KatoKid Posted September 1, 2019 Posted September 1, 2019 Be careful of buying Bosch 044 pumps off eBay, most are knock off's. https://www.driven2automotive.com/blog/bosch-044-fuel-pump-is-given-new-anti-fake-security-seal/ Gordo 1 Quote
Gordo Posted September 2, 2019 Author Posted September 2, 2019 Time to pull the L28 engine and gear box out. It’s a good opportunity to redo the brake lines and run a new clutch line to hook up to the new gearbox. Time to clean up the engine bay of all things not required and fresh coat of paint. I haven’t had a fuel gauge in this car before. So now is a good time to fit one. eBay. The gear box measures up ok to fit and gear shifter is close to standard position. im choosing to make my own gearbox mount once it’s fitted. KatoKid and OdinZ 2 Quote
PeterAllen Posted September 2, 2019 Posted September 2, 2019 (edited) Gordon. This may be an issue long resolved by newer alternative options but at the time it was a PITA. Bleeding the t56 clutch was hard enough in a Holden but near impossible in an S30. The solution was to: Remove the long bleed nipple and replace with a short piece of tubing and a long flexible line - available from Mal Woods (Qld). https://postimg.cc/YGLKnsgG https://postimg.cc/rzq7tsZR Route the line up the firewall. https://postimg.cc/646Ssb4f https://postimg.cc/2b7JKNy5 Note: Do not let the line dangle unattached while you run the motor... D'oh! Edited September 2, 2019 by PeterAllen Quote
OdinZ Posted September 2, 2019 Posted September 2, 2019 What's the L28 going into, another Z project? haha Quote
Gordo Posted September 3, 2019 Author Posted September 3, 2019 Yes the motor goes back into the red 240z from which it came from. Mick sent the exhaust headers, sump kit and the engine mounts over. So I’m setting the hole lot up on to small trolley tabes so it’s easy to move around. When I pulled the L28 out complete with gearbox,headers, and Carbys the weight was 240kg total. So I’m looking forward to weighing the LS with all the add ons. The sump kit went on nicely. Came with bolts , pick up and dip stick. AndBir and OdinZ 2 Quote
Gordo Posted September 4, 2019 Author Posted September 4, 2019 With the engine set up on the trolleys I wanted to get as many accessories fitted to the motor I could. Needed the pulley belt to suit the under Drive pulley and a pulley to replace where the power steer pump would mount. I have electric steer. Powder coated the rocker covers. And coil pack brackets.had a new clutch line made with the push on fitting to suit the slave cylinder. The engine knock sensors where hard to fit in behind the headers. I had to put one near the engine mount . Next is to trial fit the engine and gear box. pics of Engine mounts from Dirty Dingo Quote
Gordo Posted September 5, 2019 Author Posted September 5, 2019 11 hours ago, KatoKid said: Stock ECU Gordo? Hey Dave, the guy who got me the throddel peddle that suits the flyby wire is getting the wireing loom for me. Quote
Gordo Posted September 5, 2019 Author Posted September 5, 2019 (edited) Putting the engine and gear box in was a bit of work. Was trying to support the rear of the gearbox to get the right angle to bolt or at least seat the engine mounts . This was in and out a few times as I had to cut the hole bigger to allow for the shifter to fit. So settling on the gear box height (as high as I could get it ) I was able to hold or support it with a pice of timber decking.lol. Some may not know but the steering imput shaft goes between the primary’s. Two on one side and two on the other. So positioning the engine back and forth deminishes the clearance because of the angle. That left me to fit the headers and position the engine according the the headers clearance. The header would not just drop in and bolt up. The engine had to be lifted about 100mm the guide the headers in. So the gear box was hard to support through out this proses. Anyway finally found the best position and used a string line to measure center line for gearbox. With this sorted I’ve measured and ordered my tail shaft. And made up my gearbox mount. Edited September 5, 2019 by Gordo Quote
Gordo Posted September 5, 2019 Author Posted September 5, 2019 The gearbox mount was made out of hoop iron to get a template. Then 5mm x75mm flat bar bent into shape. Bolted into the chassis rails and welded tabs with more bolts through the tunnel. Into and through reinforced plating. note the temporary gearbox support OdinZ and C.A.R. 2 Quote
KatoKid Posted September 5, 2019 Posted September 5, 2019 (edited) Gordo, have you checked drive line alignment? The rubber donuts wont tolerate any deflection so need to point straight at the diff pinion center. Are you using a uni joint or CV at rear? I've got lasers and brackets to check this if you want. Edited September 5, 2019 by KatoKid Quote
260DET Posted September 5, 2019 Posted September 5, 2019 Hmmm, I get the impression that this will be ready for CB19. Gordo and OdinZ 2 Quote
Gordo Posted September 6, 2019 Author Posted September 6, 2019 Picked up the tail shaft. The guy made up a billet adaptor to replace the stock donut. Theres also a slip join fo movement. Got some new high tensile bolts, fingers crossed they hold . With the tail shaft in I was checking the drive line. Seams that the clutch is not disengaging. That’s not good. I’ll bleed it some more tomorrow. Master cylinder could be to small, or I may have put the twin plate clutch in wrong. looking at the photos clutch looks ok, Might be a gearbox out job. KatoKid 1 Quote
260DET Posted September 6, 2019 Posted September 6, 2019 Those concentric throw out bearings can be problematical, is there a external conversion kit available? My 350Z has one. Quote
Gordo Posted September 9, 2019 Author Posted September 9, 2019 With the clutch not disengaging ive tryed a bigger master cylinder still not working. gearbox out found the slave cylinder was the right one for this engine gearbox combo, but not a twin plate clutch. the through out bearing needs to be shorter for the thicker twin plate clutch. back to the brake place and another through out bearing. after a bit more measuring and checking i put it all back in . finally we have a clutch. exaust was next on the list Quote
JonMortensen Posted September 10, 2019 Posted September 10, 2019 (edited) I have a 7.25" (18cm) 2 disk button clutch on my T56 and the QuarterMaster throwout bearing setup was VERY finicky. There were numerous warnings about setting it wrong and damaging the pressure plate or the hydraulic bearing itself. I had to do a bunch of measuring and then set up a pedal stop so that the bearing didn't travel too far. Maybe you did all of that too, but the way you described had me a bit worried that you might have skipped a step or two, or maybe it doesn't matter as much with the particular throwout bearing you have, but thought you might benefit from a heads up. Edited September 10, 2019 by JonMortensen Gordo 1 Quote
hmd Posted September 10, 2019 Posted September 10, 2019 (edited) Please explain Edited September 10, 2019 by hmd Quote
OdinZ Posted September 10, 2019 Posted September 10, 2019 Haha I had a feeling it was done already! Quote
Gordo Posted September 10, 2019 Author Posted September 10, 2019 (edited) Haha. It may be done. My updates are a little behind so I’ll try and catch up when time permits. the exhaust had to have a balance pipe and also be quite enough to get under the 75db noise limits. I could not believe how low the twin 3in exaust was. Tried to get it as high as I could. Even went to 2 1/2in just before the diff. Edited September 10, 2019 by Gordo OdinZ 1 Quote
Gordo Posted September 11, 2019 Author Posted September 11, 2019 With the exhaust complete it was time to tidy up all things under the car. Clutch , fuel and brake hoses all got some attention. The peddle box was put back in and brake and clutch bleed. Fuel pump wired up and tested. The engine sensors where hard to fit as the headers are very close. I got my self a oil catch can and fittings.i would be using the same alloy radiator with the inlet and outlets in the right place. Got some new hoses. The air intake bends filter and pipes from eBay . With most of the engine bay done it was time to take it to my mate for the wiring loom and final fuel line connections to be fitted. mossy and KatoKid 2 Quote
Gordo Posted September 13, 2019 Author Posted September 13, 2019 Wiring done as best we can. thurmo fans come on at 95deg. the tacko needs to be changed to suit the v8. was quoted $245 to convert the old one. So i think ill buy an after market one. On first start up the motor would not idle on its own. The new computer will need some programing to sort all this out. But at least it goes. So ive got it booked in for a dyno tune and if everything goes all right Ill do the next track day for a shake down. Quote
Gordo Posted September 13, 2019 Author Posted September 13, 2019 The tuner will be confused. Photo just for a joke. OdinZ and 260DET 2 Quote
