Good evening folks,
Quick question: Is it a must to have fender flares for the following wheel sizes? Or can I  get fenders pulled?
just
Front: 15x8j ET-5
Rear: 15X10J ET-32
Thanks
Agree - the 8's will probably fit if you get your guards rolled.
First,
Lets find out,,, on what car?
On a ZX body it is surprising what can fit, a bit f rear lipping and the old baseball bat, with a bit of back and forth action, and fitment of that "sucked in" tyre look, the neg32's may make it!
I have a few sets f new in box Watanabe knockoff's in 15x9 at neg 13, on a Z body, yes work needed, on a ZX body, they just sneak in ncely!
  • 3 weeks later...
In a 240z Im thinking the -5 will not fit...15x8 in a zero or +4 yes.. -5 has to be getting damn close to the perch.
you are getting it confused.  A negative offset will be further away from the perch than a 0 of positive offset as the back space is lower.
To the original poster. You will need big flares for the 10 with a -32 bigger than zg flares more like the group 4 type flares.
what car?
if it's a 240z, 10 wide with -32 offset, it would be poking even with flares.
I have 9.5 - 14 or something and it's 1mm from the flares.
  • 11 months later...
Hi, whats the deepest dish wheels that can be fitted into a 240z without wanting to put flares?
Does anyone knows whats the specs of this wheels? I only know its 14"
Wow gavin.. your eyes so sharp.. I couldnt tell..
Whats the deepest rim it can go without flaring? I want to the wheels something like the red car but dont want to flare.
I have 15x8 -3 and I wouldn't really want to go much further -ve... I put a 15x8 -11 on for testing purposes once which looked like this:
Personally I like a bit less poke so I can run some nice wide tyres for period correctness
  • 5 months later...
Food for thought. I probably should put a disclaimer up for haters and keyboard warriors... but meh.
So my current setup is 15X7 with zero offset running 225/50's. See pics.
post-104756-0-82731500-1463399874_thumb.pngpost-104756-0-33561100-1463399898_thumb.png
Now this sounds very daring and hear me out. But I'd love to run a dish with neg offset;
http://www.performancewheels.com.au/product/superlite-15/
Lets say I was to go for the 15X10 on rear, and providing that the tyre is stretched to a degree.. these are the following measurements I came up with with a -26, a -12 and zero offset;
post-104756-0-32439900-1463400270_thumb.pngpost-104756-0-70533300-1463400293_thumb.pngpost-104756-0-92149500-1463400313_thumb.png
Thoughts? If that's too extreme, maybe the Atara's 15X9 -13 offset running a 235/45/15
Have 3 sets f Atara here ready to freight.
Their fronts with a stretched tyre will jst get under a standard front guard, but rears with a stetched tyre will get very clse.
Rear lips will need work.
Pic f these Ataras on a Z.
For once I agree with the Yanks, measure wheels by backspace, much simpler that way. And of course tyre sizes and ride height can make a lot of difference to clearances, it's not all about the wheels.
Looking for SGR65's 'haters and keyboard warriors', looking, looking.........
Just don't go for this look.......
Fully sick stance bro............  ha ha ha  :o
