xa1973
Everything posted by xa1973
  1. Well well good pickup..... And so she goes around and around like a bottle down south passed on from hand to hand... Look forward to your progress.......
  2. Repco, Auto 1, Autobarn, Coventry should be able to supply with a kit, youll need year of car etc, not sure on cost, should only be few dollars I generally use about 3 to 4 bottles of Shell brake and clutch dot 4 fluid and give everything a good flush out Check your booster for leaks also, get a mate to listen for you while you apply the brakes or visa versa or connect a T piece to the vac line with a pressure gauge attached See how you go..........
  3. Good one Mate... How about some pics....
  4. Pull the Master apart and put a kit through it, sounds like the systems full of muck, disconnect all your lines and blow them out with compressed air, check for kinks etc to rears......
  5. Hmmmm..... Would that be Townsville or the Gold Coast....
  6. The heater / block parts your after are available from Warren @ Allzed Or REDAT Ebay USA.... Not cheap for what they are......
  7. Congratulations to you both... May you both enjoy memories beyond any measure to treasure forever together....
  8. A shame it wasnt a month or so ago..could have a good stag night for Sulio.....
  9. Good one Rev..... With or without the engine?
  10. Same as Lynton... or to refurb yours will cost around $300 to $400 odd....either way your up for some cash.
  11. ......and LX Toranas, HQ's, Premiers
  12. xa1973
    Classic Japanese
    Public event, Public forum, Freedom of Speech....Westminster Law If the facts are the facts, no one can be liable C'mon George fill us in....... EDIT: Greg.........
  13. I like both original and modified, many of us here own one or the other or both and are not limited to just Z cars either, a lot of us own all manner of marques with mods and shoe horned engines EG: Im keen to see oozla's project complete ( )
  14. Yeah I also endorse Warren and Miriam, good people to deal with...not always fast though Pauly, sometimes he says he has the stock, but it in reality is waiting for it to land from off shore...
  15. Good one.......... Was this the motor I posted for you, from an old XP or similar vintage.....?
  16. Buy a 280zx......$5k will buy you a very tidy good runner........
  17. Dave Where did you end up getting your motor from...........
  18. Is your upgrade Master a new item or second hand.. if second hand put a kit through it..but first of all re bleed the system starting from the passenger side rear first etc, check your rod length Ive found in the past what I thought was a thourough bleed has still contained air in the system, I generally use three to four bottles per fluid change
  19. xa1973
    Want to buy 260z
    A location wouldnt be too shabby either.......
  20. Aegean Thanks for your reply...Ill remember that one...
  21. Another quick test... You have a good battery, it will crank when you bridge the starter with the screw driver.... splice into the ignition wires with a toggle or preferably a momentary switch and it should start.....
  22. A quick test... I assume your battery is at full crank amps.. With the ignition on, jump across the starter terminals with a screw driver, it should wind over and or start, or remove your starter and reinstall, sometimes the throw out will jam, Z starters are not the flashest in town once they are worn, get a High Torque..
