Six_Shooter
  1. That's technically 4 words...
  2. No one mentions counter measures for towing, because there's nearly nothing you can do to stop it. Not even the removable bollards will stop a thief, if they want it bad enough. The bollards also have ZERO effectiveness when not parked in that exact position. So when out on an errand or just for a drive and decide to stop somewhere for a while, the car would be more prone to theft than if you added the anti-starting and sound making devices. Sometimes all it takes is a flashing LED on the dash that looks like an alarm to have thieves move onto another car.
  3. Six_Shooter
    L6 DOHC
    Why shouldn't the reason I stated be enough to do it? Like I said it's more than enough of a reason for me to do it. For some people one reason is enough to make a project desirable. I didn't realize there was a minimum number of reasons needed to embark on a project... If it wasn't for the fact that I had a different engine plan in mind when I bought my car, I likely would already have this swap started.
  4. Six_Shooter
    L6 DOHC
    And what was the point of the cited blog in this thread? It would seem that the same thing was desired, a crossflow head, and DOHC, just like the KA monstrosity, with way less work. The fact that the intake is not directly above the exhaust is enough reason for me, It seems the most difficult aspect of this conversion was the timing chain set-up.
  5. The 240Z and early 260/80Z tach used an inductive loop to trigger the tach. Disconnecting the tach will disabled the 12V feed to the coil, provided it's still as original. However a simple jumper wire under the hood will get around this. On the later 260Z (280Z for North America), the tach is points triggered and disconnecting the tach will have no effect on the running of the engine. However, there is something that can be done on earlier carb equipped vehicles, with points ignition. You can simply ground the coil negative, the car will not start when you do this. The magnetic field in the coil never collapses to discharge and fire the spark plug. The only draw back to this is that if the 12V feed is left on, it will burn out the coil.
  6. Six_Shooter
    L6 DOHC
    Is it not just an RB(26) head? This looks to be a LOT less work than the one guy on HybridZ did to get a DOHC L-series, by cutting apart 3 KA heads... I'm not sure the gain would be "so little". There is a lot of potential and benefits there with a crossflow DOHC head that a none crossflow wouldn't have.
  7. I usually park mine in a garage. I always lock the doors when I'm not around it, and have installed an alarm system with a starter kill. I also consider my EFI system to be contributing to the anti-theft, since it can not just be simply jumped from under the hood like it could have been when it was carburetted. I could also upload a bin file that would not allow it to rev over a very low RPM if I desired. If the code I am running had a vehicle speed limiter I could set that very low as well. I don't believe in "The Club" because the steering wheel can be cut in seconds and removal of the club a second later.. When I'm not at home, I try to park in a high (pedestrian) traffic area, and if it's at night a well lit area. If I have to park my car outside at home, I park another vehicle behind it. The best anti-theft I have, is what it looks like. People look at it and think it's a piece of shit, because the clear coat is flaking, it's at least two different shades of brown, and has some exposed rust.
  8. That's an interesting solution for reverse...
  9. PLEASE PLEASE tell me how a DMM can possibly give false readings? I have NEVER had a DMM do anything of the sort, and I've used dozens of different DMMs, in countless circuits. I think what you mean is you don't understand how to use a DMM, so you use something that will not help you diagnose a problem, but give you pretty lights. All a test light can do is tell you there there is or isn't power on a circuit, but not how much voltage (and/or current) is available. To truly diagnose electrical/electronic circuits, you have to know that the voltage is not just there, but the correct amount, and at the correct times. As I have already stated, a DMM can show that there might be voltage without a load (a test light IS a load), but then go away once a load is applied, this will tell you the type of failure you have (likely corrosion or carbon build up on a contact). If there is no voltage in both conditions this tells you that it's a different type of failure (likely a broken wire or bad fuse). I'm not saying that a problem like this can't be diagnosed with a test light, but it will usually take longer than using a DMM, and knowing what to look for. I find that people that are afraid of DMMs, because they don't know how to use them, go to test lights and spend a lot longer diagnosing the problem than learning how to use a DMM on the same diagnosis.
  10. First rule of diagnosing electrical/electronics is: "Thou Shalt check voltages" Grab a DMM and measure the voltages at each point you have access to, including with the bulb(s) connected and disconnected from the circuit. If you have full votage (around 12V) when teh bulbs are disconnected but low voltage when connected, this usually indicates a corroded wire or poor connection somewhere, that could also be caused by corrosion of the contacts. remember the OEM headlight systems in the S30 switch the grounds, and the 12V is always live, so you need to source the ground from the circuit itself, not from the chassis or battery, when testing these circuits for voltage.
  11. I've been casually working on a similar conversion, using a 555 timer as the monostable section, I haven't been able to get to work as well as I would like, but have had only about half an hour to actually work on breadboarding the prototype. I plan to get back to it soon, hoping to be able to steal some time during "reading week" (week off of college classes), the week after next. Thanks for the link, interesting design.
  12. If you're talking about the turn signals as in this thread: http://www.viczcar.com/forum/index.php?topic=11543.0 You could use lenses from klearz.com, and then add an orange lense in teh proper location and size behind.
  13. I forgot I had this video as well. L28, Weber downdrafts, stock exhaust manifold, with 1.75" or 1.875" exhaust (it's been a long time) from the manifold to the rear axle, where it stepped up to 3" to fit the muffler. Gareth, if that question was for me (I'm a "Chris") no, the only muffler I'm running is the Sprioflow. It can be kinda loud at speed, but I find teh road noise is worse, on the highway.
  14. FWIW, I have this exact muffler on my car. I really like it. Easy to fit, sounds good, and noticed a difference in power between open tube and this muffler, that was before I added the turbo. I have a video of my car idling with the muffler, but remember, my car is turbocharged so that will change the sound over an N/A car. This was about 4 years ago, when I first got the DIS swap up and running. These videos were taken about a month and a half ago. The car was not tuned to run in temperatures this cold, so it's a bit rich and sloppy when revving, it did improve once the engine temp rose a bit.
  15. In the summer I use my 240Z as a daily, at least 99% of the time. I do have a proper daily, that sits most of the time when the good weather is around. If I lived in an area that didn't get snow, and I had to keep only one car it would be the 240Z. That being said, I understand the risks of trying to use a 240Z as a daily driver.
  16. I'm sure that around the world it's much the same as here, the next model year comes out in September. So the 2015 vehicles will be released in September of this year. I wasn't around for the release of the '74 260Z, but I would imagine it was released sometime around September of 1973. I think this is why people wrongly assign the year "1969" to their 1970 S30s, because they don't seem to understand the model release dates. Now the weird part is when you work on a 2008 model year car and it's only 2006! I did that, I don't recall the actual model now, but I remember it seemed odd to have released the next model year car almost along side the current model year offering...
  17. While that car will bring in some good cash once it's completed, the $15K price tag is a bit much in the area it's being sold in. Fully restored higher number cars sell for that amount and less. If the car is being purchased as a car to own forever, then the price is fine, but as an investment to restore and sell, it's too high to really make it profitable, for most people.
  18. Or anywhere else in the world. 1974 was the first year of the 260Z, in some places the only year. 1973 was the last year of the 240Z, and the dash is quite different than the 260Z dash. I'm 98% sure all of the chassis mount points are the same between the years though. I know for sure there is a difference in the 240Z to 260Z steering column support. The 240Z used a 4 bolt support that the dash also was retained by, whereas the 260Z used a 2 bolt retaining layout and the dash also reflected this.
  19. Download the FSM here: http://xenons30.com/
  20. Are you sure it's not an internally regulated alternator? http://www.atlanticz.ca/zclub/techtips/alternatorswap/
  21. I'd wait for a 240Z to come along, they come up fairly often. Otherwise I'd look for: -510 wagon -FC RX-7 -AE86/Corolla -'70s Sunbird/Monza/Firenza There's others that I can't think of right now, but they'd either be farther down the list or on my "Never gonna happen, I'm dreaming list".
  22. I'm pretty sure that it's a 280Z. I say that simply because the 260Z was a one year only car here in North America so it's pretty rare, and it has the large 280Z bumpers. I don't agree that it wasn't a bad movie... The pacing was awful, and the story was odd. It was somewhat original, and it had an S30, which are the only two reasons I watched it a second time.
  23. Why wouldn't you just put the old door on once you realized there was a difference, instead of cutting the door jam? :confused: Also there is definitely a difference between early and late S30s, when it comes to the latch/striker mechanism. 240Z/early 280/60Z: Late 280/60Z, if you look closely at the latch area of the door you can see that it uses a different latch type than the earlier S30:
