Showing content with the highest reputation on 12/02/2022 in all areas
  1. Nice! These 44's are the type 4's, with the external float adjustment. Nice to see a new set for reference, as I refurbish the PHH's.
    1 point
  2. Selling another set of my Mikuni 44's https://www.ebay.com.au/itm/175504175553
    1 point
  3. A few weeks ago I bolted the crusty old TH400 from the Statesman up to the LS1 for a trial fit. Unfortunately they wont go in together as the crossmember just wont allow it, so I split them and dropped the engine in and trans from underneath which is a bit if a drag. As expected the tunnel needed a bit of massaging to fit the TH400. The sump I was using was a Holley 302-1 which my nephew had bought but not used in his project but the front of the sump was too deep meaning the front of the engine was too high and was going to cause driveline alignment issues. A bit of research said that the Holley 302-2 which has a very shallow front section should fit but they are over $800 so crossed fingers and ordered one of these from VPW for $299 https://www.rts.com.au/oil-pan-ls-en...tural-6-lt~126 which is just a China knock off of the 302-2. Sump arrived promtly, looks good and with pick up, gasket and bolts etc its bloody good value. Swung the engine in again and it fits exactly where I wanted it to go after I had to notch the crossmember, the front section sits nice and low over the rack and the rear bowl is level with the bottom of the crossmember. Got the engine and trans aligned and sitting at 2.5 degrees nose up which is way better than with the 302-1. Made a temporary rear crossmember With the engine sitting safely on a piece of timber on the crossmember and with the rear of trans secured I could start making engine mounts. Got the top and bottom plates roughed out and called it quits for today.
    1 point
  4. JDM-TOY
    The Build 73 240Z
    Dash areived today, quite happy with the finish. Has some imperfections at the inner glove box section but will be hidden once the glove box door goes on. iC7 fits quite snug and now looks complete. I wasn't sure how it would look when finished and Im suprised how well it looks complete
    1 point
  5. We have colour! Ferrari Rosso Corsa Red. My camera makes it look washed out & more white then it actually is - I can assure everyone it is very, very RED! Next the doors & guard jambs will be painted, then they well get bolted on, we'll sand the primer to 400g dry. After that it goes into the booth for top colour I'm hoping to have paint on it in 2 weeks...
    1 point
