So i have assembled 60% of the brake kit for my car.
It currently consists of:
Porsche 986 Boxster calipers front and rear (986 Boxster weight is 1280kg)
RX-8 Sport 320mm x 24mm DBA 2 piece rotors drilled for 4 x 100 PCD
Caliper piston sizes:
F Disc 298mm, Pistons in Calipers 2x40,2x36 mm , pad area 216 cm^2
R Disc 292mm, Pistons in Calipers 2x30,2x28 mm , pad area 196 cm^2
Stock Boxster rotor sizes:
Boxster front - 298mm x 24mm - 6.67kg
Boxster rear - 292mm x 20mm
Ok so my questions are one, will going up to a 320mm rotor in the front overcome the what I am assuming would be a more rearward bias this car would have from the factory being rear engined?
Two, is there any point switching to a manual brake master cylinder to save weight and get more pedal feel? I have read that engines with big cams don't work well with boosters as the vacuum isn't there to power it so you are better off with a properly setup up manual system.
Just to put in, that i don't want to go to the expense of an aftermarket pedal box at this point, but will obviously get a proportioning valve to help setup the bias correctly. Also how much difference can you get with the proportioning valve?
