737 -
This is likely the type you need here: Better yet I prefer this type: The second works as both a remover and installer. The installation aspect is great because you don't need to use the crank bolt to install the harmonic balancer/crank pulley and risk damaging the crank's threads.
I'll just leave this right here....
I put my Walbro 255 in approximately the OEM location for a '73 with electric pump. Here are some pictures to take you on a journey: I originally used the OEM bracket for fitting, and had planned to use it... I decided I wanted to have a little more protection from debris for the mount and fuel lines so I made a different plate: With fuel filter: A little wider shot: I've been running this set up for 5 years without issue. That being said, when I redo my fuel system I am planning to install an in tank fuel pump, to eliminate the need to have the fuel pump suck the fuel so far. I still run the same set-up after swapping to an R200, but had to use spacers to move the plate more rearward to clear the R200 mustache bar.
I could not make it through an entire episode. Seinfeld annoys me that much, even though some of the cars seemed interesting.
Nothing with Jerry Seinfeld can be considered "great".
Its alive !!! Finally got my rb26 zed running again :)
Six_Shooter replied to RB26DETT's topic in General Discussions
Awesome, it's always nice to make progress. :tup: -
We'll have to agree to disagree, since around here even dealer installed aftermarket parts are "optional", which makes them "options" to me, and to most other people in the industry. Look at Ford and Shelby parts, they are aftermarket parts, but can be installed as dealer options. They can also be bought in the after market, either through parts stores, or Ford dealerships, just like these over-rider bars were, from the information I have found over the years. Some laws required these to be installed before the car was sold, so in essence they weren't even optional then. Now a days, Shelby cars are usually factory built, but they weren't always that way. Chevy and Yenko, is a similar example. Yenko cars were never factory optioned cars, there was a specific dealer that ordered the cars and put the Yenko option on them, and became sought after, selling these cars to other dealerships. There were others as well. There does exist "factory options" and "dealer options". Some Factory options were/are also available as dealer installed, and many times there are dealer only options.
I consider parts that were not part of the base car, but installed before it left the dealer, even if required by local laws were it was sold to be installed as options, since not every car of that type would have them, when looking at different markets.
Yep, they were optional, dealer installed IIRC. I know that in California and Washington state they were fitted to the 240Zs because the stock bumper height was too low to pass inspection, and the over-rider bars got around this. I'm sure it would be similar reasons elsewhere.
EFI to Carb, missing, spluttering and just not running right.
Six_Shooter replied to BatmansDatsun's topic in Engine
Also make sure you have the correct reach plugs. I'm only aware of one length used on the L-series, but I have been in a situation where, the wrong reach plugs were used, and it ran rough, usually missing, and would sometimes hang the RPM. The plugs were too short in that case. It was GM V8 engine that I had that issue with. We also swapped induction systems to try to rectify the problem, but the opposite way, from carb to EFI, after trying several different carbs, since I understand EFI, well GM EFI a lot more than carb. Then we found the plug length issue. -
That's the firing order, but are you sure it's correct on the engine itself? It's pretty easy to get a pair out of order, and it can sound much like what yours does. -
Are you sure you have the correct firing order? -
LOL! Until you wake up and it's minus 20, you're not in a "cold climate".
ROFL... Canberra being "cold climate". Looking at the available average temp information, the coldest day would be about that of a spring morning here. I've used 10W30 and 10W40 for years in much colder climates. When I think about it, I usually try to put in 10W30 when it gets close to winter.
1975 260Z FSM or Wiring Diagram, who has one?
Six_Shooter replied to Agno's topic in Electrical systems
That's how it is with the North American cars too. The wiring diagrams are less than accurate. no matter where the car is located. -
l20et or l28et parts still easy to come by?
Six_Shooter replied to singhy's topic in General Discussions
If you're going aftermarket ECM, don't worry about the L28ET dizzy, just use your existing dizzy. If using Mega Squirt (probably easiest), use it to trigger the ECM (lock it out), and then use the ECM to trigger the coil for timing control. Alternatively you can use a GM ignition module from a dizzy vehicle (I'd have to find out which cars in Aus came with a similar ICM to what I used), that can work as both a trigger to the ECM and allow timing control, triggering the coil. Better yet, grab a DIS set-up, IIRC the Holden VN(?) is a popular donar, fab a trigger wheel and have wastespark DIS. This can also be interfaced with an MS. Personally I use a Delco ECM, from a Pontiac Sunbird. If you do your research right, the only part "needed" from an L28ET (maybe L20ET would work as well) is the exhaust manifold. I turbo'd my L28 (NA) and the only OEM L28ET parts I used were the exhaust manifold and the cam cover, and I only put the cam cover on, because I got a good deal on one. As much as I like my turbo L28, if I already had an RB25, I'd likely swap that in. In the end I plan to swap my L28 out for a 3.5L V6, that's I've had in the garage for longer than I've owned my car. lol -
Have you looked on xenons30.com under reference? The 1975 280Z FSM should be very close to your 260Z. -
Sounds like there may be a couple of issues. First check the clutch hydraulic system as suggested. low fluid can cause the clutch to not disengage properly and making shifting difficult to do. It also sounds like there might be an internal issue with the trans, such as a broken shift fork. In my 5-speed, I had the 1/2 shift fork break on me in such a way that it would still allow the gears to be shifted, but there was a lot of slop to the motion and would cause 2nd gear to pop out on engine brake decel. I replaced the 1/2 and 3/4 shift forks with 4 speed shift forks, since they are made out of cast iron, or similar material, where as the 5-speed had forks made from aluminium.
Measuring the coil output with a DMM tells you nearly nothing in this case. Disconnect all wires to the coil, use a jumper lead to provide 12V to it, you can connect directly to the battery for this test, then do as before quickly rapidly ground the negative terminal and watch for a spark being produced at the coil wire end/spark plug grounded to the engine.
That's what it sounds like to me, and not sure why he's trying to test that way. The coil discharge will be several thousand volts at the point of creating spark.
Pull the coil wire off the dizzy cap, place it near a ground, the engine block, intake manifold, etc, or better yet use a spark tester or spare spark plug that is grounded in a similar manner and using a piece of wire quickly ground and then remove the negative coil terminal. There should be a spark when you remove the ground from the negative terminal. If there isn't then you have a coil problem, if there is, there is a triggering (points) problem.
The body ground on my car is attached to the battery. I wouldn't be looking at the alternator or really anything engine related, as long as I understand how your grounds are attached. It sounds like you have a ground from the battery to the engine block (near the starter/bellhousing area), and then another ground lead from the cam cover to the chassis? The vehicle would shut down due to having a high resistance current path, this does not automatically mean that the alternator has failed, there are a few systems that involve the chassis wiring to support the engine running as well. Do you have any additional electronics installed? Check that both ends of the ground lead are tight, and that all other ground leads are also tight. A loose ground connection can cause a high rssistance and excessive current to pass on that wire.
Some more cool Z videos - youtube.com
Six_Shooter replied to Toecutter's topic in General Discussions
IIRC the Leaf uses a ramp for power output, that limits power at lower speed and RPM, to make it drive more like a conventional car. If it could have had full power from the start it would have either pulled far ahead at the start, as long as there was traction or just fried the tires, due to low traction.
