KatoKid
Everything posted by KatoKid
  1. Massive amount of work to maintain a property like that....but then again looking at the money they have spent they can probably afford a full time gardener.
  2. Thanks Gordo for organizing. Cracking day and roads to match.
  3. Zest for coffee in Emerald ? Go there with the lycra gang and they really look after us.
  4. Nah G man. I've searched everywhere for a new 3.54 ring and pinion with no luck. My diff is a bit noisy on coast so I don't want to do anything to aggravate it so will give to the "experts" to set up.
  5. My long awaited and badly needed LSD has arrived! I had a KAAZ 2 way in the car when first completed but it was too aggressive for a road car for me. I did some research and was close to going with a Quaife gear type LSD but read that they single wheel when suddenly unloaded and were a bit unpredictable so kept coming back to OS Giken Supalock. The OS Giken website no longer lists a Supalock for long nose R200 but a bit of interweb trawling found this: https://whiteheadperformance.com/product/os-giken-super-lock-lsd-limited-slip-differential-unit-long-nose-r200-ns046-ha-datsun-240z-260z-280z-280zx-nissan-300zx-z31/ Whitehead insisted that they do fit the long nose R200 so I took the plunge. The LSD is for the US spec S13/S14 240SX and looks like it will fit but has 13mm bores for the crown wheel bolts (not the normal larger 12mm bores of the later R200's). If you have a 12mm bolt crown wheel you need to buy the Nismo S15 crown wheel bolts that are 12mm with a 13mm shoulder....or if you have a 10mm bolt crown wheel like me you need to buy 10mm- 13mm sleeves from SW Motorsport or have some turned up.
  6. Weather permitting
  7. I am so in this boat!
  8. Thanks guys, sounds like there are some options out there. Will do some more research
  9. As much as I love the look of my reconditioned 240 factory seats I've come to realize they are garbage for spirited driving so I'm looking at race style seats. Not full on race seats but seats that will provide good support without being impractical for my sunny Sunday drives! The only ones that I have seen that fit well are Velo Milano but they don't make them anymore so interested to hear what people are using and that fit well. Thanks.
  10. KatoKid
    2018 VicZed BBQ
    @WayneI'm going to steal your seats while you aren't looking!
  11. In the photo I attached. The plunger switch in the top middle, it unscrews from the PDS.
  12. As you point out the emergency brake light on the dashboard is triggered by the handbrake lever as well as the pressure differential switch under the master cylinder. Unplug the wire to the PDS and if the light goes out fully you know the problem is with the PDS. Our cars are very old and most PDS will be fully or partially seized and if you have done any brake work and had to bleed brakes they can kick to one side and stay stuck in that position which will trigger the light. On my 240 there is a main earth terminal on the PDS mounting bolt as well, check this is clean and secure. Pic below for reference is not a Z car PDS but same principle.
  13. KatoKid
    2018 VicZed BBQ
    With bells on.
  14. Rocky did a good job
  15. Not for me, but others may be keen on battery tray/inner guard.
  16. Epic find, they are still around....reminds me of how I found mine. Well done and looking forward to following progress.
  17. @gav240zI did a lot of research on exhaust systems for my swap. Pretty well all BMW factory systems are dual systems, for the E36 M3 they have dual 2" and I went for dual 2 1/4" as the cross sectional area is significantly more than a single 3". Sure you have some extra weight but the efficiency and HP is worth it....I think
  18. My original horns still worked but the laminated mounting brackets were really badly rusted so for the sake of $17 I bought these fully sic jdm horns bro.......they work https://www.ebay.com.au/itm/RED-1-Pair-12v-118dB-SUPER-TONE-LOUD-COMPACT-ELECTRIC-BLAST-TONE-HORN-JDM-WRX-HA/153100225779?hash=item23a57c0cf3:g:o68AAOSwiVJbSwQl
  19. I approve of red rocket rocker covers......carry on sir
