Six_Shooter
  1. WTF was that? Waste of 3 minutes. What was the point of casually driving around a circuit, showing off a blue hood? :facepalm:
  2. I am so glad that after reading many of the threads here that I don't have to deal with the odd thought process of the engineers you guys have to deal with down there. I can't think of any car that would have an easy to retrofit retractable belt. The problem will come in that the retractable belt will need to sit in a recess under the rear seat, that currently does not exist. It may also be found that that there isn't space to add this recess due to rear suspension and drivetrain.
  3. Yeah, why would they want you to change something from stock?
  4. In these two pictures the blue line is not lining up. Where you show it on the wheel side, is actually through the frame rail. Why complicate matters by doing this? When's the last time you heard someone with an issue concerning the brake lines and road items damaging them on an S30? For me that would be a NEVER. The brake lines are actually quite high from the road surface, and installed in ways that other items will protect the lines. You have to watch when passing brake lines, well any tubes/lines through bulkheads, because as the pressure rises the tubes will stretch and move around. If they are restricted at the wrong point, you can actually create problems, instead of get rid of any.
  5. Yeah, I missed that part, for some reason I read it as using 2+2 belts in a 240. :facepalm: Sorry about that.
  6. If you're looking to install retractable belts in your 240Z, it's possible using 260Z, well, 1974 260Z belts combined with 240Z belts. Keep in mind I used North American market parts, so I'm not sure if the AUDM stuff was different or not. Up here, the 1974 260Z (Also the only year of 260Z in North American market), used retractable belts that mounted the upper retractable pieces in the same place as the fixed belts on the B pillar. I tried using the complete 260 balt, but the lower retractor mounted slightly differently than my 1973 240Z used. So I swapped the lower retractors, and bolted them in. In earlier 240Zs that had fixed lap balts you will need to either add the seat belt pockets, or create a mount that places the retractor in that little void that is at the base of the wheel well. If you look at the Retro-Belt installation instructions you can get an idea of where there is space.
  7. The two captive nuts are for throttle linkage. It's the anchor point for the carb linkage to attach to the link from the pedal. #1 is choke linkage. On my car #2 was for choke linkage, but I have a left hand drive car, so some things are on opposite sides. It may have been filled with a solid rubber grommet and not actually had anything passed through it.
  8. It's not a residual pressure valve, it is however the early rear proportioning valve. In 1973, this was replaced by a different type of prop valve that used the right front brake pressure to modulate the rear pressure, and was installed on the firewall.
  9. Yeah, I'd love to get a pair of AUDM/JDM/EUDM tail lights. I don't want to spend what people ask for them though.
  10. S30 stub axes, the Z31 stub axles won't fit, at least not without finding a set of bearings that will fit the strut housing and the Z31 stub axle. Even then, the length of the axle might not allow everything to fit correctly. It's been a while since I looked at using the Z31 stub axle so I don't recall all of the details, I just remember the bearing issue being the biggest road black initially, and is why I opted to re-drill my stock stub axles. It also seems that information of 5 lug swaps is that the Z31 stub axle can not be used.
  11. NA Z31 never got the 5 lug hubs after '86 in Australia? IIRC it was only '84 and '85 Z31 non turbo that was 4 lug here in North America. From what I've seen both NA and Turbo hubs will work. Rears need to be drilled however. Also there's no need to weld on any material. As long as the pattern is drilled properly, there is more than enough material between the stud and the outer edge of the flange. FWIW, this is how mine have been for a couple years now. I had a machinist drill my hubs, and he said that the material thickness was within spec for fatigue.
  12. My car has had this fuel pick up for about 5 years, never an issue. My entrance to my driveway is also pretty steep and it's never scraped or caught on anything.
  13. Wow... What happened?
  14. This is how I have mine set-up, 3/8" feed, used the original feed (8mm), as return, also pulling fuel from the tank drain plug.
  15. Yep, that book has been around since the '70s. JTR (Jags That Run) has a whole series of how to V8 swap your XXXX car. Most the books were originally based on using the Small Block Chevrolet engine, but most have been updated to include LS engines as well. If you're into V8s...
  16. I'm actually checking in to see updates. :tup:
  17. That's pretty wicked.
  18. You can download the FSM from xenons30.com.
  19. To start with I see this a lot, a higher numerically gear is a "short" or "low gear" ratio. A lower numerically gear is a "tall" or "high" gear. The choice of ratio depends on a lot of factors, as mentioned where you want the engine revving to while at cruising speeds, the type of acceleration you want, and finally how much power you have. I have found in a couple cars that once more power was added the diff ratio had a large factor in just how the car accelerated, as in how quickly I needed to shift, namely 1st gear. In my 240, I have a turbo L28 that is making around the 300 HP mark. I originally had a 3.54 R180, and the gear ratio was decent, 1st gear wasn't too short, highway revs (at 110 to 120 kph) were decent. Before the turbo the L28 was a stock N/A version, with Weber downdrafts. I swapped to 3.90 R200, to be able to use Z31 CV axles, and while accel is great, I feel the gear is too short for me. !st gear when I'm at the drag strip is over too quickly to be a really good ratio for me, even though top end trap RPM is pretty good. I also feel that the shorter gear doesn't put enough load on the engine to get the turbo to spool in first gear, at least not as much as I'd like. Highway speeds I find I'm revving a bit higher than I'd like, even in 5th, but I'm just used to the steep overdrives and tall gears of more modern vehicles. This is with a 4 speed 240 box when it was N/A, and a 5 speed ZX box, when it went to turbo, 1st 4 gear ratios being the same from what I've been able to determine through research. There is an online Java script calculator that deals with the Z transmission gear ratios and plots them on a graph, to give you an idea of what changing the diff ratios will do for changing the RPM spread of each gear. I just don't recall what the URL is.
  20. The 240 will use the bottom strut. When that one is installed on, the access to the bolt heads will be towards the inside (middle) of the hatch. The other one would place the access to the outside. Which would mean it gets installed on the right side (Driver side for you Aus people). Also the bottom strut looks more like my '73 strut than the top one.
  21. I should amend my previous post, the crushing of cars has been revoked here, but the Stunting Law is still in place. We have the same problem here, too much is left up to the interpretation of the officer. It has been found that over the time that this "stunting law" has been in effect, that it has not reduced deaths or incidents of violations. This seems to be due to the fact that the people the law is meant to target are not the problem. Most street racers that are involved in organized street racing, are not doing it at 3 in the afternoon through traffic with highly modified cars, like the politicians would like us to believe. The people that are getting into street racing accidents are in bone stock or nearly bone stock vehicles, and decided to run someone at a stop light. I think over the last 8 or 10 years when I've paid attention to the reports, there has been once where a highly modified car has been involved and another had aftermarket wheels, of the tens to hundreds of other reported "street racing" incidents the cars were stock. I'm not supporting street racing, but the way our government has gone about it and how it seems that Australia is proposing does not work. About the only thing the Stunting Law has done is increased high speed chases, and a few people (myself included) keep it under the 50 over posted speed limit. At 50 over they immediately impound the car on the side of the road and leave you there, which has some groups lobbying against the seizure, due to putting the vehicle occupant(s) in danger leaving them there. There's still just as much racing and stunting going on, just done a little more discreetly.
  22. There was a similar law passed here and after a couple of people from the states had their Corvettes seized and crushed, there were court cases, and the Ontario government ended up buying these people replacement cars, and the law revoked.
  23. If it'a really dry (like an engine that hasn't ran in a long time), I would change the oil, but I remove the cam cover when adding the new oil and pour the oil over the valve train as you are adding the oil, usually a liter should do. Turning the engine by hand can help get oil between the friction areas. Usually not necessary, just depends on how anal you want to be. Another way to prime the engine and is my preferred method, would be to modify an distributer drive shaft, so that it doesn't engage the crank, and has a way to attach a drill to the end where the dizzy would be. You can then run the oil pump from the drill and getting oil into everywhere before turning the engine over at (starter) speed . Once oil pressure comes up, I like to turn the engine over a few times while priming to get the oil to coat all bearing surfaces. This is more easily done on engines where the dizzy is ran from the camshaft and in turn drives the oil pump, but can be done some engines, like the L-series with a modified drive. This is usually not very necessary on engines that have ran, because oil will basically be impregnated into the bearing surfaces, so there is usually at least a little lubrication there, and turning over the engine with the starter for several minutes can get fresh oil to these surfaces. This is more of a problem on fresh rebuilds that have sat for a long time.
