362 -
9
Aaron Neubauer last won the day on September 13 2021
Aaron Neubauer had the most liked content!
About Aaron Neubauer
- Birthday 02/04/1985
member details
Location
Toowoomba, QLD
Recent Profile Visitors
Aaron Neubauer's Achievements
Does anyone have a usable LD28 block and main caps on Aussie soil? I suspect its a very slim chance but I figured I'd ask. Cheers
Selling my used LM2 single WBO2 sensor data logger. Comes with OBD2 cable and spare extended weld in bung. I previously used this for data logging and tuning my SU carbs and my Megasuirt MS3X on unleaded pump fuel. The power supply has been modified for a permanent install and the original socket plug is included in sale. $350 ono. Located in SE QLD and can post at buyers expense.
I'm selling my faithful MS3X on V3.0 board with knock module for $500.00 ONO. Located in SE QLD. I can post at buyers expense. The ECU was wired and configured for sequential fuel and direct ignition coil drive for a distributor based ignition with two WBO2 inputs on my L28 stroker. The distributor driver is a BIP373 ignition driver internally triggered by Spark A from the MS3X. It comes with remaining unused wires for harness kit, the two DB connectors and as much of the custom harness wires (no sensor or actuator connectors) that I can salvage. Reason for selling is I was able to obtain an Emtron ECU at a good price.
gav240z reacted to a post in a topic:
Neuby's red rota'd 240Z
CroS13 reacted to a post in a topic:
Ponyo240z reacted to a post in a topic:
Mike_F reacted to a post in a topic:
sexual_sushi reacted to a post in a topic:
Aaron Neubauer replied to Aaron Neubauer's topic in Members Project(s) Journal
Well its been a while! Here is a high level summary of what has happened since the last post: Tanks Inc PA4 fuel pump installed in the shallow part of the fuel tank without any welding Ended up upgrading to a Megasquirt MS3 CPU, MS3X expansion module and internal knock monitor - full sequential fuelling and retaining L20Et dizzy converted to full cable throttle debugged a number of items with the EFI and added sensors to allow for more compensations with fuelling calculations I've tuned the fuelling tables while keeping peak timing ceiling at a conservative 30 degrees until the knock sensing is tuned. The designed third harmonic of the manifold occurs at 5500rpm and you can definitely see the effect in the fuelling maps and the way the car picks up from 3500rpm. It serves as a little bit of validation for Whitleytune's design. Next stop, dyno runs on the same dyno for comparison!- 115 replies
hmd reacted to a post in a topic:
CBR Jeff reacted to a post in a topic:
I think I fixed it- 115 replies
Hey guys. The ITB manifold has arrived from Whitleytune. It's a mad bit of kit. I will just leave not safe for work photos here for now..... If you want to see the youtube update use the link in my the signature- 115 replies
A little more has happened with the EFI build. Dual lambda sensors is what! I had planned to run dual lambda sensors on the Hitachi SU carbs if I had not the opportunity to work with Whitley Tune and the sport injection setup. The goal now is two injector banks with target AFR maps. I run a Zstory 6-2-1 header and I decided to locate the sensors at the collector of the primaries to mitigate the risk of air contamination through a joint. Its probably overkill but it seems sensible to have the most accurate reading possible if I’m trying to have the most accuracy target AFR map for two banks of injectors the MS1 V3 allows me to have. Cylinder 4-6 location was easy! The collector is located in the space between the gearbox and transmission tunnel. This one was near vertical which is the optimum orientation. Cylingders 1-3 collector is tucked in behind anything and I could to find an orientation that I was happen with to manage heat for the sensor and the wiring so I located on the side of the collector. The sensor and wiring is just in front of the gearbox in the space behind the sump. Its not completely horizontal but I’m confident its still in a good location. Innovate Motorsports recommend 24” from exhaust and these are about 35”. I’ve had an LM-2 for more than ten years and I plan to install a DLG-1 if it ever gets here (understandable shipping delay). Matt welded these bad boys in (MYS30 build). I am in his debt . Cheers guys!- 115 replies
Aaron Neubauer changed their profile photo
Thanks mate, good to know!- 115 replies
Time for some Megasquirt ECU mods! I had configured the MS1 V3 board for ignition only. Some additional work and mods are needed to make it fully armed and operational for EFI. In the process I broke a leg off one of the current resisting devices for the injector banks I will have to buy new ones from DIYautotune as they are hard to get with the hole to mount on the heatsink. Thats really all that is left to complete on the ECU. In summary I've added: second WBO2 sensor input second Nissan optical trigger input fan relay control 2 wire IAC control shifted the launch control input 5V tach output There isn't many standard configurable pins left in the DB37 harness now.....- 115 replies
Porting can fix any flow problem though there is heaps of wall thickness in any SU manifold to work with to improve flow path particularly at cyl 1/2 and 5/6 divisions.
I think mine is an E46. Only match ported supports 201.6rwhp.
Aaron Neubauer reacted to a post in a topic:
Stainless Steel Exhaust Manifolds, Exhaust And Jdm Twin-Pipe Rear Silencer.
- 115 replies
So, stock 4 screw round tops can support at least 201.6rwhp. There may be some debate over how the dyno calculates hp but there is a decent increase from the last dyno in hp and torque from essentially a tune to the fuel and ignition. Tune is super rich which could be fixed with different needles like TF but I wanted to get a run in in case QLD requires a lock down to manage the pandemic. I’m super chuffed. When I set out to home build the L28 stroker motor all I wanted as 200RWHP with triple Webers. I think I said that years ago in this build log in fact! To think I could achieve that with the standard carbs is amazing! I’ve attached the 2017 dyno sheet and the 2020 sheet. I can now get back to the ITB EFI swap knowing that it is likely to only make more power!- 115 replies
Profits from shirt sales donated to the site
Aaron Neubauer replied to Aaron Neubauer's topic in General Discussions
Use the promo code AUSZCAR for a discount on shirts. Any profit left will be donated to the site. Same designs are at Redbubble which are AU based. https://www.redbubble.com/people/BuiltOnPurpose/ -
@gav240z haha! I can at least confirm an increase from 170rwhp....- 115 replies
