If you can give me your address I'll be down that way on Sunday. I've removed quite a few 240/260 dashboards. Usually takes me around 30 mins to remove and about 3-4 hours to install. First you have to remove the + terminal on the batt, then the heater control panel, steering column bolts (4 underneath), center console, (easier if you remove indicator/lights/wiper switch and steering wheel) bolts supporting the dash on the trans tunnel, bolt on each side where you floor vents (and bonnet release) are located, panel that sits along the bottom of the windscreen (4 self tappers i think!) then all the bolts along the top, disconnect the wiring loom for the dash and I think that should be all. Its been a while since I've done one so I may have left a detail out... Hope that helps a bit!
