive has at least 2 feet of difference in tire tread from front axle to rear axle and experiance no understeer.
Car Town......Facebook Game........ 240z
Six_Shooter replied to Mr240z's topic in Off Topic Discussions
What's the point of the game? I'm workin' on Mafia Wars currently. -
My Favorite plates were the ones my uncle had on his Fiat, and should be going on the T-bucket, once we get it back together. OVR KLL
FS: 280ZX Bonnet, Hatch & Sugar Scoops - VGC!
Six_Shooter replied to C.A.R.'s topic in Parts and Tools for Sale
Can he deliver to Canad for free? LOL If only shipping wouldn't be so much. -
Hmmm... I was thinking about looking for a FairladyZ badge to put on my toolbox, but this would be a better way to go, and more easily attained. The 240Z badges look great, maybe I should get a set of those too, since my 240 didn't come with any badges.
My GM alternator was actually rebuilt by a rebuilder that I know, and brought up to 160 amps of output. I don't know what the Australian equivilant would be, but the case that I am using is what was used in the '87 to '94 Sunbirds with the 2.0L OHC. It does require some modification of the stock brackets, but not to bad to do. Here are some pictures of my alternator swap. http://domestic.3400z24.com/sixshooter/My%20vehicles/Datsun/Under%20hood/Alternator/
I'm not really one for convertables or removable tops, but I am starting to like this T-top look....
Locking the dizzy is pretty easy. Just find where the rotor attachment pivots on the main shaft and weld it together. If I get a chance I'll look for my old dizzy that I used before I swapped to DIS, and take a picture of what I did. I also used a Delco ECM (factory GM), to run my turbo L28 conversion. So far by trap speed calculations I was at about 200 wheel HP, and have only improved since then. Somewhere around 150 rwKw if I remember my conversion correctly. This is non intercooled and around 10 PSIG on a stock P90/F54 N/A combination, with an N47 intake, modified for 14mm O-ring injectors.
The ZX has an internally regulated alternator. Easiest is to just get a replacement alternator. You could have yours rebuilt, but usually takes a little longer. You may be able to buy a "rebuild kit" to replace some of the internals of the alternator, like the regulator and brushes. I used to rebuild my alternators, now I just buy rebilut ones, I can get more life and more output if I want, going this way. As another option you could look at installing a different alternator completly, I have installed a GM alternator in my 240.
FuFu'Z 240Z Project! 56K warning... too slow.
Six_Shooter replied to fufu's topic in Members Project(s) Journal
How did you manage that? -
I'm not a fan of the S130, but that defiantly helps.
What type of work is being performed? If the rear suspension is not going to be touched, you can use the LCAs. If the rear suspension is going to be worked on, you could use the box that is in front of the wheels well, where I believe a sway would have mounted. My car didn't come with a sway bar. I have used this location a few times now, sometimes for months at a time.
Well, I've had something very bad happen to the 240.... On Wednesday, a woman backed into my car, in a parking lot. :facepalm: So far the damage is the passenger fender (driver side for those down under), it is actually pushed down and back a bit, the candy scoop is damaged, and the front bumper has a crack in it, just below where her trailer hitch hit the candy scoop. It doesn't look like the inner structure is damaged, but hard to say until I pull it apart. The trailing edge of the bumper/air dam is about 3/4" (19mm) closer to the tire on that side, than it is on the other side. The headlight points down. I'm not sure if it's a good thing or a bad thing, but these cars hide the damage well. To the casual looker, it would be difficult to tell that anything was out of place, other than the obvious dent from the hitch itself. The woman was actually arguing with me that, this damage wasn`t there. I could tell right away the fender was pushed back, I didn`t realize at the time it was pushed down. So I started a claim with my insurance company today. This should be interesting...
I've used engine heat to release tight spark plugs in the past. It's a tricky thing to do with an aluminium head, but can be done.
Sweet, I like.
On Minday got in a new product that I am beta testing. It's called a Tuner View II, and while the actual Tuner View II has been around for a while, used in Hondas, with certain aftermarket tuning programs, the new part is the ALDLink, that allows it to be used with certain GM ECMs, more GM support will be added in the future. I'm Working with Craig from Moates tuning, and JR from HRTuning, to get the Code 59 side of it running well. Anyway onto the pictures... I was giddy even at this point... Unpacking... All the wonderful new toys.. There's some other stuff that I ordered from Moates in there as well, not just the TV II The Tuner View II itself. Craig put this in a case for me, with a suction cup. It can be ordered with or without the case. This is so new that Craig doesn't have ALDLink stickers yet, so there is the Xtreme ALDL sticker on it, which I think is a more fitting name for this than the orginal product. LOL This is what is different from the Xtreme ALDL, normally there would be an USB A connector here: A picture in my car. I have since changed the way I mount it in the car, because the suction cup started falling off. Because of this I think I have found exactly where I am going to install it. I should have more pictures later.
I just got a new addition in for the car today. It's called a TunerView II, original used in Hondas and certain tuning programs for the Hondas. There is a small company in the States that specializes in tuning equipment and has designed an interface to be used between certain OBD1 GM (Delco) ECMs and the TV II. I should have some pictures up later.
broken uni (universal joint) / CV conversion
Six_Shooter replied to .'s topic in Brakes / Drivetrain Components
I just swapped some stock Z31 CV axles into my 240 recently, just to prevent me from ever needing to make a thread like this. LOL So far, they are ok, I haven't been to the track, though I have beat on them a bit, so far no problems. I never broek a stock axle, but I have seen enough of these threads and have yet to see anyone break a Z31 CV axle at the power levels I'll be at while using them.
