KatoKid
Everything posted by KatoKid
  1. Haven't had a chance to even look at the Z in the last few weeks and so need to get cracking again. I had to build a frame on my test stand to replicate the firewall mounting of the main engine harness that runs over the back of the cylinder head so decided to extend this and make it a dual purpose work table as well as somewhere to mount all the components. The BMW design has a pretty cool nearly self contained main engine harness that includes the ECU, some relays, O2 sensors etc all this interfaces with the body via a single 25 pin connector, means they build one body loom for most of their models and each differnet engine just plugs in. The other element is the security system which many have tried but no one has succeeded in bypassing. The security system called EWS II is part of the body but still sends and receives inputs through to the ECU via the the 25 pin plug called the X 20 connector. Basically the security system sends code between the EWS box and the key and ECU via a transmit/receive module. Each time the car is started it sends new code to and from each component. It is imperative that you have the "aligned" key, EWS and ECU from the same car otherwise the engine wont run. They can for differnet reasons become "unaligned" which is a major drama to fix as it entails taking the vehicle to a BMW dealer for them to re align the system. Imagine a 240Z plugged into the computer at a BMW dealer!!!! Its taken a lot of work and effort on the interweb to understand the system and confirm the wiring on the factory diagrams which (for me ) are a nightmare to read. You should see the size and weight of the body harness...its massive. Ive had some great help from a guy on a BMW forum in the UK. I've striped out the bits I need from the harness and am ready to start putting it all together.
  2. Thanks Dimitri, couldnt be any closer to home!
  3. Im ready to start wiring my engine, ECU and EWS system so need to buy various colour and gauge wire, heat shrink, relays, switches, conduit and harnes wrap etc. Has anyone got suggestions on a good place in SE Melbourne suburbs to buy ? Thanks
  4. Radiator looks the goods Fu. Whats the issue with the fan shrouds and how much was freight? Im looking at a PWR, same set up with shroud and fans and they want $850 + GST!
  5. Ready now. Give me a best guess as to when I can have it back though as I will need it in a month or so if everything goes well.
  6. Jamo, you can have my for a few weeks.
  7. Nice work! Know how you feel about not being happy when you know something could be better! Accurate drive train alignment is so important, anyone can drop an engine in and it will likely be OK for a while but will ultimately come back to haunt them.
  8. Well done both of you. Need to post video of Jane's run! looked like great fun, might give the rolla a run. No surprises re getting bogged, was thinking it would turn to custard if it got really wet.
  9. Howd you go Lurchos? Looked like the rain was about to set in when I left.
  10. What time does it kick off Lurch?
  11. Sorry guys, I had a meeting in Sydney that ran late and missed my flight home. Every tried to get out of Sydney in a Friday night? Its a nightmare, had to wait 3 hours so didn't get home till pretty late.
  12. Good stuff Benny. Most guys wouldn't be bothered with making something like those brackets.
  13. Very excited for you Pete.....and the rest of us who can watch this unfold. Un naturally aspirated engines are awesome for the power they develop but there is something magic about a berserk NA engine and is the true test of real engine builders. Kudos to you for taking this on! I'm a relative newby compared to some on this forum so would appreciate a bit of background on this Neil C?
  14. Looks the part Tim. Geeeze, could they have matched you up with a tougher opponent? Clubman is practically an oversized go kart anyway!
  15. I'm of the similar opinion. Keep it bolt on if you are concerned about resale value, you can have a pretty trick car with lots of cool bolt on stuff if you really want to. The only thing I would love to do but wont because it destroys the inherent value of the car is ZG flares. Otherwise its really up to your imagination as to what you want to do.
  16. Very nice, what finish will it have? Matt black to match dash and console?
  17. Are they new cores or old second hand ones? There are many points in a cooling system (like hoses) that would/should be weaker points than the heater core.
  18. Sierra Charlie Oscar Oscar Tango Alpha did you take photos particularly for handbrake mods?
  19. Hey Mick. Let me know if you need a hand with anything. Ive got a pretty good handle on whats required to get BMW stuff running in a non BMW. David
  20. My brother has just finished building an LJ Torana for Group Nc. First test day at Winton it spat a welsh plug on his second lap. He replaced it at the track and its been fine since. Welsh plugs can vary in fit and depend on how they are installed as well.
  21. Congrats Pete.......must be an unreal feeling. Im looking forward to being in the same place in a year ......or two.....or three.
  22. Happy Birthday Scoota
  23. Adam, do you really need to ask! Close enough to L series porn.
  24. Very nice Pete, Im sure youll fly through.
