Alright I wanted to make sure before I posted any information.
With most of the GM DIS systems, the 3800 included the connections are very much like a dizzy. There are 4 basic wires needed between the ECM and the ICM. "Ref LO" usually black/red, "ESC" usually white, "REF HI" usually purple/white and bypass, usually tan/black.
The REF LO is basically a ground between the ECM and the ICM, to make sure they have the same ground potential.
The ESC is what actually controls the timing.
The REF HI, is the trigger to the ECM, in GM terms the signal is called a "DRP" or Distributor Reference Pulse. This will send one pulse for each ignition event.
The bypass will have 5V applied to it above 400 RPM is stock GM configurations, some Megasquirters like to apply 5V all the time and use the ECM to control timing during crank. This is also the wire that you disconnect to set base timing.
The other connections to the 3800 module include the crank sensor, and usually a cam sensor as well, though I don't recall if the ICM actually uses the cam sensor or if it's just a pass through on those modules.
I read people suggesting to tear apart the module and use some other MOSFETS to trigger the coils which makes the ICM itself pointless, other than for mounting, which could be done with a flat plate, if you go that route. I use the GM DIS myself, though I'm also using a GM ECM, the ECM and code I am using did not originally support DIS, and had to change some parameters to get it to work.
The GM ICMs have a built in LHM spark mode, that will have spark even with no ECM in the car, as long as it gets ignition, grounds and crank trigger. It's a great thing for diagnostics.
If you look in the Megamanual under the GM Ignition section you will see reference to the dizzy ICM, and the 2.0L and 60 degree V6 style ignitions. These ignitions require a 60* offset to work correctly, after start. The 3800 modules require a 33* offset to have correct timing, otherwise the set-up is very much the same as for a GM dizzy.
