737 -
If you were considering buying from showcars, don't. He's shady at best and people that live within a few hours of him have trouble getting what they order. I can't imagine how difficult it would be getting something from him when you live half way around the world.
I skimmed through the last couple of pages and saw some questions and suggestions for cutting the trans tunnel for the manual shifter. I'll post some pictures of my conversion. There is a picture of the auto shifter hole. Another after I cut out hole, I used the stock manual shifter boot retaining ring to mark this hole. Then a picture after it was all installed.
Connecting the 4 wires together is a clue. If these 4 wires were at the stater inhibit relay located on the fire wall then you definitely have an ignition source paying the starter. Though I believe there it's also a ground in there so that should create other issues. Also it seems that not every automatic S30 has this relay. If the wires you connected together are directly off the transmission then that is exactly what had been mentioned above the reverse light circuit is actually powering the starter. You'll likely also find that your reverse lights are on with these 4 wires tied together. I have to ask what ever would make you think that those 4 wires should be tied together?
I thought that was a great movie. The even more funny part about that movie is that for some reason people thought it was supposed to be a serious western and were pissed when it turned out to be a comedy. I love Seth MacFarlane creations. He always pushes beyond the edge of good taste, but only enough to still be down right funny.
Interstellar (2014) - Meh. It was a decent movie, but predictable. I was expecting some sort of great twist after Cooper went through the gargantuan black hole, but it was pretty much exactly what I expected to happen. I'll likely watch again, but it won't be a must watch again. I'd say 6/10, only because it some some great ideas, but failed to deliver any real excitement or new ideas.
Finally a Z car owner after 10 years!
Six_Shooter replied to jameshay_103's topic in Introductions and Forum Etiquette
Furious 7... The movie was more over the top than the previous 6, but for the most part, in a good way. Many returning characters as well. Plenty of comedy moments, and lots of action. LOTS of action. The send off for Paul couldn't have been more perfect.
Why is it that everytime someone builds one of these they claim to have the only road legal one in the world? I've seen that claimat least 3 times now. There was one here in Canada that I saw at a car show in Toronto a few years ago, that while not a great example, since it was roughly done, there was no mistaking it for the 1989 Batmobile and it was plated with Ontario plates. The one in the video looks well done, but the wrong wheels and wrong turbine inlet just seem like major dowfalls of the car.
Anything but black. BTW, what is the model of wheel (in the OP)? I know they are a semi-popular wheel for the S30, but the more I see them, the more I'm considering them.
I've used an SLC_DIY1 and an SLC_PP2 from www.14point7.com for a number of years now. Most of their devices are meant for permanent install, but I have used both my DIY1 and PP2 as portable devices, by simply adding cigarette lighter (power port) plugs. Using one with a switch allows you to easily control power when needed. Both of the units I have are capable of logging several additional inputs. The PP2 has onboard logging capability. Both units have USB connectivity which is one of the main reasons I have used 14point7.com WBO2 products. At the time they were one of two on the market I could find that had this capability. I hate USB to serial adapters, even the good ones are sometimes flaky.
Setting up a 12V test bench for checking wiring etc..?
Six_Shooter replied to gav240z's topic in Electrical systems
I meant to reply to this before now, but anyway... If this is just for this one time, I wouldn't invest anything into new equipment, and just use a battery from the car, if you needed to actually power something on the bench. I would simply connect a couple jumpers to the battery terminals (fuse protected of course), and power the devices that you are testing. If need be you can connect a battery charger to help maintain voltage, but realize that most battery chargers are noisy and can cause issues with some of the more sensitive electronics out there, luckily almost nothing in an S30 is something I would consider "sensitive". Also like PB260Z, I have and on occasion do use a jumper pack, when I'm not at my bench to test devices. They are pretty good because they have good current capabilities, and many times have a power socket on the that can be used for a small power plug with alligator type clips along with fuse protection in the tip of the power plug. Most of the time, especially when testing harnesses, a power supply is not even needed, but a multi-meter with a continuity and resistance measurements is all that is needed. If you plan to use this more often than just for this one project, then by all means get something that has more options. Adjustable voltage output can help to determine if a low voltage issue occurs with a device, although there are other ways to create an adjustable voltage output without a proper adjustable power supply if need be. Current limiting is also something that is handy to have, if you suspect that a device has failed in such a way that it is drawing more current than it should be, current limiting will allow you to set up a limit that should be just beyond what that device should draw and if it goes over, the output gets shut off and protects you and your power supply. I have a number of power supplies that I use on my bench, 2 are fixed voltage at 13.8V rated with a 3A peak output, and one that I built that has adjustable voltage output and current limit of 500mA. Surprisingly I use the adjustable power supply way more than the other 2 for what I do, some of which is car related. I also have a 75A 12V power supply that I don't have hooked up currently, but plan to in the future. The 75A supply is WAY overkill for most things and only have it because I kept it after closing a car audio shop that I owned. -
The divorced signal lights should not effect the brake lights. I'll have to check on my NADM car, to how they function, but I don't recall the brake lights not working with teh hazards engaged. I also can't get over the fact that the AUDM cars didn't come with hazards...
Just to verify, only the '73 has the illuminated hazard switch (seems to be a theme along with the heater controls ). Also only the '72 and '73 have the cigarette lighter above the hazard switch location. Earlier cars this spot was blank or for a fog light switch. It seems that the fog light switch was only in limited markets. I have yet to see any North American cars with it. Other markets the information seems to be a bit sketchy at best. Also you need the switch that matches your year dash. The hole in the bracket is different between them. So you can't just stuff a '73 Hazard switch into a '72 dash, without also changing the bracket that mounts to the back of the dash. For the earlier dashes, this requires cutting apart the brackets and welding the necessary parts together if you want to use the '73 hazard switch in the earlier dash. I did this a few months ago for a '73 that the owner picked up a '71 dash to use.
Some more cool Z videos - youtube.com
Six_Shooter replied to Toecutter's topic in General Discussions
I just shook my head when I noticed the welded fender, or sugar scoop... Just more reason why I do my own work... -
Where's the rest of the episode? They get as far as body work and then it just ends. -
I've finally caught up to the same year as you guys.... Only about 13 hours later....
Project Binky - Episode 8 is out.
So, I just finished watching The Interview. I don't see what all the hoopla was about concerning releasing it. It's a typical Rogan/Franco comedy. Actually to be honest it's a little better than that. It's not a "must see" but if you have a couple hours to waste and you're caught up on everything else, it's good for that.
Am I the only one not enamored with that video? There's just something about it that it does nothing for me... -
Seeing as the car is from California, I would assume that it is LHD (nothing I see here states otherwise), so the wipers would be best to be in a LHD configuration...
Hey.. Hey... now, What's wrong with a Brown S30? -
You should be able to get a pulley from any automotive electrical re-builder, especially one that specializes in alternators. It just needs to be larger than the stock pulley to slow the alternator down. You could also look at other stock vehicles for donor pulleys.
*SOLD*[BODY]260Z Dealer Option Nudge Bar
Six_Shooter replied to 53-681's topic in Parts and Tools for Sale
How and where does it attach to? Any installed pictures? That's an interesting item. -
I just downloaded and watched the full episode of Garage Squad "Disheveled Datsun"... Downloaded in less than 2 minutes. The new internet service is paying off. Uhg, misinformation galore. Last I checked the spark wires fit from '70 to '83 (or more years), not one year only like they claim. The early cars were not any different from later versions where wheel fitment is concerned. Their problem is that they went too wide with the wrong offset, but no, lets blame it on the car. *facepalm* Rear window louvers were dealer options, not factory options. This is the first show, or source where I've heard of the "first 100 being promotional vehicles". I'd like to know their source for that. The AC was not an issue of being an early car and interfering with the new air dam, it was a dealer installed item and later cars would have been the same. *facepalm* That timing advance plate from the distributor didn't look "seized solid" to me, when it clearly moved separate from the other plate. "facepalm* The whole cornering too hard and bend the roof thing just makes me shake my head. I'm not saying that the strut tower braces are not a good idea, but don't make them out to be a miracle item that it's not. "Went through all the trouble to remove the exhaust in one piece" really? how else would you do it? It's welded solid and the easiest way is to remove it in one piece... *facepalm* The muffler looks like shit on there. The tips, or muffler outlets are spaced too far apart. What's with this "deadline" stuff? Why is there a deadline? Just to add drama? The show would be better without. The car ended up looking nice in the end, but is in no way a "dead ringer" for a 432. They should have also addressed the suspension, due to the rear end squatting issue. New springs would have helped here. The car probably needs new strut inserts as well. It seems that if it can't be bolted on easily, the "Garage Squad" doesn't do it. I hate shows like this, they make things seem far more difficult than they are for no reason, and add more drama than is necessary.
