Six_Shooter
  1. I have one as well, that if need be, I can measure.
  2. Last I checked, performance didn't negate ugliness. I don't care what you guys say, that purple one is FUGLY. And here's another one:
  3. It's a year change. IIRC the font that is in pic 43 is the later font.
  4. New contender?
  5. Also in my post.
  6. See, now you're just talking gibberish, it's HP and ft/lbs. The engineering notation I posted is easy to read.
  7. There are calculations based on measurements, that include wire diameter, mean diameter, number of active coils and a few other parameters. I have it in a book, I'll see if I can find an online example. -=EDIT=- IIRC, this is the formula I have used: http://www.pontiacracing.net/js_coil_spring_rate.htm
  8. When I read the title, I expected to see: k = x10^3 m = x10^-3 u = x10^-6 n = x10^-9
  9. I enjoyed this one:
  10. The air dam is available from Z Car Customs, and I'm sure other places. http://www.zccjdm.com/catalog.php/azcarbum/dt46936/pd1993603/G_NOSE__240ZG__JDM_AIRDAM
  11. It looks to be just a BRE style wing, usually not hard to come by. MSA sells them, along with a taller "Victory" version.
  12. Am I the only one that sees the G nosed S30 as awkwardly long looking? Don't get me wrong, I like the G-nose itself, but I think the S30 was made perfect with the non-G-nose, length wise I mean. It seems to me that a proper looking G-nose conversion should have replaced the hood and fenders as well, to keep the overall length of the car the same, but make it more aerodynamic.
  13. Painting glass is a pain, to get it to be long lasting. Painting rubber will just look terrible and also not last very long.
  14. The spade connectors should be for the turn signal flasher. Sounds like it's time for you to download the factory service manual, and start tracing, matching up wires as compared to the wiring diagram.
  15. Yep, and you know, you must stop racing your car, because "Stance" cars don't perform. :rolleyes:
  16. I've been into watching imports and such for a long time, and I still can't find a good definition of "stanced". I do like the lowered, big wheel, deep dish (high offset?), rubber band tire, filling the wheel well, look, but I call that "Pro-touring", where the main objective is how the car functions. I find it interesting that people still to this day judge whether a car can drive well, based solely on a picture of the car on the internet.
  17. Oh man, I'd love to get one of those speedos. The closest thing I've seen around here, is the dual graduation face that I'm using now, but is very difficult to read the metric scale, since it's small and a light blue colour that really doesn't stand out.
  18. Are your speedos actually in kph? or just have kph in the inner ring?
  19. I like that, I've always just remembered the key speeds, which around here are 30 MPH approximately 50 kph, 50 MPH, which is approximately 80 kph, and 60 MPH which is approximately 100 kph. Due to our goverment's backwards thinking and listening to the wrong people, our speed limits max out at 100 kph. On the Trans-Canada Highway, there are some 110 kph stretches, but not many, and don't dare go 111 kph. :facepalm: I also have a 280Z face on my 240Z speedo that has kph on the inside ring, but is quite difficult to read, even in the day time.
  20. If I'm not mistaken the early (non turbo) EFI is triggered from the negative side of the coil, which would mean that the dizzy is not important as to which type it is in that case. Other EFI systems definitely have to use a matching dizzy. Have you verified timing advance, and spark output on those cylinders? Could be as simple as installing a new dizzy can and or rotor.
  21. I've had several carb equipped vehicles over the years, including my 240Z, and in every case but my Honda Prelude, I converted to EFI, if they weren't already, and noticed a great improvement in reliability, ease of starting, fuel economy, and sometimes power. I say sometimes power, only because I have to exclude times where forced induction was also added at the same time, of course power was added then. In my cases I have used Delco ECMs for the conversions, a couple times because those were what would have been originally equipped in those vehicles, other cases, such as my 240Z, I wanted to prove that it could be done and cost effectively, along with also being familiar with the hardware and tuning software that is used. They are robust, extremely reliable and plentiful. I have only had one failure over a couple decades of using them and that was due to some water getting on it, in a heavy rain storm. If I had had the correct MEMCAL in the ECM for Limp Home Mode, I would have been able to drive it home, unfortunately I didn't, and had to have my GF bring me an ECM that then got me home. I've since tested with the correct MEMCAL and now LHM works just as it should. In every case where there are no rules that need to be met (racing classes) or other restrictions that would eliminate the possibility, I will recommend EFI in every case. Just as a point, other than the Turbo EFI system from the ZX, the factory EFI does not control ignition timing, on the L-series.
  22. The cardboard door cards while being similar across the years do differ. From what I can tell, these come without the holes drilled, so it shouldn't really be an issue. The top metal stamping that wraps around the top of the door, and holds the window felt is also different. At some point the door lock pull was moved forward in the later years, that makes them difficult to swap to a different year door panel. I realize that you need to supply your own for these door cards, but just so that some people don't buy the wrong door panel as a donor for the top metal piece.
  23. They DESTROYED that car. Even if it wasn't a Datsun, I'd still look at it as destroyed. The "Allstars" are not. They need to have their wrenches taken away, most of the builds they do are garbage, and completely ruin the cars. They haven't learned about the idea that "less is sometimes more". I watched a few episodes of that show when they first aired, including the 240Z episode. They are all about drama and not about the actual builds.
