737 -
It's a terrible show, and the guest team never won, from what I recall. They eff'd up so many cars on that show, NONE of the ones I saw were "good." There were just the lesser of two terrible "builds."
I just bought a SPAL kit to install in mine over the winter (the next few months, Northern Hemisphereer here ) I have used the SPAL kits on other vehicles and they work well. I had looked at using window motors from a Civic, that would have been not too bad to retrofit, but in the end I decided to just go with a pre made item instead. I can always do the custom stuff later if I feel I need to.
No thanks, the Bozuku style oil cooler does not belong on any car, let alone an S30...
Wow, lots of carnage there... It looks like the headless horseman made an appearance... Too bad too, my GF loves horses and figures/figurines.
That doesn't seem to work either...
Both the link and pics don't work for me.
Pics? I'm not sure I have ever known anyone that have had something like this happen to them before.
On the (genuine) external Walbro the inlet and outlet are the same size.
Are you sure it's a genuine Walbro? There is a flow indication on the genuine parts. You can just make out the arrow in this picture:
Yes, 110%. I pulled it from the donor car myself.
Which "260 box" is cited above as needing the shifter modification? I fitted a 280ZX box, same or similar to 260/280Z box, and used the 240 shifter. It cleared the floor without issue.
If there is an upholstery place local, you could get a new one made from patterns taken from the old one. You could then get it in a custom colour or texture/material. We do this regularly at work.
My first thought is ignition switch as well, though there are a few connections between. It would be a good idea to use a DMM attached at the start terminal of the solenoid, so that when this problem occurs you can see if there is power getting to the starter. This would pretty much eliminate the starter as the issue. Then work your way back to the ignition switch. Use the DMM to probe the start wire while turning it to crank and see if voltage is being passed through the ignition switch. Another worth while test, if the DMM shows no voltage being passed through the ignition switch, is to unplug the start wire from the starter and try again. In some cases a poor contact within a switch can cause high enough resistance that when there is a load on that circuit, no voltage will be shown on a DMM, but no load, and you can see voltage. It's more of a way to confirm a problem, than find it. I would also look at the power supply to the switch. Again, going back to a poor contact or connection, if the supply has a bad connection with the load of the starter it can go dead at start as well. Basically you want to follow the path back as far as you can until you find the point where the problem is.
What the rest of us are trying to explain nicely, is that fowl or colourful language on a, or at the very least this, forum is NOT appropriate. There are many reasons for this, I've already stated how I look at people that insist on using it. Chat that way with your mates or co-workers, just not around the forum. To spell it out a little more, some people would or will take offense to cursing being used on the forums in a post very much like these. Just looking under the dash at the bundled up wires won't tell you anything. I've repaired harness that looked perfectly fine on the outside, you know the harness wrap looked like brand new, no indications that there was anything wrong internally, slice it open however, and there were burnt wires. Again, I'm not saying there is for sure in your case, wires in the dash that are damaged, but until everything is running 100% again, you can NOT rule it out. I have seen some wires where they will get hot at either end, hot only in the middle, or hot at multiple points along it's length. Well if he said the snapped ground couldn't cause it, find a different mechanic, he obviously has very little understanding of automotive electrical, it could be the whole problem, or at least a contributor. Like I said long ago, fix what is known to need repair than move onto the questionable.
No projecting from me at all. In my many years in the service industries and cruising the intarweeb, I've come across many people and posts like this one, where there is question of being scammed simply because the person doesn't understand the procedure, or system. No I don't say "shivver" or "Oh phooey", I may say nothing at all or use colourful language, the difference is, I'm not stubbing my toe on the intarweeb , but later when I post about it (ok, I know, why would I post about it), I would use language that a grandfather would read to his grandkids about a situation that is humerus after the fact. (Why would a grandfather want to tell his grandkids about some random guy stubbing his toe? lol) Ok? You found someone that did the work necessary, not extra work. That's good. Many times it is hard to find someone like this. Did your mechanic remove the dash and inspect the wiring, or is he assuming that the wires inside the dash harness are fine? I'm not saying there IS a problem in there, but until the car is running 100% and/or you actually physically the each and every wire that is in that circuit and near it (physically and electrically), you don't know for sure. I've been playing the automotive repair and modification game, specifically dealing with electrical and electronics for a very long time. I've seen some "could never happens" happen, never rule anything out until it is 100% repaired and physically inspected. THIS^^^ If I had work done for me, that is exactly what I would do. I do all of my own automotive work, (other than safety inspections, similar to your rego inspections I beleive, and alignments), because I can't afford to pay someone else for it and I enjoy it, usually. lol When it comes to other services though, the above is the exact practice that people need to employ, find someone they can trust, and ask questions, along with agreeing on a set limit to go to, where additional authorization will be needed. I'll suggest that next time, you think there is something questionable about a service technician's repair procedure, ask questions, of the person doing the work, he may have a valid reason why. If it sounds like bull puckey, then research, and ask other people that might be able to verify or deny, but do so in a non accusatory manner, you'll get much better replies from the start.
Slightly off topic, but I'm glad I don't have to go through all of this where I live. When we replace back seats with sub enclosures, we just simply do it. The only thing that would be checked when someone gets pulled over is that there are enough seat belts for the number occupants. If there are no seats, there is no issue. It seems from some posts that if you want to set something in the trunk to transport it home, you need to get an engineering cert. lol The lack of room for a sub enclosure in a two seater is a reason why I almost wish I bought a 2+2. I'm strugling with where exactly I'm going to install a sub. I've narrowed it down to two very custom enclosures behind the front wheels, inside the fenders, or a single enclosure in the rear quarter opposite the fuel fill (driver side for me, passenger side for you lol). What subs are you looking at installing? There may be better options.
For me, it has to do with someone assuming that anyone of us in the auto repair or modification business are just out to rip people off. There was also the babbling on about how we're all mature here, so why is there a swearing filter? That seemed obvious to me. Maturity to me, means being able to express one's self in a manner that does not require swearing, or cursing to get a point across. It too to me seemed like the OP was just some young guy that thinks it's cool to swear based solely on that. In my dealing it's the exception that someone that is not in their 20s puts up such a stink about being censored. I too am in my 30s and try to use clean language to convey what I'm saying. I find people are much more responsive to that than being cursed at. As far as the repair here goes, it's hard to tell whether he just wanted to vent that he felt he was being ripped off again or wanted to tackle the repair himself. Even after subsequent replies I'm still not sure. Yeah, everyone wants that $2 or free repair for everything, I know I do. LOL!
For the record I never said to just up and replace the alternator, but that I wouldn't rule it out as a possibility in a diagnostic procedure. It seems that you have other issues, in "losing" two cars to other people. There's usually more to the story, how long did the cars sit there? Did you make any attempt to inform them that you wanted the cars, or to arrange transport of the vehicles to a location where they would be secure?It might be that you need to find a better mechanic, this one may just be bad news. I've never understood why people will complain about about a certain store, or auto repair shop, barber, etc, then in the next breath say "Well, I gotta go, I have an appointment at the shop I was just complaining about...." If you don't like something or someone, change what you have or where you go. Nothing says that you have to keep going back to some place that you don't feel like you're treated fairly by. I can't see the burnt wires in the second picture, the above of the driver side engine bay. I do see the burnt wire in the coil picture. Any repair like this you start with what is known to be bad, such as the broken ground wire. Even something that may seem unrelated fix it first. You'd be surprised just at how related different systems are in a vehicle. Without actually looking at the vehicle myself, I would have to say the broken ground is related, and you may find more wires that are just as crispy. Unfortunately they would be in the wire harness and possibly in the dash. So if after repairing those wires you still have problems, you'll have to dig deeper. Use better techniques to repair that broken ground. If it keeps breaking, you're not repairing it correctly. The definition of insanity is doing the same thing over and over expecting a different result. What exactly is breaking? The repair, or the connector, or the wire itself? The only wires or connections I have had break on me, have some sort of physical property affecting their longevity, such as weight of a harness pulling on it, vibration, corrosion, etc. Make sure the wire is supported, not vibrating and not able to have corrosion form and you should never have a problem. So start with the known problems, repair the burnt wires, using proper techniques (solder/heatshrink/wrap), then using proper tools, such as a DMM, set to current mode, find any circuits that have a higher than normal current draw, either while running or not, or better yet, both. I take offense to threads like this, because I have stood on the other side of the counter for many, many years, literally and far behind that counter performing the actual work. I've been told I have no idea what I'm doing by the people paying me to do it. What? I've been called a rip off, even though I was giving a deal, among other things all because people paying me to do it, have little to no knowledge about what it is that I'm actually doing, and assume that it's easy, because I didn't spend 4 years in university to learn how to do it. No, I learn everyday about what I'm doing. There's always something more to learn. Threads like these just keep confirming what the problem is with people that have little to no knowledge about a subject or just enough to make them think they know, when there is much more to it. As the saying goes, "The more you know, the more you realize you don't know." I have had people describe problems to me, even over the phone and have figured out the problem, even though it has seemed unrelated to most, before the car ever showed up. It's from experience, and diagnosing many years of problems or systems. In this case, wanting to replace the alternator without going through an actual diagnostic procedure does seem a bit odd. Even if I have figured out the problem just from a description, I will go through a diagnostic procedure to confirm it, before replacing parts, if possible. I'm not trying to call you names or tell you are wrong here, but just to say that maybe, there's a reason why someone will want to do something that seems unrelated or not likely the problem, because they have likely seen the problem before, or something very similar. Before someone gets into a diagnostic procedure, they may not know there are other issues. Like I said before you may need to find a different mechanic if he just wants to throw parts at a problem instead of doing a proper diagnosis. Unfortunately sometimes a proper diagnosis does involve replacing parts, especially when it comes to electrical. I'm sure as a computer tech you've seen some common problems on certain MoBos, programs power supplies, vid cards, RAM, HDD etc, and when someone says I have XXX components and I have this issue, you will in your own mind, say "Yep, I know exactly what that problem is... (I also dable with computers too and see some common problems pop up. ) As far as the filter, I'm not offended by swearing in general, but why is it so necessary to use it? Why put up such a big stink to be able to curse on a forum that has already set filters in place? To go by the idea of "banning those that abuse it," what is considered abuse? 1 curse word in a thread, in a post, in a sentence? Each of us have a different tolerance for people that curse and swear, so it is better, as a whole to just say none of it, and move on. If you really need to use cursing in your posts I can think of many other forums that allow it, and choose not to be a part of those ones, because I prefer the atmosphere of forums where they limit or don't allow it all. I find the membership is generally more mature, and can convey their thoughts much more positively and with a higher grade of understanding. In closing, before the next time you want to call someone names because you don't fully understand the system or procedure, you might want to stop, think of the other side of the coin and re-word what you say.
Color of front area that surrounds radiator - black or body color?
Six_Shooter replied to Brabham's topic in Body work
My '73 (USDM) is painted, rather poorly IMO, around the rad opening facing the grill, in a black colour. At this point it is a flat black, which I would assume would be correct. I believe this is original, just do to wear and how the rest of that area looks as well. -
Just as a forward, I have been working with automotive electrical and electronics for over 20 years, so I've seen a lot... Yes, it is possible that the alternator and/or regulator could cause a problem at start up, while it would be a rare situation, I wouldn't rule it out. I'm also not sure that would be the first thing I would check, but it would be on the list. A poor or broken ground can also cause problems like you describe, and because of the lack of proper body grounding, the chassis would need to find a ground source through other components, the alternator and regulator being one of those components. Unfortunately for those of us that work on the other side of the counter and perform the diagnosis and repairs of vehicles, we have to deal with people like you a lot. Who don't know much at all about how a particular system works and because their bartender's best friend's dog walker's little sister's day care provider's uncle said some stuff about electrical components in a car once, they think they can assume that a particular situation just can never happen. If there's one thing I've learned in all the years I've worked with automotive repair and especially electrical, is never rule out a possible cause, until the diagnostic procedure has been performed. On the next part of your post, I'm glad the filter is there, for people like you, that think the rest of us want to be cursed at when we are relaxing in the evening catching up on the world of the intarweeb. While I don't mind cursing in certain contexts, this would be where where I think you are an under-educated pompas ass , whom unable to express himself in a manner which would want me to help you.
What? What was the cause?
Best Forum Response to a Question .... EVER!
Six_Shooter replied to MaygZ's topic in Off Topic Discussions
I enjoyed that. Thank you. -
Instead of modifying the alternator for mounting I would recommend modifying the mount that is bolted to the block: I cut mine on that marked line, I don't seem to have a picture of it after it was cut. Modifying the mount instead of the alternator, allows for easy and quick changes of the alternator if one ever fails I also used a GM alternator in my car, though mine is 160A and a CS series, that was built for a car with a rather large stereo, but never installed, so I used it in my 240. I'm thinking of going to a stock 105A, just to get a better idle charge.
"I just want to make sure you don't have crabs... We are at the beach..."
