Riceburner
Riceburner last won the day on May 25 2020
Riceburner had the most liked content!
3 Followers
About Riceburner
  • Birthday 06/09/1980
member details
  • Location
    Melbourne, Victoria
Recent Profile Visitors
4,418 profile views
Riceburner's Achievements
  1. They style of trumpets will differ too, The EFI hardware type will be harder to fit because of the large bellmouths on the end. Alans look pretty close to 50mm.
  2. Probably a better question for Alan as I don't run triples so the spacing is different.
  3. EFI Hardware https://www.efihardware.com/products/1045/cable-pull-with-opposite-link
  4. Nice Jeff. The trim retainer around the roof is a good idea
  5. Re LSD’s. I’ve no actual experience with the KAAZ type but I did read about them being noisey. I’ve got the OS Giken, from the driving I’ve done it’s really quiet and you don’t know it’s there. $80 a litre for their special oil is crazy though.
  6. Started a new little project with my bro to install the two spare FCR41’s I have to his newly rebuilt 510. He sourced a Nissan SU manifold for only $50. I spent time yesterday sand blasting and cleaning up the ports with a dremel lol. My first try at porting, so hopefully it’s ok. It’s going on a stock L20B with a brand new V912 head running a 72 degree cam. Mikuni couplers will need to be ordered but I think they’ll bolt straight on to the manifold studs. We might also have a look at port matching the manifold now it’s been buzzed a little. Looking to run it with the gold Keihin ‘power blade’ velocity stacks. They’re 50mm long, 65mm at the opening and run a blade half way through the stack. It’s meant to improve air speed at low to half throttle. The hardest thing will be fuel supply as the FCRs run plastic T pieces that are held in by the adjacent carb, now the spacing has changed we need a new solution.
  7. Ok, if it’s going to be a horsepower killer it’s not a good idea then! Lol
  8. Does anyone have an idea as to how well the factory SU manifold flows? I’m toying with the idea of pulling the six FCR41’s and installing two of them onto an SU manifold after porting it, with a stock air box and the yoshi dual trumpets. Not sure what power losses I’ll have, if any?
  9. Small donation made. Thanks for all you efforts and all the best going forward.
  10. They look really nice, price is pretty reasonable too. Clearance may be the only issue around the strut tower when running sock filters. I used to run a sock filter minus the internal spring for intake 3, this would occasionally get sucked down into the trumpets. What’s the disadvantage with running a total length a few inches shorter for filter clearance? Or can they do filter backing plates, one that mounts to the back of the trumpet bell mouth, and the second that will allow you to sanwhich a custom uni filter on the end?
  11. That looks the same as what mine were, from memory the LSD centre buttons they thread into are only about 8mm thick. @Mods, Might be a topic for drivelines.
  12. Thanks for responses guys. Yeah it’s both calipers doing it. New flex lines were part of the rebuild. He did paint all of the calipers during their rebuild, I wonder if that’s binding up somewhere. Could be time to try a spare set of Calipers.
  13. Confirmed push rod length and connection looks all ok.
  14. Attached pics and info on how he ran lines. Ok so maybe the residual pressure should go back in once the issue is fixed? He is double checking the push rod length, he did have to adjust that at install. EDIT: One thing he wasn’t certain of was how tight the front caliper nut with the split should be.
  15. Hi Dave, I’ll have to check if there’s been any other mods other that the twin reservoir master. Initially it was holding pressure all the time, rock hard peddle after a few applications, brakes red hot. He opened up the master and removed this (see pic). Following that is seemed ok, now it’s started doing it again. A short drive to the local servo with half a dozen brake applications, the fronts could not be turned by hand and were red hot. After 30mins you could doing them half a turn. Front calipers have been tested and they moved freely.
