twoforty z Posted January 19, 2022 Posted January 19, 2022 3d printed horn pad retainer rings. Replacing your broken horn pad is now easy and super quick, pull the old one out, us a little bit of silicone or sikaflex and just clip the new one in! Printed to fit the 240z horn pad, but will also fit 240k and 510 SSS horn pads. $35 posted, and $5 from every sale is donated to the AusZcar forum. gilltech and 240ZBUILTBYME 2 Quote
NickF Posted January 20, 2022 Posted January 20, 2022 Great I'll take one Will pm address Thanks Nick Quote
NickF Posted February 1, 2022 Posted February 1, 2022 Arrived today a tight fit on horn ring Just have to make sure of a good adhesion and fit to horn pad Nick twoforty z 1 Quote
Dirtydatto Posted February 3, 2022 Posted February 3, 2022 Anyone on the fence about these, you shouldn't be. I got one of the first ones and it fits perfectly. You will probably need to dig out some of the old foam within your horn-pad to get the old retaining ring out, but as long as you don't go too crazy and leave a good amount to secure the position of the ring, you can fill in the cavities with whatever glue/epoxy you use. Big shout out to twofortyz for getting these done! gav240z and twoforty z 2 Quote
Administrators gav240z Posted February 4, 2022 Administrators Posted February 4, 2022 I bought 3, haven't fitted yet. Any suggestions on adhesive to use? Quote
240ZR Posted February 4, 2022 Posted February 4, 2022 I got the ring, just need a horn pad!... Can anyone help???????????????? Quote
Dirtydatto Posted February 5, 2022 Posted February 5, 2022 On 2/4/2022 at 8:17 PM, gav240z said: I bought 3, haven't fitted yet. Any suggestions on adhesive to use? I used sellys contact adhesive from a tube. Gave it overnight to completely set and it was good to go. gav240z 1 Quote
AndBir Posted February 9, 2022 Posted February 9, 2022 On 2/5/2022 at 8:53 AM, 240ZR said: I got the ring, just need a horn pad!... Can anyone help???????????????? https://www.gumtree.com.au/s-ad/brigadoon/other-parts-accessories/260z-horn-button/1280921314 Quote
Dirtydatto Posted February 9, 2022 Posted February 9, 2022 Fairly sure that horn pad uses a different type of retention system and subsequently horn button/bus for the column. From memory the bus has 3 "T" piece stand-offs that this pad locks into. The retention rings in the post wouldn't be suitable unfortunately. If you do really get caught in a pickle shoot me a message down the line as I have a good condition spare, but I don't really want to let it go. Quote
Dirtydatto Posted February 9, 2022 Posted February 9, 2022 3 minutes ago, Dirtydatto said: Fairly sure that horn pad uses a different type of retention system and subsequently horn button/bus for the column. From memory the bus has 3 "T" piece stand-offs that this pad locks into. The retention rings in the post wouldn't be suitable unfortunately. ^ OdinZ 1 Quote
gilltech Posted February 9, 2022 Posted February 9, 2022 The 240Z and 260Z (and respective Fairlady S30 or whatever) steering wheels and horn pads are completely different designs, as noted by Dirtydatto above. OdinZ 1 Quote
