Six_Shooter
  1. Over what length? As the wire length gets longer, the resistance goes up, reducing potential current transfer.
  2. I'm not a fan of deleting windows, in any car, especially the 240Z.
  3. Move the lights from side to side, so that the thin area is out
  4. Try it with the lights on opposite sides.
  5. Soda tastes better than sand, less gritty too. lol
  6. uhhh... Your welcome? LOL I just haven't had good experience with the aftermarket universal wiper systems. You can look into the Honda/Civic wiper motor swap as well. Many people report good results with it.
  7. Is anyone interested in trading a pair of USDM (all red) 1973 240Z tail lights for the AUDM (Amber turn lens) tail lights? I have a pair if good condition 1973 240Z tail lights, that I can get pictures of for anyone interested in trading. Just bear in mind I am in Canada, so shipping will likely be a little slow. lol
  8. After installing a couple aftermarket wiper systems, I would NEVER consider one for my own vehicle, or for anyone else really. I would spend the time to modify/add to the harness to get the OEM wiper system working, or at the very least using the Civic/Honda wiper motor swap.
  9. Translucent paint also works. I think this is how I'm going to get my JDM (look) 240Z tail lights, using clear replacement sections.
  10. For the extra few bolts it would take to remove the heater boxes, I would remove them. Nothing worse than having sand end up in there and either ruining the flaps after re-assembly (and use) or having the blow out at you, when you use the heater.
  11. Was it the universal shaft that snapped or the output axle flange that snapped?
  12. That doesn't apply to the '75.
  13. That's an L20 with Delco electronics. Antus got a hold of me when they first started that project, for some guidance on how I did mine. The OP has an L28 with L20 parts. If it was my car, I'd likely fire it on the L20 ECU, if it was there, but wouldn't drive it until it was tuned, or swapped to a different ECM, that I was able to tune.
  14. A 1973 240Z. For parts... My buddy, who helped me with the tieing down and such. He'd been up for like 30 hours by this point and has a hole through his foot from a nail he stepped on the other day... :S The car is quite rough, but has some decent parts, like a rear sway bar, possibly upgraded front sway bar (need to measure and compare), a header, possibly rebuilt 280Z engine. Aftermarket steering wheel, that I'll at least be able to keep the adapter, the foam on the wheel itself is pretty rough shape. The guy I bought it from said it has a 5-speed, so I'll have to check that. The wheels are in good shape, which is surprising looking at the condition of the chassis itself. Same with the fenders, they are in good shape. The hood and hatch are basically rotten though. The chassis was at the guys house, but most of the body panels and other parts were a few blocks away in another garage. We bolted the fenders on, and held the doors in place with straps. LOL It also came with two VERY good condition black 280Z (260Z for you down under) seats, those will be going in my car post haste. I then went to another place after getting the car home and bought some brand new, never installed head light covers.
  15. The bottom one (in the picture is the reverse light, the middle one is 3rd or 4th gear switch (4th gear I'm pretty sure), the top one I'm not sure about, if it was nearer the shifter I would say a neutral switch.
  16. I'm not a Mountain Motor fan, but that is pretty cool.
  17. Just to update, I ended up picking up a 4 speed tranny and swapping the cast iron shift forks into my 5 speed. I had to drill the holes for the roll pins a bit larger, to use the 5 speed roll pins, since they seemed to change size at some point. This tranny has never shifted so smooth. I just wish I had kept one of the 4 speeds I had long ago, so that I didn't need to buy another one. lol
  18. I'm running an N/A F54/P90 combo that has unknown milage (already installed in the car when I bought it), that I added the 280ZX exhaust manifold, Cam cover (Only makes sense, right? ), F47 (IIRC) intake mani, since the car was carbed when I bought it, a Borg Warner turbo from a 6.5L turbo Diesel, and Delco (General Motors) EFI to, using an N/A 280Z (NOT ZXT) dizzy, and I've ran as much as 14 PSIG non intercooled, but backed it down to 9 PSI until I added the IC, at which point I turned the boost up to 15 PSIG, running on 91 octane fuel that can contain "up to 10% ethanol" (Damn Canadian fuel). I abised it for about 3 years non intercooled, then abused it for a little over a year intercooled. I also added DIS before adding the IC, using a custom trigger wheel set-up and GM coil pack. You don't need to use a turbo engine, the N/A version will take boost just fine, especially with the advances of modern EFI. If you want more specifics, they are in my build thread in the members section.
  19. I was thinking something similar, as in how I could take all of those Ferraris and swap parts around...
  20. No, he simply said the gauges are on the wrong side, I said they are not. lol
  21. No, they're not.
  22. Here is a picture of the foam based speaker enclosing pieces (I resist calling them baffles, because a baffle refers to a different part of a speaker mount).
  23. I don't know why you guys are getting a lot of noise, through the mount. I've been running one for a year or so now, and noticed no difference in diff noise. *shrug* If I was to go to a rubber style mount again, I would likely look at something that mounted from the top.
  24. I'm not sure if you can get them over there but here, we have speaker pods (for lack of a better name) made of foam that enclose the rear of small speakers. This helps with a more controlled speaker (improving sound), but I wouldn't expect any miracles. The biggest thing to try and do and isolate the rear wave of the speaker from the front wave, in other words, isolate the sound coming off the rear of the speaker from the sound coming off the front of the speaker, as much as possible. The other thing that will help, and a lot I might add, is solidly mounting the speakers. Building a bracket that attaches to the structure of the car to support the speaker will help improve sound, along with reducing rattles and buzzing from interior panels.
