A couple of other things that were on the To Do list.
I've had lots of grief with clutch function in previous conversions, generally not enough throw out and clutch not releasing fully and this was down to a combination of insufficient pedal stroke/ratio's and mismatched master/slave sizes. I was determined to get this right this time and I succeeded...too well. The clutch pedal stroke was unnecessarily long and the take up point really high, up near the top of the pedal stroke. So I wanted to reduce the stroke and make a more neutral/natural feeling clutch which engaged in the mid to upper mid of pedal stroke. I'm really particular with this! The clutch master is a BMW setup under the dash but it doesn't have an adjustable push-rod so the only way to adjust pedal height and stroke was through re-drilling the point were the rod attaches to the pedal. Took me a couple of goes and in the end I had to welder-up the couple of holes I had drilled and punch a new hole mid way between holes but in the end got it spot on. Happy left foot now!
Heel and toe wasn't possible with the original brake and accelerator pedal set up. Once I had the clutch were I wanted it I was able to lower the brake pedal by adjusting the push-rod length to the same height as the clutch and hey presto, much better but still not perfect. I need to fine tune a bit more but I've got plenty of adjustment left.....and wear some proper shoes....Blundstones aren't really driving shoes!
The original bonnet release cable had broken and been McGyvered by the previous owner. It worked but I had thoughts of the cable breaking in the middle of no where......I had some credit with MSA and lashed out and spent a ludicrous $167 on a new genuine Nissan bonnet release. Peace of mind if nothing else!
