Six_Shooter
  1. An easier one: Bad Beer Rots Our Young Guts, But Vodka Goes Well
  2. Haha
  3. Why don't you?
  4. You guys are WAY over paying for a lot of stuff, especially Peter, really $4000 for custom intake and exhaust manifolds? Motec is expensive and not necessary to run, even on the "ultimate build." $4000 for a fuel system? I bet a similarly capable system, using components that are as high quality could be built for less than half, less than $1000 around here. $7500 for a custom crank? I was quoted less than $2000 for a custom crank from a US company about 3 years ago for a different engine (a V6), even with shipping and import fees into Australia would not be $7500. BTW, I can read just fine, which is why I'm astonished that you and other people are paying these absurd amounts of money for parts. My estimates included supporting items, like the fuel system and ECU. Maybe many of you are just stuck on catalog builds? Buying parts based on some brands that are simply a recognized brand, and not necessarily any better than a lesser know brand.
  5. Even if that were the case, current exchange rate is right around 2:1, so, that would be about $17500, which is still way more than MANY engines would cost. for $17500, I can buy an extremely stout LSx, with boost, good for around 1000 HP, probably more (Though that would be low on my list of engines), Ford Modular engine, also with boost good for about the same HP. Looking at 6 cylinder engines, that could buy a very stout 2JZ, a VERY built RB, among many other 6 cylinder engines. I know things are priced higher than around here, but if you're seriously putting $35000 in parts only in to an L-series, you need to re-evaluate what you're doing, or at the very least HOW you're doing it. Quality of fuel is irrelevant in this case. I also don't believe for an instant it's as bad as some people on this forum would make it out to be, looking at what I've seen other people accomplish in Australia.
  6. For $35000 I could have a MUCH better and much more powerful engine than an L-series. Engines can be built right for far less than $35000, and make plenty of power.
  7. The car in the original post has just about everything I don't like that gets done to these cars, but it pulls it off well, and looks great. I think that is a stock speedo with a new face, look at the ODO, and Trip ODO. The grey and black one provided in a later link, is one of my favorites, and have always loved the blacked out trim look. I'm not a fan of chrome to start with, so the less there is, the better IMO.
  8. Who is deciding this "fuel being better in one area than another"? What makes you think that the fuel I run is so much better than what you run? Octane does have a large factor in burn rate, and resistance to detonation. So far all I read about that is conjecture, no facts. I have a feeling this goes back to "your HP" being different than "our HP." :facepalm: Also who needs a full bar of boost (15 PSIG)? I'm running about 10 PSIG right now and it's more than what I need in an S30, most people that ran similar boost numbers with a tuned combination will likely agree. That's the key here, proper tuning, running low boost with a properly tuned set-up will run better than a poorly tuned high boost engine.
  9. It depends on a few things, though I would definitely NOT recommend doing it that way. I'm assuming you're using an L28 ECU, which has no closed loop feedback, just tables based on airflow from AFM and RPM. The first thing that will happen is with the larger injectors you'll be running fat (rich) at idle and part throttle cruise, causing issues with washing down cylinders, fuel in the oil (reducing viscosity), possibly hard to start, poor fuel economy and annoying other drivers with your too rich condition. The way people have used OEM ECUs (Not L28 ECU that I'm aware of however), is to retain the stock injectors and use an "FMU" AKA Fuel Managment Unit, also named RRFPR, Rising Rate Fuel Pressure Regulator, to me both names are a bit misleading. How these work is to pinch off the return line of the fuel system, as boost pressure increases, raising the fuel pressure usually by rates of 8 or 10:1 (8 or 10 PSIG of fuel pressure for every 1 pound of boost), this only seems to work well on low boost systems, 5 to 8 PSIG depending on the engine, and using more modern EFI system that has closed loop feedback. The added fuel pressure will deliver more fuel for the same injector pulse width, but without actually trying it, or following a recipe of someone that has done that very same thing on the same engine, it's a guess at best of how well it will work, without trying it. I've installed a couple systems that used these parts, but the end result was always a compromise. In all honesty, the very next upgrade I would be looking at, would be a tunable ECU, such as Megasquirt, Delco (What I'm running), 300ZX with Nistune, or more expensive options. You can pick up plenty of power, and driveability just in a proper tune, especially going to a system that can control both fuel and spark timing. The system, if selected properly, can be carried over to a turbo application as well.
  10. Rubbish... You assume that the fuel I run is any better that what you have available to you, based on what? I run pump gas, usually 91 octane, sometimes I will run less, just to prove to myself it can be done without issue. If your fuel was so bad, NONE of the turbo combinations would run well. Most any detonation issues can be cured by tune, only extremely poorly designed combustion chambered heads would need any work, and as far as I'm aware NONE of the L-series heads fall in this category. On top of that fuel "quality" seems to be purely speculation based, with no one actually performing any bonefied tests of who has the best grade fuel. It is reported that my neighbours to the south have worse grade fuel than we do, but I see combinations that run just fun on the same grade of fuel. If I listened to everyone that told me "it can't be done" I wouldn't have half the things done to any of my cars, or other projects that I have and work great.
  11. What's the current SCR? around 9:1, 9.3:1? That will handle boost just fine. This idea of needing sub 9:1 SCRs shoulc be left in the '60s where they belong. If you plan it out well, and find good deals, you can turbocharge your current engine for cheap and make it reliable, but you have to select parts that will work well together. This is where research will help immensely. Yes, the non-turbo intake manifold will work fine with boost. The bonefied turbo manifold has a pop-off valve, which with the way it is used is not necessary IMO, it's not the same as a "blow off valve." Using the stock exhaust manifold and either the stock turbo or an aftermarket turbo will work fine. The stock turbo should produce boost in the power band you have cited, though, I wouldn't get too hung up on needing to see a particular boost pressure by "XXXX RPM", what's more important is usable power band. Can the chassis and tires take a surge of power at 1500 engine RPM in 1st gear? If not, then you won't be any quicker than you are now. One of the things that would be high on my list in a conversion like this is a tuneable EFI system, be it pirated from a 300ZX, which seems to be popular, an aftermarket system or pirated from some other car (I run a Delco/GM system on my 240Z), make sure you can tune it for your car, that will make a large difference in end product. As far as intercooling is concerned, it would be something I would definitely want, even at lower boost pressures. That being said I ran 10 PSIG on my 2.8L for a few years, non intercooled, so it can be done, but you will pick up plenty of power by intercooling the system. So if budget is tight, you can run non-intercooled to start with and add an IC when you can afford it.
  12. PZG: Do you have pictures of these different spoilers? From using the keywords "Bird Bath rear spoiler" in Google, the closest thing I could come up with was a spoiler/wing that had sides that extend forward along the 1/4 panel. Also in Google images, "IMSA rear spolier" looks like it is similar to the BRE style spoiler/wing, just extended down the side of the 1/4 panel a a few inches. If I don't know what a BRE spoiler looks like by now, I should have my Datsun club privileges taken away. lol
  13. HAHAHA... That would take a lot of paper... And a very large printer. LOL! Imagine the size of scissors you would need to cut it out?!
  14. Hmmm... I just happen to have some extra inspection covers AND cowl panels....
  15. LOL. Yeah, I'll have to make one of these....or a dozen.
  16. You shouldn't need to do any soldering, just remove some nuts to swap the short harness on the back of the gauges.
  17. It could be a problem with the wires feeding the gauge, such as an ignition feed. Since you say you have a spare gauge, you can swap the harnesses betweem them. Electrically the gauges are same for the run of the S30, exceptions being the tach and the obvious difference of ammeter and voltmeter.
  18. That's not how electricity works though. If there is too much resistance in the wire the current will go up, which causes the wire to heat up, which causes increased resistance, which causes the current to rise, which causes more heat..... Including the wire length in the spec "max current capabilities" of wire gauge is very important. There are some wire lengths in vehicles that are only a few inches, while others are several feet long, which can change the required wire gauge drastically.
  19. They don't suit every car or build, but I do like these wheels on a lot of 240s I have seen them on. If I hadn't swapped to 5 lug on my car, I would likely be installing them.
  20. I have the Kia door rubber on my 240Z, and like them a lot. Seal well, holding the door firm, without needing to use excessive force to close the doors. For my hatch, I used a 4th gen Chevy Camaro hatch seal. It needed to be cut shorter, and took a but of effort to close tye first few times, but works well. I don't onow what the Aussie equivilant would be for that part.
  21. True, but other than the turbo bits on my car, I don't have any. lol This was just a thought since I recently got a nice condition pair of tail lights.
  22. Intimately. However, my hands on, is with North American products, which differ slightly from the Australian counterparts. There is at least one Australian Delco conversion though. Now, they did a few things differently than I did, and I think it was more to use what they had around. http://delcohacking.net/forums/viewtopic.php?f=16&t=998 The 280Z Dizzy can be used to trigger a GM Delco ICM (Ignition Control Module), which is how I did my initial conversion, mostly because I ran out of time to get the DIS on, before Zfest that year, I got it running the day before, then drove it about 150 KMs round trip with a very rough tune! It drove fine though, just need some work to get it better (and lock out the dizzy ).
  23. If you are serious, we can look into the postage.
  24. I was wondering if that was the case.
  25. Delco (Holden/GM) ECM conversions have been done with great success. Tunable and reliable.
