744 -
4
Everything posted by Roberto
You are talking about the vacuum advance unit itself, aren't you? If so, I got mine recently from Nissan. I think I got slugged $200, but it was genuine. I didn't realise MSA sold them. Nevertheless, much cheaper than a new Mallory complete unit ??
Mick and myself have decided to drive over for this and make a weekend of it. There is room in the car for anyone else from SA who would like to come. You know you want to! BTW: company car = no cost to anyone
I have never seen a fender brace the goes under the fenders. I can't really imagine it. I have seen this one that braces the fenders and strut towers through the engine bay.
Hi Dave, In the US, there is a mob selling these below. Not cheap ($700) and even more expensive to get it here, but you can see what he has done in the pic. The site is: http://www.datsunstore.com/product_info.php/products_id/661?osCsid=49b110cd9f3d03035efe85768de69115 Doesn't look like what you are describing, but that may give you some ideas for bracing.
Welcome mate! Enjoy the site.
There is one on ebay as we speak. $180 or best offer. OR http://www.zccjdm.com/catalog.php?ref=azcarbum&recview=11&dt=93287&disp=name&per=10 for $65 USD. Even with international postage would be around $100-$120 AUD
Can't miss this. I will be there too. PM Sent. (If anyone else from Adelaide wants to go, let me know)
At the workshop day, Rev (and I have heard it from others too) recommend not to use 2-pak colour paint in your garage because it contains isocyanate which is very toxic. A good mask may not help either, especially with neighbours, pets etc. 2-pak primer is ok because it does not have isocyanate, so you can do all your prep work safely at home. I have heard that HiChem does an isocyanate-free 2-pak colour paint but I don't personally know of anyone who has used it and recommends it. Still has to be more durable than Acrylic, heh? :-\
I would even make another trip over from Adelaide for that. +4
Why not just get thicker chassis rails and extend them further back? That would be the most common and simplest way of strengthening the chassis.
You don't really need an expensive oil catch can. Oil shouldn't leak from the rocker cover breather. When I had triples, none come out from there. Just cover it with a nice looking filter. As for the block, attach a hose to it, put a 90 degree bend fitting pointing upwards, then a bit more length of hose and then another one of those filters. This will allow gases to vent and keep the oil in the engine. If you want to use the catch can for the bling factor and because you already bought it, then that will work too. Just ensure the can is vented to allow gases from the engine to escape. You mentioned in a previous post hooking the can up to the inlet runners. If you do this then you don't need a catch can at all. It will be similar to the factory PCV system. Just make sure you use a PCV valve to regulate the vacuum and tap into all the runners to keep each cylinder equal. Does that help answer the question?
Hey Adam, Let me try to understand. You are going triples, so you are not going to have a PCV system connected. You want to be able to "catch" the oil that will slowly leak from the block vent (underneath the distributor). Is that right?
I used to use fully synthetic Mobil 1 and always had tappet noise I couldn't get rid of. I even added that "Tappet Noise Stop" additive (which has molybdenum disulphide) and it only marginally helped. This was a 30K since rebuild L26 engine. I decided to go for a thicker mineral oil because I figured that this is what these engines were designed to use. I switched to Penrite 20-60 and tappet noise stopped. Didn't even need to add the additive. My advice is to get an oil of the correct viscosity for older engines (usually a bit thicker) and change it more rather than less often.
Good stuff. Hey, you have the "260Z" staggered rear bumper holes. I thought all 240Z's had the holes parallel. Maybe just the earlier ones. Your rotisserie will not line up with earlier 240Z's then without mods??
You can get brand new 240Z rear brake drums on ebay from the US from $30 to $50 plus postage.
It was a great day guys! Nice to meet you all and put faces to names..... Thanks also to Simon (Maygz) for giving Mick and I transport from the airport. I took a few happy snaps too.
Here are some reported dyno figures in kw and hp at the wheels taken from zhome.com. Mickl you are only 10 - 12hp off what was reported for standard Zeds that day so maybe your engine is just a little tired. Don't forget also, different dynos give slightly different power figures...... Car Mods Kw Hp Datsun 240Z 2.8L 91 122 Datsun 240Z Race 128 172 Datsun 240Z RB20 turbo 84 113 Datsun 260Z Standard 75 101 Datsun 260Z 240Z carbs 76 102 Datsun 260Z Warm 93 125 Datsun 260Z 350 Chev 184 247 Datsun 260Z 2+2 Standard 72 96
Firstly, get another spray bar! Do not drive with a broken one as you will destroy your cam and rockers in no time. I am speaking from experience. As for power, when I first got my 260Z (with flattops) I couldn't believe how gutless it was. Nowhere near 160hp Gross which is now about 130hp SAE at the engine. At the wheels you should have about 110hp which is the best case scenario, assuming everything is good and in tune. If you are 20hp down, it could be various things from engine health (compression ) to timing and fuel delivery. My problem was flattops and too much advance. The flattops never got sorted, so the solution was roundtops and also got 280ZX electronic ignition. Changed the motor completely. Do you have flattops?
In addition to that, the auto 240Z's in Australia had a final drive ratio of 3.55:1. They did not change through the years. Don't know about the paint finish.
In Australia, 240Z's were built with a ratio of 3.9 (R180) and 260Z's 3.7(R200) In the USA it was a different matter (3.364 for manuals and 3.545 for autos) Aren't we lucky.....
You could try Nissan, but they will be closing lunch time today. Maybe in-stock??
http://www.viczcar.com/forum/index.php/topic,6012.0.html It's all here in the sticky post "Overview of L-series heads". Essentially they are the 240Z head: Small chamber, smaller valves and higher compression.
